Vizio M651d-A2R won’t turn on
  • Hornnumb2
    • Feb 2011
    • 218
    I can get it to turn on holding down power button for 30 seconds, but if turned off won't come back on. Power board is DPS- 200PP -190 and has 5v standby and 24v. I do get 385v at the long capacitors and none of the caps look bad. When it's powered I don't see any dark spots like bad backlights. Any suggestions to check next. Thanks
  • Hornnumb2
    • Feb 2011
    • 218
    Re: Vizio M651d-A2R won't turn on
    Seems like a main board issue, aren't the voltages good on power supply?
      But where are the control Voltages readings?
      • nomoresonys
        • 12330
        • U.S.
        Need to test them all, #3 below.
        • Hornnumb2
          • Feb 2011
          • 218
          Here are the results
          • Hornnumb2
            • Feb 2011
            • 218
            Let me know if it’s too small and I will type it out.
            • R_J
              • Jun 2012
              • 9623
              Have you checked the voltages on the LED driver board? also check the fuses on that driver board. I suspect you could have a few bad (likely shorted) led's causing the led driver board to over current shut down. It only takes a couple bad leds and you likely won't see them through the lcd screen.
              • Hornnumb2
                • Feb 2011
                • 218
                should I be able to unplug the leds and get it to start up?
                • R_J
                  • Jun 2012
                  • 9623
                  If you unplug the leds, it will likely detect an open circuit and also shut down. The driver board monitors the current the led strings draw and if it is out of the set limit it will trigger a shut down.
                  • Hornnumb2
                    • Feb 2011
                    • 218
                    I haven’t been able to get it back on to test led voltage on board yet, it’s hit and miss when it decides to start up. I did order one of those led tester and get these reading with them unhooked. With the red on pin 1 and ground going down the line 2-4 I get 55.2 and the same going the other way. I will still keep trying to get it to start where I can check those while running.
                    1: VLED2 +
                    2: FB2-4
                    3: FB2-3
                    4: FB2-2
                    5: FB2-1
                    6: FB1-4
                    7: FB1-3
                    8: FB1-2
                    9: FB1-1
                    10: VLED1 +
                      You'll keep black probe of the meter on the chassis, put red probe on pin 1 then turn on the TV to see how high the Voltage jumps up to then wait 10 seconds to see what it goes down to, then turn off the TV and the repeat the same test on the other 9 pins.
                      • Hornnumb2
                        • Feb 2011
                        • 218
                        I am using one of these, right now it won’t start up to test voltage. https://www.shopjimmy.com/sid-gj2c-l...ght-tester.htm
                          OK, I thought you are testing the LED driver Voltages.
                          You are trying to test each LED sting with the LED tester.
                          You will pull the LED connector off the power supply board then out red robe on the connector (that goes to the LCD panel) the VLED1+, then use the black probe to test each FB1-1, FB1-2, FB1-3, FB1-4.
                          Do the same with LED2+and each one of the FB2-1, FB2-2, FB2-3, FB2-4.
                          Basically you are testing 8 LED strings.
                          • Hornnumb2
                            • Feb 2011
                            • 218
                            That’s what I did and get the same reading across all sets. 55.2. So does that lead me to believe that if I had a bad led or two some readings would be different?
                            • budwich
                              • Jul 2015
                              • 3097
                              unless there is some thing very "different" in the design, there is something strange with the measured results for pin 11 and 12 (BL) on cn202. Remeasure to ensure that the values are correct. Further look closely at the board / connector to see what the difference is. I would expect any "labelled point" to be the same for the same label.
                              • nomoresonys
                                • 12330
                                • U.S.
                                12 looks to be bl-on/off, 11 and 14 don't appear to be labeled.
                                  Can I see the pictures off the whole backside of the TV showing all the boards?
                                  I looks like the main board is connected directly to the LED driver board so the BL-ON and Dim controls are not routed to the power supply board.
                                    You also need to do the test on post 11 using Volt meter.
                                    • Hornnumb2
                                      • Feb 2011
                                      • 218
                                      Haven't been able to get to start again yet but her are some photos.
                                        https://assets.shopjimmy.com/media/c....d01-top_1.jpg
                                        I cannot tell from the picture of the whole backside of the TV to see where CN1 of the LED driver board go to, same for the CN5 of the LED driver board
                                        Picture is not straight shot so it is hard to see which cable to where.
                                        And right now you no longer get any Voltage at VLED1 +, VLED2 + when toggle TV on and off?
                                        • Mulp
                                          VIZIO M65-C1 Does Not Turn On
                                          by Mulp
                                          Hi All,
                                          I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
                                          When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
                                          I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here....
                                          01-13-2024, 09:57 PM
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • Yanleb
                                          Vizio M70-D3 4K with dark spots backlight issue
                                          by Yanleb
                                          I have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
                                          On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
                                          I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've...
                                          03-22-2022, 01:06 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                        • robante15
                                          Acer Aspire 4520 won't turn on after reboot
                                          by robante15
                                          Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                          It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                          The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                          If I remove the...
                                          04-06-2024, 06:50 PM
