when i turn on, Philliips TV is not on
  • Nish
    • Sep 2013
    • 124
    Re: when i turn on, Philliips TV is not on
    I put 1k resistor to connect P-ON-H1 to AL+5V.
    Now reading
    C912 = 13.40
    C906 = 18.96
    C951A = 5.56
    Across ZD907 = 1.30
    No voltage at output of IC902
    • R_J
      • 9625
      When you add the 1k to turn on the power supply, does the voltage on ic902, pin1 change? this is the ENable pin for the regulator, If it is changing (logic high) and you still have no output from ic902, either the ic is bad or there is a short on the output. If the ouput voltage is 0 volts I would suspect the ic, if there is 1~2 volts, It could be too high a load. as ic801 and ic601 have 10Ω resistors in there VCC lines.
      • Nish
        • Sep 2013
        • 124
        Before install 1k resistor
        PC902
        Pin4 = 16.22
        Pin3 = 15.55
        C906 = 16.20
        After 1k resistor install
        PC902
        Pin4 = 19
        Pin3 = 18.55
        C906 = 19
        Output voltage of IC902 = 0.053v and goes to 0v right away.
        • R_J
          • 9625
          Looks like the regulator is bad, It should output around 15~17v when ENable is high.
          • Nish
            • Sep 2013
            • 124
            I try to buy the regulator. I couldn't find this ic. I have attached the picture.
            • R_J
              • 9625
              You can order them from China. They seem to be a custom part number but are likely made by Texas Instruments, and might be a TPS7A4501DCQR or TL1963ADCQR I have not tried any of these substitutes.
              • Nish
                • Sep 2013
                • 124
                IC902
                Pin4 = 16.42
                Pin5 = 1.27
                IC601 PIN12= 16.24
                • R_J
                  • 9625
                  IC601 provides about 17v internally. This is a low current voltage and needs to be suplemented by IC902 for the ic to work.
                  IC902 supplies the VCC voltage for IC801, pin12 and IC601, pin12 and also turns on Q802, which turns on Q800, which tells both IC801 and IC601 to start.
                  I suspect if you replace the regulator ic, the power supply could be close to being fixed.
                  • Nish
                    • Sep 2013
                    • 124
                    IC801 pin12 = 16.18v
                    IC601 pin12 = 16.24v
                    Q802 =0.659v
                    Q800 = 0v
                    I will replace R818 and see
                    • R_J
                      • 9625
                      What is the point of replacing R818? Why do you think they have the regulator ic in this circuit?
                      • Nish
                        • Sep 2013
                        • 124
                        When I measure resistance, I did not get resistance. I thought bad resistor.
                        • Nish
                          • Sep 2013
                          • 124
                          What should I do?
                          • R_J
                            • 9625
                            Originally posted by Nish
                            What should I do?
                            Replace the regulator ic! The chances of that 10K resistor being bad is next to imposible.
                            Again: Why do you think they have the regulator ic902 in this circuit?
                            • Nish
                              • Sep 2013
                              • 124
                              To supply voltage to IC801 and IC601. That's what I think.
                              • R_J
                                • 9625
                                That is correct. So if the INPUT has (19v) and the enable pin is high (18.5v) and the OUTPUT is 0 volts, (and the output line is not shorted to ground) what could be wrong.
                                • Nish
                                  • Sep 2013
                                  • 124
                                  Should be the regulator IC902 is not functioning.
                                  But the IC902 pins are reading the below voltage.
                                  IC902
                                  Pin1 = 2.527v
                                  Pin2 = 19.19v
                                  Pin3 = 0v (gnd)
                                  Pin4 = 16.24v (output)
                                  Pin5 = 1.29v
                                  Pin6 = 0v (gnd)
                                  Is this IC not working? I am confuse.
                                  • R_J
                                    • 9625
                                    IC902
                                    Pin1 = 2.527v
                                    Pin2 = 19.19v
                                    Pin3 = 0v (gnd)
                                    Pin5 = 1.29v
                                    Pin6 = 0v (gnd)
                                    I was going by what you reported earlier in post# 143
                                    and post#141
                                    That is why I suspected the regulator, so it IS working ok.
                                    So you should now have PANEL+24V and P-ON+12V
                                    • Nish
                                      • Sep 2013
                                      • 124
                                      I was going by what you reported earlier in post# 143 and post#141 That is why I suspected the regulator, so it IS working ok.
                                      Ok sorry about that. I mislead you.
                                      No I do not have PANEL+24V and P-ON+12V at the connector.
                                      I have attached the picture of voltage now.
                                      • Nish
                                        • Sep 2013
                                        • 124
                                        Is there anything I can check please?
                                        • R_J
                                          • 9625
                                          The only voltage that points to a line is the 350v, That tells be that the pfc circuit and IC801 is working. The 16.24 seems to be the vcc supply, so that is correct. Is the 1.1 volts for pin 4 or pin5 of IC601?
                                          I have no idea where you measured the 87.2
                                          Looks like the IC601 circuit is not working, check the resistance of R618(15Ω), R617(51Ω) and R620(51Ω) and [R52 1](15Ω) If they are ok. Check the voltage on pins 11,14 & 15, Also is there any voltage on D601 cathode?
                                          I looked closer at the connections on T601, The connections on pins 1 & 2 don't look that good, Remove the old solder, clean up the trace and rivet and resolder them
                                          • rabsonnjala
                                            LENOVO IDEAPAD 100 works only on bench power supply
                                            by rabsonnjala
                                            Hie I have a Lenovo laptop
                                            Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                                            it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                                            below are my readings
                                            with the original charger only
                                            JBATT1
                                            PIN1 0.22V
                                            PIN2 0.22V
                                            PIN3 0.45V
                                            PIN4 0.45V
                                            PIN5 O.43V
                                            PIN6 0V
                                            PIN7 GND
                                            PIN8...
                                            11-20-2021, 08:32 AM
                                          • zaurus81
                                            HP 15-cb028nl (dag75ambad0 rev. d) no charge battery
                                            by zaurus81
                                            Hi all, I have a HP 15-cb028nl (dag75ambad0 rev. d) that turns on but does not charge the battery. The laptop arrived with the super I/O (ITE IT8987E BXA) burned. After replacing the EC, it turns on but does not charge the battery. Below are the voltages on the pins of the bq24738h, with and without the battery inserted:
                                            WITHOUT BATTERY WITH BATTERY
                                            PIN1 (ACN)= 19.76 V PIN1 (ACN)= 19.76 V
                                            05-06-2025, 09:48 AM
                                          • kalilinux25
                                            Lenovo Thinkpad T410 no power
                                            by kalilinux25
                                            DEVICE: Laptop
                                            Model: lenovo thiinkpad t410
                                            Board Id: 09A33-3 48.4FZ09.031
                                            NZM1H-8
                                            ISSUE: NO POWER
                                            From the first mosfet 20v is not passing through, pin 4 has 19.5v and the first mosfet is a P-CHANNEL mosfet (SI7121DN) i think the pin 4 should be lower to active the 1st mosfet to allow the 20v to pass to second mosfet ive check all for shorting in the board , i did;nt find in rails, so ive check the schematic and im suspecting that, my Q61 is faulty due to its pin 1 is 0.47ohms? im not pretty sure, hope someone can help me figure out this issue.
                                            07-13-2025, 07:56 AM
                                          • DrFalken
                                            Honor MagicBook X 16 mod. BRN-F56 dead
                                            by DrFalken
                                            Good morning!
                                            A customer just brought in an Honor MagicBook X 16 mod. BRN-F56, motherboard P/N Fermi_MB NB6269A_MB_V4, not working (no power LED, no charging LED, nothing)
                                            He said he had been using an aftermarket power supply for a while, but noticed that it suddenly stopped charging and when the battery was completely dead the laptop would not turn on, even with the original (working) power supply.
                                            On the power connector, on the motherboard side, I measure 20V.
                                            With the thermal imaging camera I found a component labeled 2920J (TSOP5) that, when I supply power, increases...
                                            01-29-2025, 03:41 AM
                                          • danro
                                            Owon HDS2202S oscilloscope
                                            by danro
                                            I have this OWON HDS2202S oscilloscope that worked fine until it was used with the wrong probes mounted in the wrong place.
                                            It is not completely dead, it still fulfills some functions. I opened it and found some damaged components inside. I have identified the rest but I cannot identify this IC. I don't think I can find the diagram, but can someone help me identify this component?
                                            It seems to be an LDO regulator. I identified it like this:
                                            Pin1 - Vin
                                            Pin2 - GND
                                            Pin3 - ? (connected with pin1)
                                            Pin4 - ADJ ? (resistive divider between Vout and...
                                            07-25-2024, 10:46 AM
