Re: sharp lc32d42u power supply - DPS-178APA
Yes it can be tested without a load. It is only to confirm that the power supply is turning on the panel power 5 volts. The PS-ON resistor is to turn on the main power supply (which is confirmed to work) the PNL_POW resistor is only to turn on the panel 5v
normally the main board provides the 3.3 volts to turn on the power supply and the panel power, the resistors are to simulate the main board. The main board should not be connected when forcing on the power supply.
"Since all the other voltages are being supplied by the power supply, and you say the rest of the tv is working and the fault is on THIS power supply. Simply forcing on Q7926 will not be an issue and the tv will work because you tested proved it with the other power supply correct?
Correct.
Can I assume that this resistor test can be done without the "load" of the rest of the TV?
If so, I'd bring it to my friends shop week after next and do it there.
If not I'll get a couple 1ks from him and do under load.
But thanks so far, R_J, and I'll be in touch after I visit his shop.Leave a comment:
Disconnect the power supply from the main board and get two 1K resistors, Connect one resistor between BU5V and PS-ON and the other resistor between BU5V and PNL POW
Then check if you have all the voltages including PE pin 3,4 PNL5VLast edited by R_J; 02-06-2020, 11:55 AM.Leave a comment:
"Shorting Q7907 collector to ground will force the PNL5V ON. "
Something has changed here. The blue power LED upfront no longer lights.
I just shorted the C of Q7907 to gnd. PNL POW (P4 of PD) OV.
P3/4 of PE at 0V.
Perhaps Q7907 was failing or am I coming to the wrong conclusion?
Other Voltages are all still correct.Leave a comment:
The ONLY voltage that is not being supplied by the power supply is the switched PNL5V. This voltage comes directly from the working BU5V. The only control line for this voltage is PNL POW, It needs to be at 3.3 volts to turn on Q7907 base.
Shorting Q7907 collector to ground will force the PNL5V ON. So if the main board etc. are ok, the tv should work.Leave a comment:
PE
pin1=UR6V - 5.77
pin2=gnd
pin3=PNL5V - 0
pin4=PNL5V - 0
pin5=gnd
pin6=gnd
pin7=UR10V - 10
pin8=UR10V - 10
pin9=gnd
pin10=gnd
pin11=UR13V - 12
pin12=UR13V - 12
PD
pin1=PS-ON - 3.02
pin2=AC_DET - 3.07
pin3=gnd
pin4=PNL POW - 0
pin5=BU5V - 5
pin6=gnd
LA
pin1~5=24V yes
pin6~10=gnd
when I short Q7907 collector to ground, the red LED annunciators on the Main panel under the heat sink/cage, go off.
But the TV does not come on.Leave a comment:
What voltages are missing on the power board?
PE
pin1=UR6V
pin2=gnd
pin3=PNL5V
pin4=PNL5V
pin5=gnd
pin6=gnd
pin7=UR10V
pin8=UR10V
pin9=gnd
pin10=gnd
pin11=UR13V
pin12=UR13V
PD
pin1=PS-ON
pin2=AC_DET
pin3=gnd
pin4=PNL POW
pin5=BU5V
pin6=gnd
LA
pin1~5=24V
pin6~10=gnd
If the only voltage you are missing is on plug PE: PNL5V , short Q7907 collector to ground, this will turn on the PNL5V and the tv should work. If it does, the Q7907 could be bad.Last edited by R_J; 02-05-2020, 08:44 PM.Leave a comment:
Since I'm sure the PS is the problem, as when I swapped supplies with another of the same TV, it works.
Isn't there some point to source the problem on the power board?Leave a comment:
IC2007 pin1 is the PNL5V_ON_CPU and connects to [Y23] under the CPU.
IC2007 pin2 is the PNL_POW and connects to pin 63 of IC2002
Pins 1 AND 2 need to be high (3.3v) to get the PNL5V_ON (IC2007 pin4) to be high which turns on the panel power on the power supply.
Since the pins are hard to access I don't know how to check their voltages.Leave a comment:
trying to figure out the location.
Is there any indication in the SM pcb drawings that would indicate this heat sink. The ref point might help localize the chip.
Or remove it that I might have a look at whats hidden.Attached Filesif you find these attachements useful please consider making a small donation to the site
If you look at the service manual, it has board views, you would need to follow the trace and see where it appears on the other side.Leave a comment:
IC2007, R2004 and C2024 seem to be on the B-side (trace).
Are there test points on top I can access?Last edited by metropical; 02-05-2020, 01:33 PM.Leave a comment:
That eliminates the t-con/panel, killing the voltage. Look for IC2007 on the main board, this is the ic that controls the PNL5V_ON, I was going to say post the voltages of the 5 pins, but it seems to be a bga chip.
So check the voltage on R2004 and C2024Attached Filesif you find these attachements useful please consider making a small donation to the site
zero volts on J7915 with plug PE restored and the lvds unplugged.Leave a comment:
Hi R_J. I realize you're prolly have other things going, but when you get a chance.
Thanks,
FritzLeave a comment:
both sides behind the cage.
Ov.Leave a comment:
The lvds cable is the one between the main board and the t-con board, it must be behind shield, It is the wide 30 pin, You can also just unplug it from the main board.Leave a comment:
which is the LDVS cable? The 2 ribbons at the top of the board or those at the bottom behind the cage.?
Also, not familiar with those connectors. How do they separate?Attached Filesif you find these attachements useful please consider making a small donation to the site
So with the the wire on Q7907, you get 5 volts on J7915. I can't see what would be preventing the 5 volts for the panel from turning on, Try disconnecting the LVDS cable going to the t-con board, then with plug PE re-connected see if you get 5 volts on J7915Leave a comment:
by caspianDear members,
I have a linear variable power supply with unknown brand name that I used for voltage injection.
Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
In addition, I discovered that its zener diodes are defective.
I can replace the burned transistors.
But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
Therefore, I cannot replace the zener diodes.
I do not want to test the zener diodes in a test circuit to discover their model or value.
no schematics are available... -
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by DvsrHi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
After replacing the caps I started testing out the speaker. It seemed...4 Photos-
09-10-2025, 10:20 AM -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... - Loading...
