Samsung UE40F6320AK on / off boot loop problems
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    I have a Samsung UE40F6320AK stuck in boot / start up loop when I turn it on it boots up to the logo screen then shuts itself of and back on again continuously.
    I have removed the back, and no obvious bad capacitors, I have unplugged and cleaned all cables and connectors
    I have tried isolating parts individually, I tried unplugging wifi module, bluetooth module, power button/remote sensor, to no avail.
    I tried unplugging Tcon, exact same prob. Cable to backlights etc.
    The only time anything differs is, if I unplug video board from power board, it still loops on and off, however it does it twice as fast.
    When I unplug the main power cable from the TV, it still clicks as if turning on and off for a few seconds, aprox 3 or 4 times, before it actually becomes silent.
    Any help where to start with this or where to end with it greatly appeciated.
    Re: Samsung UE40F6320AK on / off boot loop problems
    Lets see good clear pictures of the whole backside of the TV showing all the boards so we can see what we are dealing with.
    • Bloopeta
      • Jun 2018
      • 526
      • United Kingdom
      Thankyou for your reply.
      Here are the pics as requested, if you require anymore please let me know.
        • 12094
        • U.S.
        Could try eeprom reset, hold a wire from EEPROM_GND to EEPROM_SDA power up tv for about 20 seconds remove wire then turn tv off, so for reference we will say that FA_TX is number 1, you want the wire on numbers 4 and 6 which is eeprom-gnd and eeprom-sda. DO NOT PUT IT ON FA_TX.
        • Bloopeta
          • Jun 2018
          • 526
          • United Kingdom
          Have tried this, made no difference
          • raydem
            • Dec 2012
            • 27
            • spain
            Could you re-program the eeprom? It is like the eeprom is corrupt.
            • Bloopeta
              • Jun 2018
              • 526
              • United Kingdom
              I wouldnt know where to start lol
              • Bloopeta
                • Jun 2018
                • 526
                • United Kingdom
                Would it be the eeprom though? As if I unplug the main cable prom the PSU to video board, its still does the same??
                • Bloopeta
                  • Jun 2018
                  • 526
                  • United Kingdom
                  Not sure if its worth mentioning, but before trying eeprom reset, after plugging TV in, it would go into standby, and I would have to turn on via remote or power button to get it to the looping stage, however after attempting eeprom reset, now as soon as the TV is plugged in, it tries to start automatically without having to press anything.
                  • yokoono
                    • Apr 2010
                    • 479
                    Put the TV in the socket and immediately put on the nand memory with freeze spray (-55 celsius degrees). You have a chance to get out of the loop. Then do a factory reset.
                    • Bloopeta
                      • Jun 2018
                      • 526
                      • United Kingdom
                      I have tested power board outputs without anything pluged into power board, the results when it clicks are
                      1. N/C 0
                      2. P/DIM4 Jumps
                      3. D-ON/OFF Jumps
                      4. P/DIM3 Jumps
                      5. GND
                      6. P/DIM2 Jumps
                      7. B13V Jumps
                      8. P/DIM1 Jumps
                      9. B13V Jumps
                      10. N.C. 0
                      11.VAMP Jumps
                      12. BLU ON/OFF Jumps
                      13. VAMP Jumps
                      14. GND
                      15. GND
                      16. GND
                      17. B5V Jumps
                      18. A5V Jumps between 5.27 and 5.26
                      19. B5V Jumps
                      20.PWR ON/OFF 0.87v jumps upto 2.3?v
                      All the ones I have wriiten just jumps beside, jump from 0
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        If you disconnect the power supply from the main board and jumper A5V to PWR ON/OFF using a 1K resistor and switch on, does the B5V and B13 supplies come on.
                        • Bloopeta
                          • Jun 2018
                          • 526
                          • United Kingdom
                          Ill get a 1k resistor and try
                            "20.PWR ON/OFF 0.87v jumps upto 2.3?v"
                            So the PS-ON pin is jumping up and down between 0.87 and 2.3V?
                            BTW, PS-ON pin has built-in pull up SMD resistor R5852 to pull PS-ON pin high for power supply self test.
                            Samsung BN44-00622D
                            https://www.shopjimmy.com/samsung-bn...led-board.htm#
                            • Bloopeta
                              • Jun 2018
                              • 526
                              • United Kingdom
                              Samsung BN44-00622D
                              Hi yes, it 0.87, then when clicks jumps up to 2.3something volts, then when clicks less than a second later goes back down to 0.87, then repeats in continuos loop
                                Are you 100% sure that the A5V is not jumping between <2 V and 5V?
                                • Bloopeta
                                  • Jun 2018
                                  • 526
                                  • United Kingdom
                                  Hi, yes sure, unless im testing the wrong pin, ive attached pics and marked it in red.
                                  • Bloopeta
                                    • Jun 2018
                                    • 526
                                    • United Kingdom
                                    If thats the correct pin, this is the reading
                                    • dick_barton
                                      • Aug 2015
                                      • 6642
                                      • Wales
                                      The pin numbers are given alongside the socket.
                                      • Bloopeta
                                        • Jun 2018
                                        • 526
                                        • United Kingdom
                                        Yeah I was just double checking incase I had the top and bottom mixed up lol, ive ordered 1k resistors to check what you suggested, ill update you with the results when they arrive.
                                        • Takeatry
                                          Yet another Samsung QLED Boot Loop
                                          by Takeatry
                                          Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                          10-04-2024, 02:57 PM
                                        • torchzack
                                          Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                          by torchzack
                                          Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                          I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                          Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                          08-28-2023, 07:42 AM
                                        • NolesFan
                                          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                          by NolesFan
                                          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                          10-24-2024, 06:36 PM
                                        • eigma
                                          Samsung UN40H5003 boot loop every ~8 seconds
                                          by eigma
                                          Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                          Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                          SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                          Main board: BN94-07592P / BN97-08922R...
                                          11-20-2024, 10:31 PM
                                        • blaster_
                                          Samsung UE49MU6105K - boot loop, horizontal lines
                                          by blaster_
                                          Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                                          Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                                          06-22-2022, 05:19 PM
