Sharp LC60E79u 2 blinks power/3 Blinks OPC
  • Anzio
    • Sep 2012
    • 10
    I have a Sharp LC-60E79U with the blinking light error (Power and OPC blink 2 times together then OPC blinks 1 time. I read the previous thread on Sharp lc60e79u (https://www.badcaps.net/forum/showth...t=66913&page=3) with this same issue, but no resolution was posted.
    The service manual indicates this as a “DET_5V (33pin) error (L). 5V is not applied.”
    I cannot enter service mode by pressing input and channel down and plugging the unit in to power outlet. However, I can override and enter the diagnostic mode if press channel down and volume up and plug the unit into power outlet, I can get a steady power light but back light does not comes on. Nothing happens when I press power and holding power turn unit off (no power light). Pressing power again returns to the blinking light cycle. I measured voltage in the override state at the power supply and got the following values. I noted that there was no value at pins for S14.3V.
    Any advice on next step would be appreciated.
    Anzio.
    SGND 0V = 0V
    SGND 0V = 0V
    PNL 12V = 0V
    PNL 12 V = 0V
    PNL_POW = 0V
    BV5V = 5.0V
    PS_ON = 3.0V
    AC_Det = 3.1V
    SGND 0V = 0V
    SGND 0V = 0V
    SGND5 0V = 0V
    SGND5 0V = 0V
    S14.3 V = 0V
    S14.3 V = 0V
    UR 14.3V = 14.3V
    UR 14.3V = 14.3V
    SNGD3 0V = 0V
    SNGD3 0V = 0V
    SNGD3 0V = 0V
    SNGD3 0V = 0V
    SNGD3 0V = 0V
    INV 24V1 = 24V
    INV 24V2 =24V
    INV 24V3 = 24V
    INV 24V4=24 V
    Re: Sharp LC60E79u 2 blinks power/3 Blinks OPC
    Can you upload your service manual? My service manual does not show error codes chart.
    PNL 12V = 0V
    PNL 12 V = 0V
    PNL_POW = 0V
    PNL_POW control signal from main board is not present so there will be no PNL 12 V for the T-CON board.
    S14.3 V = 0V
    S14.3 V = 0V
    UR 14.3V = 14.3V
    UR 14.3V = 14.3V
    Are you 100% sure that S14.3V is not present? This Voltage is from the same out put of the power supply that produces the UR14.4V, you can see how the connections on the bottom side of the board.
    Also read this thread for 2:3 blink code: https://www.badcaps.net/forum/showth...harp+LC-60E79U
    May be you should also provide the pictures of the whole backside of the TV showing all the boards.
    • Anzio
      • Sep 2012
      • 10
      I will check readings again tomorrow take more pictures.
      Attaching service manual form the precursor LC6077U which includes what was left out of the LC60E79U service manual. See page 6-19)of LC6077U for error codes 2 blinks power/3 blinks OPC.
      • Anzio
        • Sep 2012
        • 10
        "Are you 100% sure that S14.3V is not present? This Voltage is from the same out put of the power supply that produces the UR14.4V, you can see how the connections on the bottom side of the board."
        OK, I checked the S14.3V again and there is no voltage present. I'm attaching pics of the of the whole backside of the TV showing all boards and the bottom view of the Power Board.
        Anzio
        • Anzio
          • Sep 2012
          • 10
          Better picture of Power Board top view.
            Anzio
            Please look at the marked up I made that shows how 14.3V, UR 14.3V, and S14.3V are generated and how they are connected, as you can see the 14.3V is fed to inductors, one for the UR14.3, another one for S14.3V.
            So for you to have UR14.3V but not S14.3V it means that you have open connection in that S14.3V path which you should be able to easily trace it with Ohm meter and visual inspection.
            • Anzio
              • Sep 2012
              • 10
              Budm, I am so sorry I made a measurement error. After making measurements from the bottom of the Power Board S14.3 is present at the bottom solder with a reading of 14.3V.
              However when I try to measure from top of board pin connector with a small probe inserted into the where the S13.3 cable connects, there is no voltage present. I wonder if I have a bad cable?
              I also measured voltage on Main Board at PD (top of cable and at the pins connected to the board) and the following voltages were detected:
              Main Board PD
              Pin 1 - 14.3V (UR14.3V wire connected here)
              Pin 2 - 14.3V (UR14.3V wire connected here)
              Pin 3 - 14.3V (no wire connected here)
              Pin 4 - 14.3V (no wire connected here)
              Pin 5 - 0V (S14.3 wire connected here)
              Pin 6 - 0V (S14.3 wire connected here)
              Pin 7 - 0V (no wire connected)
              Pin 8 - 0V (no wire connected)
              Pin 9 - 3.1V
              Pin 10 - 2.9V
              Pin 11 - 5.1V
              Pin 12 - 0V
              I attached a picture of the Main board.
              I'm a novice but working hard to learn.
              Anzio
                Your posy # 1
                " I measured voltage in the override state at the power supply and got the following values. I noted that there was no value at pins for S14.3V."
                So why are you wasting time checking on the Main board connector?
                It is obviously that S14.3V is fine so I cannot see why you say you do not have s14.3v at the power supply board, it is fine as far as I am concerned so do not waste any more time on S14.3V.
                The connector pin of power supply is not made to match one end to another end.
                • Anzio
                  • Sep 2012
                  • 10
                  Thanks, any suggestions where to look next given the error code "DET_5V (33pin) error (L)?"
                  • Anzio
                    • Sep 2012
                    • 10
                    Budm, you referenced in the earlier post to "Also read this thread for 2:3 blink code: https://www.badcaps.net/forum/showthread...harp+LC-60E79U." Would it be appropriate to take reading on the MOSFET q7120. RebRebel10 use a 330 ohm resister in trying to troubleshoot the Gate issue.
                    • joblo37pam
                      Sharp LC-80LE844U Blinks 2 slow, 5 fast
                      by joblo37pam
                      It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
                      The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
                      10-26-2023, 02:17 PM
                    • klassic
                      Sharp Aquos LC-60LE635E three blinks
                      by klassic
                      Hi community,
                      I will describe my problem with a TV in those short following terms to be the most precise :
                      What i have :
                      power board DPS-162KP-1
                      main logic board QPWBXF733WJN2
                      symptoms :
                      white led light logo at startup,
                      after 2 minutes, blinking 3 times a row, repeating
                      no backlight (and apparently no picture, checked panel with flashlight)
                      no startup sound
                      powerboard investigations :
                      1-2 PNL : 0v
                      3-4 GND
                      5-6-7-8 UR : 13.15v
                      9-10-11-12...
                      10-24-2023, 01:39 PM
                    • Biruslapio
                      Panasonic P58V11B 8 and 12 blinks error "fix"
                      by Biruslapio
                      Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                      Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                      04-13-2021, 07:13 AM
                    • JayPoorJay
                      sharp LC70EQ10U 2 slow, 2 fast blinks
                      by JayPoorJay
                      Good morning... I'm new here and have a LOT to learn.
                      I'm a rescue-er. I live in NYC and I don't even want to get started on the amout of stuff that makes it onto the curb, to be crushed and in a land fill, simply because our repair shops have been sold out and because - well, it's a disposable society... Anywho
                      I have 1 motorcycle, 3 Jaguars and a Porsche that were all headed to the crusher due to a couple handfuls of needed parts and a Lil Love,,, I'm hooked on the rescue. A member of several forums and a huge fan of DIY environments such as this one. Hats off to you...
                      01-24-2022, 09:26 AM
                    • Nairolf
                      Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                      by Nairolf
                      I have a Samsung DM32D display.
                      When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                      Here’s what I have tried so far:
                      1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                      2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                      3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                      From these tests, I suspect the problem might be on the mainboard. Could anyone...
                      08-24-2025, 03:47 AM
