Backlights but no picture - No 12v to Tcon board
  • Stuckster
    • Oct 2019
    • 40
    First time poster.
    Hoping to get some help troubleshooting my 65" TCL.
    Model: U65E5800FS (AUS)
    D65A620U (China Equivalent)
    Symptoms: Backlight but no picture/display.
    I have already determined:
    - Tcon board not receiving any 12V.
    - Mainboard only outputting 2.6v to audio/speakers
    - Replacement PCB (no change)
    - Replacement Tcon board (no change)
    - Voltages from PCB to Mainboard (with TV on) read
    1. VPWR 23.6v
    2. VPWR 23.6v
    3. GND 0v
    4. VPWR 23.6v
    5. GND 0v
    6. GND 3.2v
    7. VSTB 3.3v
    8. 3DEN 1.0v
    9. GND 0v
    10. P/O 3.2v
    11. PDIM 3.2v
    12. BL ON 3.2v
    Interestingly there is doesn't seem to be any 12V going to or from the PCB to the mainboard. The panel has a dedicated LED driver module which is receiving voltage to turn on the backlights. But where is the 12v for the Tcon board meant to come from?
    Pics attached.
    Any help would be much appreciated.
    I need to be 100% certain which board is faulty before I outlay money to replace it. I'm in Australia and unlike in the US, with shops like shopjimmy.com, spare parts are quite expensive to source privately. eg: $300 for a mainboard.
    cheers
  • neilc6
    • Nov 2015
    • 1550
    Re: Backlights but no picture - No 12v to Tcon board
    With tv unplugged, disconnect ribbon cable from tcon to panel one side at a time and see if tv powers up one side. But if you're not receiving 12V to the tcon, its usually switched from the main board.
    • Stuckster
      • Oct 2019
      • 40
      Here is a pic of the Mainboard without the heatsink cover.
      • Stuckster
        • Oct 2019
        • 40
        Thanks. Tried what you suggested but unfortunately no change.
        • neilc6
          • Nov 2015
          • 1550
          12V for the tcon usually is switched through the main board from the power supply on one of the edges of the LVDS cables. You can usually figure out which edge by ohming the tcon fuse with one of the edges and usually passes through more than 1 pin. You can trace this through the main board where it should go through a FET switch. Could be a BGA failure on the processor not sending the tcon on signal to the FET. Can test this by heating the processor with a hair dryer before plugging in. Also check for 12V from the power supply going to the main board.
          • Stuckster
            • Oct 2019
            • 40
            From memory I think it's the last 4 pins on the 51 pin cable. So I should be able to check this easily enough.
            Looks like there are two processors on the board. Which one would I heat?
            Yeah I can't see any, which is odd (see the list of voltage readings from the original post). In the absence of a dedicated 12v signal going direct from the pcb to the MB, is it possible that the mainboard could convert the 23.6v or the 3v into 12v?
            • diif
              • Feb 2014
              • 6978
              • England
              It will be 24v -> 12v. You could check the coils (grey squares) for a short to ground, the power rails for the processors and memory will be low but it's possible the 12v might have a short.
                https://www.badcaps.net/forum/attach...1&d=1571549151
                Can we get picture that is in focus? Right now I cannot read the designators on the board.
                • Stuckster
                  • Oct 2019
                  • 40
                  Hi BudM
                  Sorry. My mobile is hopeless with close up detail. I've retaken using a proper camera and split it into two photos so you get clearer detail. Thanks.
                  • Stuckster
                    • Oct 2019
                    • 40
                    Unfortunately no shorts to ground in the coils.
                    There is a 6R8 coil on the mainboard reading 12v. It also has a test point on the flip side that says 12v. But somehow that isn't getting to the Tcon.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      12v on a test point sounds hopeful, it will need tracing to see where it goes.
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        What is the part number given on the IC
                        • Stuckster
                          • Oct 2019
                          • 40
                          Hi. Thanks for your help! It should be much clearer on this image.
                          https://www.badcaps.net/forum/attach...6&d=1571657047
                          • nomoresonys
                            • 12128
                            • U.S.
                            Meter in diode mode check the small ceramic capacitors on t-con, see if any read short or beep if you have beep function on meter, kind of unlikely tho, see if tcon fuse is blown, do you get the 12 volt with the lvds cable disconnected?
                            • nomoresonys
                              • 12128
                              • U.S.
                              Check for voltage on each side of tcon fuse black probe on chassis ground if you haven't yet.
                              • nomoresonys
                                • 12128
                                • U.S.
                                Could try heating the mainboard a small section at a time with a hairdryer, hit the whole board including the ceramic and electrolytic caps, see if display changes any.
                                • nomoresonys
                                  • 12128
                                  • U.S.
                                  Unhook ribbon cables from t-con to panel then see if you have voltage on tcon.
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    Unfortunately it's not. It's the numbers written on top of the IC I'm asking for.
                                    • Stuckster
                                      • Oct 2019
                                      • 40
                                      Tcon fuse is good. I believe the 12v is sent to the Tcon via the 51pin LVDS cable. So I would presume that there will still be no 12v with the LVDS unplugged, but I will test it anyway.
                                      • Stuckster
                                        • Oct 2019
                                        • 40
                                        Hey. Sorry. I can see 2 or 3 smaller ICs on the board. Do you need to know the numbers printed on each of them? If not, could you identify the specific one you are referring to?
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • Awsmessymail
                                          Vizio E701i-A3 backlight only and now no backlight
                                          by Awsmessymail
                                          Hello all,
                                          I’ve tried to repair TVs in the past with some luck. Toms repair manuals got taken down and now thats a bit harder.
                                          I picked this TV up hoping for a quick fix. When the TV would power on, only the backlights would come on. The owner told me they heard loud screeching before it shut off. This alone makes me want to think the main board has an issue.
                                          As I researched, I found the TCON/driver boards were an issue on this unit. I went in troubleshooting the TCON but found good voltages on the TCON. I followed shop jimmys guide to test the transistors and they seem okay....
                                          02-13-2024, 11:04 PM
                                        • maxim2511
                                          LG 55EC930V OLED - swich on swich of no screen
                                          by maxim2511
                                          My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                          Then I get an idea to take it apart and clean boards from dust.
                                          In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                          Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                          05-14-2021, 02:21 AM
                                        • Fly_Among_Stars
                                          VIZIO E70-E3 Half picture with half TCON
                                          by Fly_Among_Stars
                                          I have a VIZIO E70-E3.
                                          Symptoms: Black screen, no picture, but LED backlights are working.
                                          I probed the power board and voltages are as listed on the board.
                                          Main board appears fine, too.
                                          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                          There are two separate ribbon cables feeding the LCD.
                                          If both are connected, the screen is black.
                                          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                          04-24-2023, 08:20 PM
