sharp lc32d42u power supply - DPS-178APA
  • metropical
    • Jan 2017
    • 42
    last 2 times I had an issue with this supply, it was a 5wt zener in the stand by circuit.
    That zener tests good and the 5vt stand by (bu) supply tests good.
    Any idea what I could check next?
    It's a cheap enough supply on the "pulled" market place, but I might just be inheriting someone elses future problem.
    https://flic.kr/s/aHsmKXfqpn
    • 12196
    • U.S.
    Re: sharp lc32d42u power supply - DPS-178APA
    What do you get with test #3 below.
    • metropical
      • Jan 2017
      • 42
      that is a link to snaps of the plugs in case res isn't high enough.
      the 2nd pic with 2 plugs; plugs are shown out just so I could get a clear pic. The plugs were in when tested.
      bottom plug of 2nd pict.
      Pin3 to ground stayed at 0v off and on.
      Pin2 stayed at 5v off and on.
      the 1st pic is the only other plug on the powerboard.
      Thanks for your help, nomoresonys.
      • R_J
        • 9535
        The only two pins you checked were on PD pins 2 and 3 ? (pin 3 IS ground)
        What about pin #1 which is the PS_ON (power supply ON)?
        • metropical
          • Jan 2017
          • 42
          lemme clarify
          top to bottom
          p1 - gnd
          p2 - bu5v
          p3 - pnl power
          p4 - gnd
          p5 - AC detect
          p6 - PS on
          I'll go back and check the others.
            You count the PD connector pin wrong:
            Pin 1 = PS-ON
            Pin 2 = AC_DET
            Pin 3 = GND
            Pin 4 = PNL POWER
            Pin 5 = BU 5V
            Pin 6 = GND
            • metropical
              • Jan 2017
              • 42
              OFF ON
              Pin 1 = PS-ON - 3v 3v
              Pin 2 = AC_DET - 3v 3v
              Pin 3 = GND -
              Pin 4 = PNL POWER - 0v 0v
              Pin 5 = BU 5V - 5v 5v
              Pin 6 = GND-
              In other words, voltages didn't change off to on.
              • metropical
                • Jan 2017
                • 42
                I forgot to mention that the front "stand by" LED has been cycling since the failure.
                ~.5 sec off/~5 sec on.
                The service book I have shows a "power board" on p 10-39 to 10-42.
                PDF page 100-103.
                On page 102 there is a representation of the plug and voltages of which I've been testing.
                1 - PS_ON 2.8v - I get 3.025
                2 - AC_DET 3.2v - 3.08
                3 - G
                4 - PNL_POW 3.3v - 0v
                5 - BU5V 5v - 5v
                6 - G
                So it appears P4 is missing it's voltage.
                Though I don't think this is an exact representation of the components on the actual pcb I have.
                • metropical
                  • Jan 2017
                  • 42
                  I think that P4 PNL_POW is a return voltage, not a source from the PS.
                  But what am I looking for and where.?
                  My time with board level stuff was on recording studio gear 30 years ago.
                  Not so familiar with this.
                  • will62
                    • Dec 2016
                    • 229
                    • usa
                    The pnl_pow voltage comes from IC2007 (AND gate). It requires ~3v from both the cpu and mcu to send the pnl_pow voltage. See pages 72 and 102 in the SM.
                    • R_J
                      • 9535
                      PNL_POW is the "control voltage for the panel 5v" All it does is switch the PNL5V ON or OFF that's it, nothing else
                      A high or low logic (3.3v - 0v) on the PNL_POW pin turns Q7907 on or off which tells Q7905 to connect the BU5V to the PNL5V
                      You have confirmed that PNL_POW is changing from 3.3v to 0v, all you need to do is check plug PE pins 3or4 (or use J7915) PNL5V and see if it changes from 0 to 5v when PNL_POW changes.
                      • metropical
                        • Jan 2017
                        • 42
                        I know this is odd, but I think I may have a different board. I don't see IC2007 on the actual board, despite what the SM shows.
                        Unless it under this heat sink, pic attached.
                        But still, when I swapped the PS, the tv worked.
                        So I don't understand why I'd be looking outside the PS.
                          So are you saying that with old power supply board the PNL_POW of PD connector shows 0V, but with new power supply it shows 3.3V?
                          • metropical
                            • Jan 2017
                            • 42
                            sorry, my post is poorly formatted.
                            P4 is 0v on the bad PS.
                            3.3v is what is stated in the SM.
                            I swapped the PS with another one of these TVs we had that failed.
                            So I now have the failed supply.
                            When I put the known good PS in the bum TV, it lit up NP.
                            That post was suppose to look columnar, but alas...
                              I do not understand, you said TV works with new board, so PNL_POW of PD connector shows 3.3V then when using the new power supply board?
                              • metropical
                                • Jan 2017
                                • 42
                                I assume so. But that TV isn't here.
                                What I'm saying is the other TV failed. I put the other PS in it and it works fine.
                                But that TV is in a different location. I now have it's failed supply.
                                It is 0v on P4.
                                • R_J
                                  • 9535
                                  It is 0v on P4.
                                  What is P4? I see plug PE and plug PD
                                  • metropical
                                    • Jan 2017
                                    • 42
                                    yes, Pin 4 on plug PD. aka PNL_POW 3.3v. I have 0v on this supply.
                                    • R_J
                                      • 9535
                                      That is because it is NOT A SUPPLY, please re-read post 11
                                      Here: Red is the BU5V volts, Blue is the panel power 5 VOLT OUTPUT, Yellow is the PNL_POW Control line.
                                        Originally posted by r_j
                                        that is because it is not a supply, please re-read post 11
                                        +10
                                        • caspian
                                          What Zener Diodes on a Linear Power Supply
                                          by caspian
                                          Dear members,
                                          I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                          In addition, I discovered that its zener diodes are defective.
                                          I can replace the burned transistors.
                                          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                          Therefore, I cannot replace the zener diodes.
                                          I do not want to test the zener diodes in a test circuit to discover their model or value.
                                          no schematics are available...
                                          05-26-2025, 12:38 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • timtrace
                                          Won't stay powered on - Sharp LC52LE700UN with RDENCA336WJQZ DPS-286AP power supply
                                          by timtrace
                                          Greetings - first post. I'm awed that a forum like this exists. It's a dream come true. I'm not even kidding.
                                          I've got a 13 year-old Sharp LC52LE700UN television that's developed a problem of powering itself off after 30-45 seconds. If I pull the mains cord and reconnect, it will come back on right away without so much as a button push...then turn off after 30-45 seconds.
                                          Service manual S37X3LC46E77U is attached to this post, as well as a front and a back picture of the RDENCA336WJQZ DPS-286AP power supply taken after completing my work.
                                          Each time that the...
                                          05-14-2020, 09:24 PM
