No Screen or Sound on 32 in ELEMENT ELEFW392
  • rebelkustoms
    • Sep 2015
    • 150
    Hello All,
    Been a while since I have posted or tried to fix anything. I have an Element 32 in, plug it in it gets a standby light. When you press the ON button, the indicator turns blue but there is no screen or sound. Fooled around with the buttons and plugged in a few sources to be sure, nothing. The single red and white wire above the line of capacitors is getting 52-56 V. Im guessing from the routing and the Voltage that is the power to the backlight. This one was a donation and the little main board is cheap, so if it is a main board issue I will just replace. But if i can narrow it to a backlight or a Tconn I think it may be recycling material. Let me know what you think.
  • R_J
    • 9579
    Re: No Screen or Sound on 32 in ELEMENT ELEFW392
    It seems like a backligt issue, place your meter probes across the red and white wires on that plug, then turn on the tv and see if the voltage gets to around 80 volts or more.
    That 52~56v is the base voltage, it will get boosted when first turend on, but if it sees an open circuit it will drop back to the base voltage.
    • rebelkustoms
      • Sep 2015
      • 150
      So off voltage hangs in the mid 40s when turned on after a second or so it shoots up to 110 - 115v then steps back down to around 58.5v and stays there.
        The LED driver is not seeing the load that is why the Voltage went up over 100V, you have open circuit some where in the LED string.
        • rebelkustoms
          • Sep 2015
          • 150
          I have really only messed with power supplies etc. on these things. So I am guessing I might be getting into non-serviceable territory on the LED lamps. Is there parts out there?
            • 12216
            • U.S.
            Sold out but might help you out with what to get: https://www.shopjimmy.com/element-pb...s-3-strips.htm
              • 12216
              • U.S.
              Replacement on a similar tv: https://www.youtube.com/watch?v=In91IzmGLaM
              • rebelkustoms
                • Sep 2015
                • 150
                Been watching videos on this repairs and someone tested the strips and removed a faulty led and did a pass through with some soldering.Is +/- 3v going to effect the Main Board or the other LEDs? Im sure this isnt the preferred fix but honestly this TV was free and I have no need for it so I might give it a try.
                  • 12216
                  • U.S.
                  Can use diodes in series so the Vf will be about 3v.
                    You may be able to bypass ONE LED but not more than that if more than one LED is bad, it will over heat the PWM MOSFET that maintain the constant current through the LED string when LED's are bypassed, when you the LED's you must reduce the Backlights level to as low as possible (it should be done any way).
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • Rozp
                      70LE660U dark cloud or black screen with sound.
                      by Rozp
                      Hello Everyone,
                      This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                      I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                      08-29-2023, 05:25 PM
                    • Mgiffune
                      by Mgiffune
                      I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                      I ordered a supposedly β€˜new' Tcon board this time, and
                      06-09-2024, 10:28 AM
                    • ChaosLegionnaire
                      by ChaosLegionnaire
                      09-13-2022, 09:02 AM
                    • Audeze
                      Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                      by Audeze
                      I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                      Does...
                      10-06-2024, 08:54 PM
