Cloudy White Screen = dead TCON board?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Well, I got my first dead TV to repair or part and dispose of. Boo. Hate it when I acquire other peoples repair failures.
    The TV turns on but is silent, CCFLs turn on, but I get the "cloudy white" display. I take it that the TCON is bad since the PSU appears to be working since it has soft power which works...
    The TV uses an integrated TCON as far as I can tell. So theoretically I have to ditch the panel with the TCON to fix it?
    Are tcon boards fixable or do they tend to be complete FRUs? How much state is kept on tcon boards? Chances of just a power connection to the tcon gone bad that would cause the cloudy white screen, or is there initialization that needs to be done on the tcon (and thus a microcontroller there too) which could have all sorts of annoying things that could go wrong with it that would emulate no power?
    • 12167
    • U.S.
    Re: Cloudy White Screen = dead TCON board?
    Make, full model number and pics.??
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Ah sorry was more of a general question. Don't have pictures, kind of mad at it, threw it somewhere to look at it later or never, but it's some crappy polaroid brand 19".
      Cloudy white display as in the TFTs in the display all are off/not controlled, so whatever state they were in is what they are - no picture information whatsoever is making it to the display. Blooms everywhere, just like clouds... Eventually fades to mostly white.
      The pinout of the cable from the logic board to the tcon would be interesting of course for probing, but getting this kind of data is never easy...
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        Sounds like a bad panel to me, though I haven't fixed a TV in ages now
        Wattevah...
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4325
          • Italy - Milan
          It seems mainly a tcon defect, you must check the usual tensions on it...
            • 12167
            • U.S.
            Does seem like a panel issue from description, could probably find a cheap tcon but would only work if it is a tcon issue of course, wouldn't think they would cost too much, being that it's 19 inches.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              What about the integrated tcons? Usually means I replace the tcon with the panel? Then the ones that are chip-on-cable (though I think this one there's a board on the display.)
              Anyone actually try repairing tcon boards or are they pretty much needing to swap them because there's not much that is fixable on them (i.e. broken PCB trace somewhere or the ICs are toast?)
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4325
                • Italy - Milan
                Check first if the tcon supply tension 12v or 5v stay there, or if the fuse is broken, if not you can check for the dc-dc converters, switching or not.. how? this is another story..
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Cool yeah I did notice a device I wasn't familiar with - a 4-pin TO-220 remote controllable 12V LDO on the PSU board. As I didn't have schematics and the silkscreen sucks on this board I didn't trace it - if it even feeds the tcon or not.
                  I should go due diligence and test the voltages on the psu board, though testing on the tcon board is going to be mighty difficult. There were a bunch of bad caps on the board I didn't bother replacing because I was expecting different behavior from the device due to the bad caps, not the white out.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4325
                    • Italy - Milan
                    change them..
                      We need to see the pictures so we can see what we are really dealing with.
                        • 12167
                        • U.S.
                        This is the missing info we needed, change m out, it's probably your only problem, bad caps can give all kinds of displays that can make you think it's something else.
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          • Romania
                          I once had a Samsung TV which had a semi-dead LDO on its T-con, hence it didn't produce any picture - just a white screen. Its output was slightly less than what its package said. Since I didn't have the exact part on hand at that moment, I first wanted to check if that was the issue to begin with, so I removed the LDO and wired in a cheap DC-DC buck converter off Ali set to 3.3v if I remember correctly. The set did produce an image, albeit it had horizontal stripes all over it because it didn't like the switched output of that converter - wasn't filtered well enough. Still, it instantly told me what the issue was and I got the proper LDO which solved the issue. I actually wrote a thread about this and it's you guys who told me what the issue was all along. Might not be completely similar to what you describe, but goes to show bad power CAN cause issues at panel-level where you don't usually expect it to...
                          Wattevah...
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            Interesting. Might have to check after all. Just that the behavior didn't seem right, I'd expect mostly working but random cyclic behavior with bad caps, at least that's all the other bad cap problems I've seen on my LCD monitors (other than the switch controller capacitor which could cause even power up to fail -- neither of these behaviors match what I saw with my LCD monitors prior to replacing the bad capacitors.)
                            Will need to dig the TV out of the defer pile... and the LDO is a 12V (278R12) unit which sort of baffles me.
                            Incidentally the cloudy white screen is the exact behavior I saw with my LCD monitors if I forget to connect the logic cable from the digital board to the tcon/panel.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4325
                              • Italy - Milan
                              The cloudy effect is probably due to an initial power up of the panel, then tcon goes protection, the pixels has a gate capacitance that lets those to slowly fade to white (off).
                              • mateuszdg
                                • Dec 2022
                                • 16
                                • United Kingdom
                                Sorry for jumping in i alaway tought its a panel issue. I have screpped one sony for that issue. Now i have a nice big OLED sony with simmilar issue and i wonder if its for sure panel. Any advices ?
                                Its SONY 65AF9 and it powers on with almost black screen except part of it is like cloudy gray.
                                • Diah
                                  • Feb 2013
                                  • 6364
                                  we have threat on sony OLED and its described how to test panel and t-con as stand alone.. make new threat and show us yours test result
                                  • mateuszdg
                                    • Dec 2022
                                    • 16
                                    • United Kingdom
                                    I would love to do it but i cannot create my own new thread even tough i have met all requirements and been already in few discussions etc WHo do i need to talk about it ?
                                    I was trying to find a dedlcated thread for Sony OLED but unsuccesfull. Any chance you could share a link ?
                                    Thank you very much.
                                    • EazyBone
                                      • Jun 2023
                                      • 1323
                                      • United states
                                      I had a Sony 5 blink thread. It's pretty recent, shows how to test the panel there. Diah explains it. My panel unfortunately was dead, but the test is valid
                                      • mateuszdg
                                        • Dec 2022
                                        • 16
                                        • United Kingdom
                                        Coud anyone help me finding a OLED test thread? I was searching for it but no luck. I'd like to finally rule out screen from other components. Thx
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • harp
                                          White screen repairs
                                          by harp
                                          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                          05-13-2024, 03:43 AM
                                        • Rav_tangle
                                          MacBook Pro 2011 turns on with keyboard light , screen dead
                                          by Rav_tangle
                                          Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                                          I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                                          Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                                          is this...
                                          05-31-2024, 04:09 PM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • NeilMcG
                                          Hp Elitebook - Dead Screen
                                          by NeilMcG
                                          Hello all,
                                          First time posting, so please be gentle 😂
                                          HP Elitebook 850 G2 Win 10 with Intel HD Graphics 5500.
                                          Screen dead, but booting.
                                          I connected it to an external monitor via both VGA & Display Port outputs and external monitor works fine, nothing with F4 or detecting another screen in settings.
                                          Got a replacement panel, still dead & still displayed to external screen as before.
                                          Removed CMOS & left it. CMOS reconnected, all as before, no panel, external monitor works.
                                          Got replacement cable...
                                          12-06-2024, 03:23 AM
