Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
  • huj3r
    • Aug 2023
    Hi there!
    I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
    Photo of the situation after the black shadow dissipates:
    After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
    I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
    > This indicates HFR Communication error. [ HFR Communication error ] Mouton (IC5505) micro (on BGC board) is communicating with T-con board. Check above and replace BGC board or LVDS harness (between BGC board and T-con board).
    This is a map of the TV circuitry:
    I tried a different board and I get the same identical pattern, so it's not the BGC board.
    What should I do now? I tested all pins of the LVDS harness (photo here of a different model, but harness looks the same) and noticed that the last two pins are shorted e.g. 0 resistance between them. I do not have another cable to verify, nor the pinout, so cannot tell whether it's normal not.
    Any help appreciated, thanks!
    • 12323
    • U.S.
    Re: Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness pro
    Test the tcon, lots of videos of tcon testing on youtube, if one doesn't seem very good go to the next.
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • joliver82
      Sony XR-65A95L no power due to logic board issue
      by joliver82
      Hi guys!
      I'm trying to repair a TV that a friend gave me recently. Lightning struck next to his house and broke the TV apart from more electronic devices.
      First of all I've checked the power supply and it works as expected. I removed the logic board and shorted the 3.3v standby output to TCON_ON and POWER_ON and every voltage was generated as expected (12v and 25v for logic board and 32v for TCON).
      When trying to boot the TV normally (having the board connected), the TCON_ON signal is not generated from it which made me think there's some issue in the logic...
      11-26-2025, 04:57 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
