LG 65UH5500-UA Backlight flash on first power up only
  • jason123
    • Oct 2015
    • 1083
    Re: LG 65UH5500-UA Backlight flash on first power up only
    Yes the 13.2 V is 10.5 v when TV Is off. When the STB is ON (3.4 V) the voltage jumps to 12.62 v (when the back lights happen not to turn on) and 13.34 v when it powers up properly.
    80 v is 66.4v when TV is off and ~82V when STB is 3.4 v
      So the power supply is putting out the Voltages like it should, so the LED drivers board should be working as long as the LED driver board has all the control signals for the backlights to be on.
      • jason123
        • Oct 2015
        • 1083
        I got derailed by the large caps having 385v all the time... never seen that before
        If i didn't misunderstand you #40, if STB is 0 v, then PFC Should be off. So why would large caps have 385v?
          That is why you need to check pin 22 of the SMPS/PFC IC, but as I indicated it may be stuck on, it the least of the problem right now, you need to find out why you do not have backlights.
          • jason123
            • Oct 2015
            • 1083
            Ok, so
            When TV is on (STB = 3.4V)
            LED1+ to LED6+ are reading 88.25V
            LED1-, LED2-, LED3-, LED4- & LED6- are reading 42.26 V
            LED5- is reading 44.6 V
            When TV is off (STB = 0 V)
            LED1+ to LED6+ are reading 66.2V
            LED1-, LED2-, LED3-, LED4- & LED6- are reading 20.24 V
            LED5- is reading 22.3 V
            Is that meaning string LED5 has defect? I'm measuring on the back of the connector (Side that is directly connected to LED strips so no connector "connectivity issue" it seems
              • 12276
              • U.S.
              #46
              Not sure, maybe one weak diode in backlights??
              • jason123
                • Oct 2015
                • 1083
                Very odd.. Brand new set of LEDs. With a tester, they all light up..
                I'm going to try replacing the LED driver board - Can't think of anything else.
                • jason123
                  • Oct 2015
                  • 1083
                  So this TV has 24 strips, each with 5, 3-V LEDs. There are 6 supplies on the LED Driver board, so each supply should be providing at least 60 V Differential for the Strips to turn on (I'm assuming each supply is driving 4 strips = 20 LEDs)
                  The fact that I'm getting only ~40V differential tells me the LED driver is not doing its job?? Am I on the right track?
                  Is there another control signal that tells the LED Driver to turn on other than the STB that's going to the power supply? Or is the Power supply turning the LED driver board on by simply turning on the 80V rails (From 60 to 88?) I see PWR_ON and DRV_ON on the Driver LED coming from Main board.
                  Just trying to determine if this is a LED Driver board issue or still a power supply issue and I simply got a bad power supply this time too (2 bad supply boards)
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    #49
                    Swap LED1+ and LED1- with LED5+ and LED5- and see if the slightly different voltage reading moves.
                    • jason123
                      • Oct 2015
                      • 1083
                      Ok, further measrement on the LED Driver board yielded something intersting:
                      The PWR-ON (pin 1 on CN402) has 3.45 V when I turn TV ON. DRV-ON (Pin 11) however has only 1.5 V. Momentary contact between these 2 pins (Pin 1 and Pin 11) turns the Backlight on and keeps it on.
                        PWR-ON is the PS-ON for the power supply boar, the LED driver board is used for routing that signal to the power supply board, it is not used by the LED driver circuit.
                        For the backlights LED driver board to works it needs DRV-ON (BL-ON) and the P-DIM signal.
                        So you are able to force on the Backlights by using the PS-ON signal, at this point the image, sound, and all other function of the TV are OK?
                        What do you get at the P-DIM pin?
                        What is the Voltage reading between the two leg of cap C409?
                        • jason123
                          • Oct 2015
                          • 1083
                          P-DIM is pin 12 and is not accessible - I'll get a pair of sharper tip leads and report shortly.
                          C409 reads 88.x V
                          Traced DRV-ON back to the motherboard - seems something has changed, either resistors changed value from nominal (not labeled - 603 package) or leakage in the path is higher, but the main board generates 3.3 V, but after resistor networks by the time it gets to the LED Driver Pin 2 of OZ9906 (Chip Enable) it's down to 1.5 V - not sufficient "ON" logic.. given that I don't have 603 resistors and I can't see the darn things anyway, I replaced one of the series resistors (there are several between the main board and the LED Driver) with a blob of solder and that did the trick.. so far so good.. LED Driver is seeing 2.9 V on the EN pin of the controller - Backlight comes on..
                          Now.. back to the weird problem that appeared on 2 power supply boards - why are the large caps seeing 385V always... PFC not operational on 2 boards ??? very odd
                            P-DIM must be present since the backlights are on and you can dim the backlights at this point.
                            The PFC circuit, need to look at pin 22 of the SMPS/PFC IC as suggested.
                            • jason123
                              • Oct 2015
                              • 1083
                              Pin 22 of the PFC IC reads 5.53 V when TV is off.. jumps to 8.6 when it's turned on.
                                That must be measurement error. Did you use the chassis as the GND for the meter? You need to use the negative leg of the main filter cap as the ground for the meter because you are making measurement in the hot side.
                                See spec sheet of the IC on the page that I pointed out to for what the Voltage should be on pin 22.
                                • jason123
                                  • Oct 2015
                                  • 1083
                                  So not the cleanest solder job...but pin 22 connects to cap then to hot gnd, so i soldered across the cap. Just measured again from pin 22 referenced to large cap gnd and same results.
                                  I see what you're referring to on page 34.. table 5 on page 32 lists range for that pin as -1.4 to 12 v..(abs max maybe)...used in a different mode? This pin doesn't seem to be driven by a voltage.. just has a cap to hot gnd?
                                    It's page 34 (see my post #40).
                                    Enable input (pin SSHBC/EN).
                                    There may be trace going under the IC.
                                    I cannot see how you can have the same Voltage readings using the chassis GND and using the Hot side ground.
                                    • jason123
                                      • Oct 2015
                                      • 1083
                                      Both measurements are referenced to hot gnd. First reading was pin 22 references to the pad the capacitor is connected to, which is shorted to negative lead of large cap. Second measurement to confirm for you was pin22 referenced to negative lead of large cap.
                                      I tried continuity check between pin 22 and the traces exiting top and bottom of chip and there doesn't seem to be a connection
                                        Pin 22 is the ENABLE pin so it has to be controlled some how, and it does change state, but I cannot see how the control Voltage, 5.53V/8.6V can be that high either..
                                        At this point you will have to find the schematic to really find out what is going on.
                                        • jason123
                                          • Oct 2015
                                          • 1083
                                          Section 7.8.8.1 (page 26) explains the function of this pin when used as soft start. I think the voltages i am reading are as intended. Don't you think?
                                          • triplefour
                                            TCL 75S421 has sound but no backlight not even a flash
                                            by triplefour
                                            TCL 75S421
                                            PSU BOARD: 40-L402H8-PWD1CG
                                            it shows not even a flash of backlight when powering up.
                                            but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                                            testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                                            unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                                            i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                                            with mb connected, PSON...
                                            11-17-2023, 09:54 PM
                                          • Superbee_dad
                                            Sharp 80” long short flash backlight error - Help
                                            by Superbee_dad
                                            Hello Sharp TV experts
                                            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                            01-24-2025, 11:51 PM
                                          • ekozeko333
                                            [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                            by ekozeko333
                                            I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                            🔥 The Problem Started After Suspected ESD/PD Fault
                                            I experienced a power issue or ESD event through a USB-C charger
                                            After that, the NX20P5090 power switch was visibly burned and was replaced
                                            Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                            🧠 What I’ve Done So Far
                                            Flashed...
                                            06-21-2025, 02:48 AM
                                          • corrize
                                            Nikon D800 camera - flash don’t work and capacitor don’t charge
                                            by corrize
                                            Hello, I'm stuck in troubleshooting…
                                            The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                            In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                            When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                            10-01-2022, 10:02 AM
                                          • crozoki
                                            Philips 65PUS6554/12 one time backlight flash
                                            by crozoki
                                            Hello
                                            I have Philips 65" TV (65PUS6554/12).
                                            Problem is when turn on tv backlight flash only one time for about 1 second then turns off and display is dark but sound is there.
                                            Sometimes TV turns on and work with no problem, had backlight and picture, but mostly Tv wont turn on backlight. Any idea where to start looking?
                                            Power board TPV 715G9187-P01-008-001S
                                            Main Board 715G9907-M01-B03-005K...
                                            09-03-2022, 05:47 AM
