What Zener Diodes on a Linear Power Supply
This topic has been answered.
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Dear members,
    I have a linear variable power supply with unknown brand name that I used for voltage injection.
    Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
    In addition, I discovered that its zener diodes are defective.
    I can replace the burned transistors.
    But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
    Therefore, I cannot replace the zener diodes.
    I do not want to test the zener diodes in a test circuit to discover their model or value.
    no schematics are available for this power supply.
    Does this power supply worth repairing when I do not know the model/value of the zener diodes?
    Does the power supply fail soon if I replace the transistors but do not replace the zener diodes?
    If I must replace the zener diodes, what model/value of zener diode do you recommend for replacing all the zener diodes on the board?
    Can they all be replaced by just one model/value of zener diode?
  • Answer selected by caspian at 05-27-2025, 03:25 AM.
    eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    for most zener diodes, dmms' voltage source is too low to cause zener breakdown so it'll look like a normal diode. kind of hard to know what voltage is needed without the schematic...
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      How do you know they also failed? Usually board blackening happens if zeners fail else they don't typically fail.
      You may be okay to replace transistors without the zeners, but depends on how it's connected (schematic? or at least foil side of board?) Also what ICs are being used, LM723's?
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        there is no visible sign of damage or burning on the zener diodes and the board.
        I tested the Zener diodes on board using the diode mode of multimeter. however, I do not know why my multimeter struggles to apply voltage on some of the zener diodes. On one direction, it shows infinite resistance. but on the other direction, sometime it shows 0.6v and sometimes it shows infinite resistance.
        I used to use this power supply for voltage injection on laptop mainboards. I do now know why Q1 and Q2 got shorted.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          • caspian
            • Oct 2015
            • 1591
            • Laptop
            ok, so the zener diodes are fine.
            Thanks @eccerr0r
            • Dvsr
              On M-Audio AV40 active studio speaker's two zener diodes get really hot.
              by Dvsr
              Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
              I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
              After replacing the caps I started testing out the speaker. It seemed...
              09-10-2025, 10:20 AM
              03-31-2024, 02:12 PM
            • прямо
              Help me understand this linear supply circuit.
              by прямо
              Was looking for a simple CV CC linear supply to build and came across this one.
              https://oshwlab.com/svalentin544/lab...ply-0-38v-0-5a
              I etched the provided board design and populated it.
              The output voltage adjustment works.
              The output current adjustment however, doesn't behave like I expected it to be. If PR2 is going clockwise, the output voltage decrease. Adjusting R5 has no effect.
              I don't have a load connected to the output at all.
              ​​​Can someone explain how the current adjustment work?...
              02-17-2025, 11:09 PM
            • sumilumi
              700mv ripple on Akai Sampler linear supply
              by sumilumi
              Hi fellow troubleshooters. This is my first post on badcaps. I've recently setup an electronics workbench. i'm also building a studio with old equipment bought faulty at low cost.
              I've been into electronics since the mid 80's and particularly in the last few years though only getting hands on with repairs now. My knowledge gaps are significant so I'll be posting here to seek guidance advice and general practical applied learning.
              On my bench today is an old ca. 1993-95 Akai hardware sampler. This runs on both a linear and Smps supply. Both are getting on in age and ripple...
              01-02-2022, 10:12 AM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
