MacBook Pro 2011 turns on with keyboard light , screen dead
  • Rav_tangle
    • May 2024
    • New Zealand
    Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
    I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
    Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
    is this the enable pin?
    can somebody with experience help, I'm a bit of a novice & not really too experienced.
    i have a multimeter & some basic knowledge & am willing to learn , please be kind as I'm very entry level but keen to advance my knowledge.
    ps: sorry if it's been asked multiple times & I tried searching for answers & no luck
    also am aware of bad amd gpu on these & have baked this guy in oven & no luck , also checked board for damage or corrosion & nothing appear wrong.
    does beep with no ram & does boot to os as far as I can tell with disc spinning & keyboard lit up .
    is the gpu dead & if so should it still be booting up ?
    if gpu is dead should the screen have no lights ? Including backlight?
    cheers
  • Rav_tangle
    • May 2024
    • New Zealand
    Any MacBook gods out there that can help please?
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • resistor83
      Macbook pro 15" 820-2915-B 2011 A1286 boot on but black screen
      by resistor83
      Hi everyone, I have this 2011 MacBook Pro 15" model 820-2915-B which has a problem.
      I turn it on, the startup sound is heard but the screen doesn't turn on, not even the backlight. The keyboard lights up after a while and the capslock works. If I press any key I can hear sounds as if the system is booting.
      I thought it was a screen problem but after changing it the problem remains.
      What could I do?
      09-14-2023, 12:38 PM
    • Stephen
      MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
      by Stephen
      MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
      03-15-2024, 09:37 AM
