sharp lc32d42u power supply - DPS-178APA
  • R_J
    • Jun 2012
    • 9625
    Re: sharp lc32d42u power supply - DPS-178APA
    Yes it can be tested without a load. It is only to confirm that the power supply is turning on the panel power 5 volts. The PS-ON resistor is to turn on the main power supply (which is confirmed to work) the PNL_POW resistor is only to turn on the panel 5v
    normally the main board provides the 3.3 volts to turn on the power supply and the panel power, the resistors are to simulate the main board. The main board should not be connected when forcing on the power supply.
    • caspian
      What Zener Diodes on a Linear Power Supply
      by caspian
      Dear members,
      I have a linear variable power supply with unknown brand name that I used for voltage injection.
      Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
      In addition, I discovered that its zener diodes are defective.
      I can replace the burned transistors.
      But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
      Therefore, I cannot replace the zener diodes.
      I do not want to test the zener diodes in a test circuit to discover their model or value.
      no schematics are available...
      05-26-2025, 12:38 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
    • Dvsr
      On M-Audio AV40 active studio speaker's two zener diodes get really hot.
      by Dvsr
      Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
      I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
      After replacing the caps I started testing out the speaker. It seemed...
      09-10-2025, 10:20 AM
      07-01-2024, 06:34 AM
