Sony KDL-46ex520
    • 12331
    • U.S.
    Re: Sony KDL-46ex520
    Discharging capacitors with a resistor, can be done in circuit: https://www.youtube.com/watch?v=2TcVZ2opuNc
    • diif
      • Feb 2014
      • 6978
      • England
      I believe this is your service manual.
        • 12331
        • U.S.
        You are sure that you have 5 blinks and not 6?
          • 12331
          • U.S.
          According to service manual, 5 blinks indicates tcon error, page 24.
          • Global Safari
            • Nov 2019
            • 32
            Hi
            Yes 5 blinks. No 12 volts to the T Con board.
              • 12331
              • U.S.
              #26
              5- times blinking Check PANEL_VCCat pin 1 of CN6001 on the B* Board which is the mainboard, page 24 service manual.
                https://assets.shopjimmy.com/media/c...78-b-top_1.jpg
                Did you check the fuses F6001, 002, 003 on that main board by the LVDS connector?
                I suspect F6001.
                • Global Safari
                  • Nov 2019
                  • 32
                  Maybe take the powerboard out and check underside for bad/cold solder joints, sometimes they look ok but can be loose, look closely at anything on a heatsink and the transformer legs joints, they take the most abuse, be very CAREFUL not to touch the HOT parts, they can hold a BIG charge for quite a while.
                  Hi
                  That's where if all started.. no 12 vdc at that test point.
                  Kinda pointing to the main board. The fuses on this board are
                  Very small. Gonna just replace the main board
                    • 12331
                    • U.S.
                    #29
                    I would have felt better about it being the mainboard if we could have proven the backlights and powerboard somehow, those fuses are small but pretty easy to check.
                    • Global Safari
                      • Nov 2019
                      • 32
                      I can check them tomorrow. Not sure which ones I need to check.
                        • 12331
                        • U.S.
                        #31
                        Those 3 little ones in Buds post #27, check the link there's a clear picture there.
                        • Global Safari
                          • Nov 2019
                          • 32
                          Will do ..thanks.
                          • Global Safari
                            • Nov 2019
                            • 32
                            [QUOTE=budm;928797]https://assets.shopjimmy.com/media/c...78-b-top_1.jpg
                              • 12331
                              • U.S.
                              #34
                              And?
                              • Global Safari
                                • Nov 2019
                                • 32
                                No chance last night.. will do after work tonight.
                                • Global Safari
                                  • Nov 2019
                                  • 32
                                  Okay..just got home from work..I have put a red square around the 3 fuses in question.I wanted to make sure these are the 3 fuses in question.
                                  • neilc6
                                    • Nov 2015
                                    • 1550
                                    F6001 is below the silkscreen. F6002 and F6003 have arrows pointing to them.
                                      Those are caps.
                                      See the fuses as marked in the picture.
                                      • Global Safari
                                        • Nov 2019
                                        • 32
                                        Gotcha..will check tonight...gotta make dinner.Will reply back with voltages when I get a chance tonight.
                                        • Global Safari
                                          • Nov 2019
                                          • 32
                                          Gotcha..I will check tonight..thanks again!! Are those replaceable?
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • delpiero3
                                            Sony Vaio SVS MBX-261 board failure
                                            by delpiero3
                                            Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
                                            Nevertheless, let's say, i don't come as a total beginner.
                                            I have this old laptop, which suit perfectly my needs, with the...
                                            10-29-2024, 06:16 AM
                                          • huj3r
                                            Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
                                            by huj3r
                                            Hi there!
                                            I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
                                            Photo of the situation after the black shadow dissipates:
                                            After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
                                            I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
                                            > This indicates HFR Communication error. [ HFR Communication...
                                            08-15-2023, 10:55 AM
