LG 65UH5500-UA Backlight flash on first power up only
  • triplefour
    TCL 75S421 has sound but no backlight not even a flash
    by triplefour
    TCL 75S421
    PSU BOARD: 40-L402H8-PWD1CG
    it shows not even a flash of backlight when powering up.
    but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
    testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
    unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
    i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
    with mb connected, PSON...
    11-17-2023, 09:54 PM
  • Superbee_dad
    Sharp 80” long short flash backlight error - Help
    by Superbee_dad
    Hello Sharp TV experts
    Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
    > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
    > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
    01-24-2025, 11:51 PM
  • ekozeko333
    by ekozeko333
    🧠 What I’ve Done So Far
    Flashed...
    06-21-2025, 02:48 AM
  • corrize
    Nikon D800 camera - flash don’t work and capacitor don’t charge
    by corrize
    Hello, I'm stuck in troubleshooting…
    The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
    In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
    When I press the flash button, it's detected by the system, flash icon appear on LDC display....
    10-01-2022, 10:02 AM
  • DanPoka
    by DanPoka
    02-15-2025, 05:05 AM
