Sharp LC-60LE741E 3 Blinks
  • london-freddie
    • May 2015
    • 472
    Hi Guys
    Just bought cheap this Sharp LC-60LE741E, seller said can not get it out of standby
    Got it home plugged it in and it powered up, however after maybe 2 minutes it powered off itself and has not come back on since.
    When powering on white led at bottom centre comes on steady for about two minutes (nothing on screen) then goes off, White led then comes back on flashing three times
    I can not find what this flashing code is, all I am finding is 1 quick flash then 2 short flashes, Mine is 3 flashes all same length
    Did find a reset involving think it was volume down and input held whils plugging in but that had no effect
    Only thing I have checked up to now is for 5V standby on powerboard which is there.
    My first thought is powerboard but maybe it is the mainboard
    When tv did first power up picture seemed good for the short time it was on
    Any ideas please as to what these 3 flashes are telling me
    thanks
    • 12276
    • U.S.
    Re: Sharp LC-60LE741E 3 Blinks
    Try it while holding input and channel down, see if that works.
    • london-freddie
      • May 2015
      • 472
      Hi
      Thanks for that Input and channel down, No effect
      • london-freddie
        • May 2015
        • 472
        I am struggling at the moment to check powerboard Vs, but looks like I have no 12v at pins 1 and 2 on PD
          • 12276
          • U.S.
          Do you have backlights? If not (with tv unplugged) unplug cable from powerboard to mainboard, plug tv back in, see if they come on.
          • london-freddie
            • May 2015
            • 472
            No backlights come on with powerboard to mainboard cable unplugged
            Does not a BL on signal from mainboard to powerboard tell the powerboard to turn on the backlights, or am I wrong
            • london-freddie
              • May 2015
              • 472
              I have been trying to follow a youtube video SHARP AQUOS TV "LC-60LE650U" flashes 3 slow, 1 fast. No back light or sound. Here's the fix. by Ray S
              On checking my regulator, mine is a slightly different board I also have no 12v coming out from the regulator, this 12v seems to go to pins 1 and 2 on the PD connector but I also have no turn on volts at the regulator.
              Am I on the wrong track here ??
              • london-freddie
                • May 2015
                • 472
                underside of powerboard Q7120 I believe is the 12v regulator
                  You need to report what Voltages you have on the power supply connector that goes to the main board so we can see what it has or does not have when TV is off and when power switch is activated, that will be the starting point.
                  • london-freddie
                    • May 2015
                    • 472
                    Hi will do budm asap, was struggling to get readings from top of the board, will have to try from the bottom but keeping all connected, I will do it
                    • london-freddie
                      • May 2015
                      • 472
                      Anyone know yet what the 3 flashes mean on this set
                        https://www.badcaps.net/forum/attach...6&d=1561560221
                        BTW, what is the board P/N as printed on the board and on the bar code stickers?
                        You can probe the connector from the wire entrance side using skinny probe tip.
                        • london-freddie
                          • May 2015
                          • 472
                          Ok budm got what you want
                          PIN
                          1 PNL12v 0V
                          2 PNL12V 0V
                          3 GND
                          4 GND
                          5,6,7,8 UR13.2 13.23v
                          9,10,11,12 GND
                          13 AC_DET 3.35V
                          14 PS_ON 2.87V
                          15 BU5V 5.09V
                          16 PNL_POW 0.2v
                          17 PWM1 0v
                          18 NC
                          19 DIMMER 0v
                          20 NC
                          21 OFL 0.2v
                          22 ERROR 0v
                          23PWM2 0v
                          24 STB 0v
                          • london-freddie
                            • May 2015
                            • 472
                            Board number is
                            • london-freddie
                              • May 2015
                              • 472
                              417V on Main caps
                                PIN
                                1 PNL12v 0V: No output because PIN 16 PNL_POW is not present
                                2 PNL12V 0V
                                3 GND
                                4 GND
                                9,10,11,12 GND
                                13 AC_DET 3.35V
                                14 PS_ON 2.87V
                                15 BU5V 5.09V
                                16 PNL_POW 0.2v Bad, should be 3 ~ 4 VDC from main board
                                17 PWM1 0v: Bad
                                18 NC
                                19 DIMMER 0v: Bad (this analog Dimming may not be used)
                                20 NC
                                21 OFL 0.2v
                                22 ERROR 0v
                                23PWM2 0v: Bad
                                24 STB 0v: Bad, this is the BL-ON signal, should be 3 ~ 4 Vdc.
                                So something is going on with the main board or something is locking out that causes it not to send out some of the command signals.
                                  417V on Main caps
                                  This is quite high, it should be around 380 ~ to 400V at the most.
                                  Meter is OK?
                                    • 12276
                                    • U.S.
                                    Do you have standby voltage with cable from powerboard to mainboard unplugged?
                                    • london-freddie
                                      • May 2015
                                      • 472
                                      Just rechecked main caps yes 417v as far as I am aware meter is ok
                                      are we talking standby voltage at pin 24 ?
                                        As indicated in my post #16; The STB pin is BL-ON.
                                        BU5V pins are the standby power supply pins.
                                        • Egidio85
                                          SHARP LC-40LE814E does not turn on 2 flashes
                                          by Egidio85
                                          hi, I have a sharp tv model LC-40LE814E with DPS-126CP-1 A power supply.
                                          the tv initially turned on, displayed the image for 10 seconds and then turned off. so in a loop until the power was cut off.
                                          reading the classic optocoupler problem I changed the mounted cosmos with SHARP PC817 recovered from other boards.
                                          now the TV turns on for 1-2 seconds and turns off giving 2 flashes in the front LED.
                                          to avoid banging too much I preferred to take an identical tested and working card (or so the supplier says)
                                          07-21-2023, 11:49 AM
                                        • joblo37pam
                                          Sharp LC-80LE844U Blinks 2 slow, 5 fast
                                          by joblo37pam
                                          It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
                                          The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
                                          10-26-2023, 02:17 PM
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
                                        • JayPoorJay
                                          sharp LC70EQ10U 2 slow, 2 fast blinks
                                          by JayPoorJay
                                          Good morning... I'm new here and have a LOT to learn.
                                          I'm a rescue-er. I live in NYC and I don't even want to get started on the amout of stuff that makes it onto the curb, to be crushed and in a land fill, simply because our repair shops have been sold out and because - well, it's a disposable society... Anywho
                                          I have 1 motorcycle, 3 Jaguars and a Porsche that were all headed to the crusher due to a couple handfuls of needed parts and a Lil Love,,, I'm hooked on the rescue. A member of several forums and a huge fan of DIY environments such as this one. Hats off to you...
                                          01-24-2022, 09:26 AM
                                        • Anzio
                                          Sharp LC60E79u 2 blinks power/3 Blinks OPC
                                          by Anzio
                                          I have a Sharp LC-60E79U with the blinking light error (Power and OPC blink 2 times together then OPC blinks 1 time. I read the previous thread on Sharp lc60e79u (https://www.badcaps.net/forum/showth...t=66913&page=3) with this same issue, but no resolution was posted.
                                          The service manual indicates this as a “DET_5V (33pin) error (L). 5V is not applied.”
                                          I cannot enter service mode by pressing input and channel down and plugging the unit in to power outlet. However, I can override and enter the diagnostic mode if press channel down and volume up and...
                                          07-03-2020, 01:12 PM
