Sony KDL-55EX620 10 blinks
Re: Sony KDL-55EX620 10 blinks
So your sticker numbers match on both mainboards?Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND IT'S ALWAYS IGNORED SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS.Comment
please don't disturbed conversation we want to to solve this 10 blinking error..
resolder the 2EPROM from your old ( original ) board to the replacement oneComment
Both boards are A184571B.
I have a CH341A programmer with clips but there is no profile for IC2500 S-24CS02AFJ-TB-G listed in the service manual. Tried something close but couldn't read anything off the old board.
The schematic shows this chip interfacing only to the VGA connector. Little hesitant on swapping this IC since I may want to return the replacement board.Last edited by neilc6; 12-28-2019, 06:19 PM.Comment
Good call, I think diah's on the wrong path yet again. If the boards are a match there's no need to change out IC.Last edited by nomoresonys; 12-28-2019, 06:26 PM.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND IT'S ALWAYS IGNORED SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS.Comment
https://www.extron.com/article/uedidNever stop learning
I strongly suspect you need to match the model/panel type since this board is used in multiple models. The supplier I bought this from (they had 5 in stock) just groups them together since they have the same part number. It's a crap shoot if you get a compatible one.
From the service/training manual, 6 blinks is backlight error and there are 24 different panel options in the service menu. For my model, there are still two different panels.
On another note - Netflix is no longer supported on this model from Dec 1 2019 adding to the list of removed apps which includes both YouTube and Amazon Prime.Last edited by neilc6; 12-28-2019, 07:00 PM.Comment
https://www.badcaps.net/forum/attach...8&d=1577566778
So what P/N number did you go by, the P/N PCB assembly as printed on the sticker?Never stop learning
Part number on sticker is A184571B.
Didn't order from shopjimmy but they only show one main board part number.
https://www.shopjimmy.com/sony-a-181...e-required.htm
What worked for me upgrading the firmware was turning on the TV, confirm green and amber flash, and then plugging in the USB drive. Flashed red and amber when complete after a couple of minutes but then the red led blinked instead of restarting.Last edited by neilc6; 12-28-2019, 08:21 PM.Comment
Your panel number matches one of the two in your sj link?Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND IT'S ALWAYS IGNORED SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS.Comment
I still cannot find error code for 10-blink in the service manual or the training manual for this chassis.Never stop learning
Panel is LTY550HJ0301. The shopjimmy link has 46" panels.
i used method of resetting it by make bridge wire on pin 5 & 6. plug the tv on count 1 2 plug out - remove the bridge from standby go direct to service menu.
for this we don't use the knob switch on/off on the TV. just use RCComment
Seems that you need to reconfigure thru service menu, did you try display,5,volume down,power?Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND IT'S ALWAYS IGNORED SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS.Comment
I don't know where Diah wants to go, how can a VGA edid eprom to block the picture from appearing and end in protection? Don't seems logical, the screen config can't be bad as you have seen a picture for short. With the help of connector's markings or srv man. force the backlight on so we see if i' m wrong. And members please use commas, the reading is too difficult whithout...Comment
The tv won't stay on to enter the service menu. Will flash for a second and blink error code with on button or service mode sequence. Get the same error code even with the backlights disconnected. Before the firmware upgrade, I was able to have the backlights stay on for 10 to 15 seconds after the startup Sony logo but it never completed booting. After the update, it shuts down right away.Last edited by neilc6; 12-29-2019, 04:33 PM.Comment
by shahnldGood Day.
I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite... -
by NicktronicHi all,
I have the subject TV and it will work normally sometimes but suddenly go black and give the 2 red blinks blink code. When this happens, I check the power supply board voltages and all I have is the Standby 3.3V and BL_ERR 2.2V. When it's working normally, all power supply board voltages look normal and stable. I've checked the backlights with a tester and they all test good. I've also read that the 2 red blinks is a faulty power supply board, so could it be throwing up an erroneous BL_ERR?
Any Sony experts out there that can help??... -
by x_orange90_xI just got this today and it has the infamous 6 blink code. I've read it's quite possibly bad backlights, and I intend to check them soon. However, I was just curious if the Sony logo should it's shouldn't be appearing briefly between powering on and the light starts flashing. I've read at least one other person had the logo flash quickly, but mine does not show anything at all, not even a flicker. The green light comes on and after about 5 seconds the red light flashes. So I'd expect in this 5 seconds to see the logo. This leads me to believe it could be a power supply issue.
I... -
by dominik0801Hello guys.
Today I got this TV for free, the friend included a "new" (used) TCON with it, since he told me, that doesn't work either.
With the stock TCON, this TV turns on, stays on, but the screen only has 5 RED vertical lines on it, and that's it.
Backlight stays on and is fine.
With the "new" TCON, the TV turns on, shows SONY logo, some spinning circles, then the TV goes blank, and the stand-by LED is blinking 5 times, won't react to anything.
I have read some forums, where it's been told that the part number is not always enough... -
by chrisl32Hi,
It is about a Sony KDL-46EX500 that was struck by lightning.
I did not see any visual damage on it.
An internet provider box and the Ethernet port of an AppleTV were also out of order.
My following remarks refer to this schematic ; https://www.badcaps.net/forum/attach...2&d=1378923377
posted by https://www.badcaps.net/forum/member.php?u=16669.
Thanks to him :-)
There was nothing on screen, and after a few seconds, it gave the 2 blinks code.
As I had no 394V on the C6516 capacitor; I decided... - Loading...
