Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
  • huj3r
    • Aug 2023
    Hi there!
    I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
    Photo of the situation after the black shadow dissipates:
    After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
    I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
    > This indicates HFR Communication error. [ HFR Communication error ] Mouton (IC5505) micro (on BGC board) is communicating with T-con board. Check above and replace BGC board or LVDS harness (between BGC board and T-con board).
    This is a map of the TV circuitry:
    I tried a different board and I get the same identical pattern, so it's not the BGC board.
    What should I do now? I tested all pins of the LVDS harness (photo here of a different model, but harness looks the same) and noticed that the last two pins are shorted e.g. 0 resistance between them. I do not have another cable to verify, nor the pinout, so cannot tell whether it's normal not.
    Any help appreciated, thanks!
  • nomoresonys
    • 12307
    • U.S.
    Re: Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness pro
    Test the tcon, lots of videos of tcon testing on youtube, if one doesn't seem very good go to the next.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • delpiero3
      Sony Vaio SVS MBX-261 board failure
      by delpiero3
      Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
      Nevertheless, let's say, i don't come as a total beginner.
      I have this old laptop, which suit perfectly my needs, with the...
      10-29-2024, 06:16 AM
