Samsung 60" LED blank screen and WILL NOT STAY OFF
  • x_orange90_x
    • May 2015
    • 765
    Re: Samsung 60" LED blank screen and WILL NOT STAY OFF
    Originally posted by budm
    Shorted out LED in the series connected LED's will still allow the LED strings to light up, open LED will cause the whole LED not to light up. Too many shorted out LED will also cause the LED circuit shutdown. Shorted circuit in one of the LED string to the chassis will also cause the shutdown.
    What kind of the LED strips/assemblies are used in your TV.
    I run into panels that have one of the LED strip's wire nicked by the chassis and cause intermittent shorts circuits to the chassis.
    BTW, do you have LED tester?
    Here is the link to exactly what I purchased from Shopjimmy:
    https://www.shopjimmy.com/samsung-bn...-12-strips.htm
    So under normal, wall mounted use, what would cause an led to short circuit? When I installed the strips I used strong double sided tape to secure them to the chassis.
    Also, if an led is shorted, would it be off or would it still light up? I see no darkspots when the screen is lit and blank.
    • budwich
      • Jul 2015
      • 3097
      you might try further "panel orientation" tests. How about flipping the panel "upside down"... ie. top down, bottom up. Then also try side up / side down. See if things change.
      • x_orange90_x
        • May 2015
        • 765
        In regards to resistance on the wires, or in overall behavior?
        • budwich
          • Jul 2015
          • 3097
          overall behavior first.... trying to find a "normal" position (ie. vertical position) where the tv operates properly... then once there you can start checking things to form a baseline along with possibly understanding what the difference is from "proper upright position"... basically, it costs nothing to do the "flips"... and proceed from there carefullly especially with the meters that you have. :-)
          • x_orange90_x
            • May 2015
            • 765
            Tried all different orientations and no change. However, I believe I found where the problem resides, and that is the backlights. While they were on and flashing, I started smelling hot electronics. I smelled around all of the boards and nothing. The smell was coming through the vent hole in the attached picture.
            Edit:
            I'm preparing myself to open up the panel for the third time.. But I have a few questions for. If an LED itself is shorted, in this particular TV, would the rest of the lights be working and that one would be off, or would it still be on? If it's shorted, can it be desoldered and replaced (I have the original set still)? And finally, if it's a short at the connector between strips, can that be repaired (ie. Electrical tape behind it)?
            I'm not up for purchasing a whole new set again as these are out of warranty now.
              • 12323
              • U.S.
              #86
              Ok, looks like you need to get in there again, wonder if this is one of those models where a problem on the powerboard keeps messing up the backlights or if you have just a backlight short, bare wire, or some such.
                • 12323
                • U.S.
                #87
                With that burn smell going on, I'm thinking the problem should be visible maybe.
                • x_orange90_x
                  • May 2015
                  • 765
                  That's what I'm hoping for. It seemed to be originating from near the bottom center, which it where the strips connect. Perhaps the connector it's arcing on the frame when voltage is applied?
                  So in the likelihood it's something I can easily repair, what should my expectations as far as life expectancy? I never used them at full brightness, but whatever is happening now makes me fear that their life span has been dramatically decreased.
                  • x_orange90_x
                    • May 2015
                    • 765
                    I think these pictures are self explanatory...
                      You have bad contact resistance on the connector so it is heated up like that.
                      • x_orange90_x
                        • May 2015
                        • 765
                        Can I repair this or does this strip need to be replaced?
                        Edit:
                        Trying to pull the strips back to place something anti-cunductive resulted in the connector falling apart.
                        Checked eBay and someone wants nearly $20 for a single used strip. So, could I remove the connector and solder wires between the connection points?
                        • R_J
                          • 9629
                          I would just remove both plugs and connect them with wires, then make sure non of the connections touch the metal panel. Then also inspect the other connectors while it is apart.
                          It looks like they had poor solder connections between the plug and the strip, Then it started arcing and burnt the trace. So you might want to resolder ALL the strip plugs
                          • x_orange90_x
                            • May 2015
                            • 765
                            Ok I'll do that then.
                            One of the light spreaders popped off when I was removing the strip. I don't have any super glue, but I do have Loctite SI 595 Clear RTV Silicone Adhesive... Would this work to reattach the spreader? The silicone is supposedly good up to 450°F.
                              • 12323
                              • U.S.
                              #94
                              Funny a brand new strip is of such poor quality, time for a refund on that junk.
                              • x_orange90_x
                                • May 2015
                                • 765
                                I know! Unfortunately Shopjimmy only has a 180 day warranty. These are now roughly 14 months old. Should last years longer imo. And they're listing kinda brags about the 'redesigned' connector that is supposedly better.
                                I know I sound cheap asking this, but I don't have the usual repair items at hand right now, and I really want to just get this thing back together and find it if it works.... But, Clear RTV silicone adhesive.. Can I use it to reattach the light spreader that popped off AND to remount the strip to the inside of the chassis? If not I will go get super glue and double sided tape tomorrow.
                                  I would notify Shopjimmy and show them the pictures of the failures and see what they will say.
                                  BTW, I am glad we got down to the cause of the problem.
                                  • x_orange90_x
                                    • May 2015
                                    • 765
                                    I emailed them and even stated I knew the warranty was way past. I wasn't really trying to get a free replacement or anything, but damn, their response was essentially "sorry the warranty is expired, we can't do anything. Here's a coupon code for 10% off"
                                    I replied and sent them the pictures and just said I wanted their technical department to be aware of the failure of their product.
                                    Anyway, I just went and picked up double sided tape and super glue, so I'm about to start working on it now. I'll pay a follow-up when finished.
                                    • x_orange90_x
                                      • May 2015
                                      • 765
                                      After removing the connectors I can see it's burnt straight through down to the aluminum backing. I'm afraid if I solder a wire to it that it will end up arcing or electrifying the entire aluminum strip AND chassis when mounted.
                                      I'm going to try and see if two of my old strips (the originals out of this TV) are will work and probably use them instead. I hate to have to resort to it because they probably don't have that great of life expectancy left in them
                                      • x_orange90_x
                                        • May 2015
                                        • 765
                                        I replaced the strip with one of the original in which i half-ass tested and seen each led blink, but upon reassembly and inspection it is bad. Good news is that upon plugging in the TV it was in standby, and turning it on resulted in a full successful powerup with everything functioning as it should... Except for backlights. So either i coherse SJ into replacing this one strip, or I purchase a used one from eBay :P
                                        • x_orange90_x
                                          • May 2015
                                          • 765
                                          I'm going to have to resort to using a string of the original lights, if I can find a set that works. Is it possible for me to test the Backlights outside of the TV? I seen it done inside of the TV with 9v batteries, but as I said that was inside and plugged in. I bought a bunch of 9v batteries but couldn't get the stands I was checking to light up.
                                          Also, when I have the panel apart, is there a way to trick the LEDs into being on without the panel connected to the tcon?
                                          • Chrissygizmo
                                            Panasonic TX-48CX350B backlights but white screen , blank screen
                                            by Chrissygizmo
                                            Hi all, I’ve got a problem I hope someone can help me fixi.
                                            I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                            01-11-2025, 03:18 PM
                                          • mecha1166
                                            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                                            by mecha1166
                                            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                                            11-25-2024, 05:22 PM
                                          • Chrissygizmo
                                            samsung ue55nu7021k backlights working but blank screen
                                            by Chrissygizmo
                                            I have a Samsung ue55nu7021k that has working backlights but has a dark blank screen..
                                            I've tried a couple of different boards from a friend without success, however, one of the boards produced the Samsung Smart logo on the screen so I'm guessing it's the main board that's at fault, is there anything I could try to repair the board or is it a case of buying a new one ?
                                            Thanks in advance...
                                            08-01-2021, 11:50 PM
                                          • dicky96
                                            HP Elitebook Screen blank - backlights but no image
                                            by dicky96
                                            Hi guys
                                            I'm trying to fix this laptop screen
                                            Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                                            OK so I have the original screen which works but has lines across the bottom quarter of the screen
                                            I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                                            04-28-2021, 07:30 AM
                                          • mrtek
                                            Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                                            by mrtek
                                            Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                                            11-26-2024, 09:58 AM
