Cloudy White Screen = dead TCON board?
  • Diah
    • Feb 2013
    • 6613
    Re: Cloudy White Screen = dead TCON board?
    Originally posted by mateuszdg
    Coud anyone help me finding a OLED test thread? I was searching for it but no luck. I'd like to finally rule out screen from other components. Thx
    https://www.badcaps.net/forum/showthread.php?t=92239
    read post #4
    • Daren87
      Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
      by Daren87
      I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
      08-13-2023, 03:25 PM
    • kca
      by kca
      Hello all ~
      08-31-2025, 06:38 AM
    • harp
      White screen repairs
      by harp
      To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
      Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
      On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
      05-13-2024, 03:43 AM
    • Rav_tangle
      MacBook Pro 2011 turns on with keyboard light , screen dead
      by Rav_tangle
      Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
      I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
      Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
      is this...
      05-31-2024, 04:09 PM
    • x_orange90_x
      TCL 50S535 bad tcon or panel issue?
      by x_orange90_x
      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
      03-29-2025, 11:02 PM
