Sony XBR-65X900C Sporadic Issues
  • Diah
    • Feb 2013
    • 6614
    Re: Sony XBR-65X900C Sporadic Issues
    you dont need to keep hold them pressed
    from the point you plug it back to wall socket count from 1 to 10 then release and never touch it any more
    • Diah
      • Feb 2013
      • 6614
      your TV issue are communication between ram and main processor i think.. as you plug it with LAN all recommend apps and smart apps loading and they occupied the ram so there are no more space to let the firmware run. CPU are responsible to clear the ram and load other script. you can repeat this methode how much you can till clear it.. this will never harm the set at all. other wise you need to reflow the cpu or ram.
      • budwich
        • Jul 2015
        • 3097
        Originally posted by Michale32086
        Yea, I have moved it back and forth from the display area to the work bench... I am always petrified every time I do it, but I am becoming more comfortable with moving it back and forth...
        I have the back off and there doesn't appear to be any bad caps or burn marks..
        One of my first thoughts was the symptoms are like the Samsungs when they have a couple charred connections off the Power PCB.. But no such luck with this one..
        Funny you should mention this..
        I seem to have a different problem now.. I see a different boot up process when the ANDROID animation is quicker and then I see a ANDROID IS STARTING.... loading apps message and then the TV shuts off...
        NOW the biggest problem seems to be that the TV tries to boot up, but shuts off at various stages of the boot process..
        And I still can't get a valid Factory Reset...
        Next time I move the TV to the workbench, I'll get some shots of the power boards...
        Thanx for the reply.. Much appreciated..
        I recently have an xbox original (2003) that would boot up some times and others not so. Moved it from one area to another (obvious different plugs), it would boot up fine. Moved it to another area where there is an xbox that works fine... same cabling used on the "bad one" would not boot. I took the housing off to look inside while booting.... then I saw the fan having a hard time to start... it would go a bit and then stop. The fan gets its power from the main board.... I looked around and see that 3 of the 3300uf 6.3 v caps (hint... likely in the 5v circuit) in the main board area appear to have slight budge and measure out at 10kuf ... :-(
        I haven't replaced them yet as local parts don't carry low voltage ones.
        Anyway, your problem seems to point to issues with the 5v supply / generation.... hence my suggestion.... I would take a closer look at any place that needs or appears to need 5v plus juice... meaning the voltage might be OK but not enough current.
        • Michale32086
          • Nov 2011
          • 1453
          Yea, I think a reflow is what got me into this mess.. I might have fried something...
          I'll play with resetting it more today... Maybe something will 'pop'...
          • Michale32086
            • Nov 2011
            • 1453
            If I can't do a successful reset today maybe you can run thru some voltages with me on Tuesday???
            Here are the pics for the 2 power boards...
            If the voltages check out, I think I am just going to break down and buy the Main Board..
            Kick myself to think that the LAN issue COULD have fixed the original problem had I not gone crazy with the reflow equipment..
              • 12331
              • U.S.
              #46
              A reflow shouldn't hurt IF you monitor your temps closely.
                • 12331
                • U.S.
                #47
                I thought this approach was pretty clever: https://www.youtube.com/watch?v=ZDQNOU2w_ek
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  #48
                  Yes, a novel idea but a DDR3 chip is smaller and thinner than a processor on a TV.
                  Heating a small part of the board to 220c leaving the rest cold isn't a very good idea for thermal shock reasons. It's the reason rework machines have a bottom heater.
                    • 12331
                    • U.S.
                    #49
                    Looks like they want about 200+ bucks for the mb, wonder if a repair service might be more economical.
                    • Diah
                      • Feb 2013
                      • 6614
                      Michale32086
                      don't give up. nothings impossible. could you shoot video to see what happen on the set screen and LED indicators when you plug it in wall socket.? also could you post photo of the main board and where you attempted reflow.. ??
                      Sony TV in general some time need unusual way to repair- some time it need real argue LOL.. for example.
                      your firmware now v5.433 as the TV set from 2015 production, other Sony in EU of 2016 production got the Android 8.0 Oreo. download one Oreo firmware and let yours TV argue.. it will do the following .. your Recovery will call out to clear data of your pervious firmware. then it will read the RSA KEY of new firmware and try to download it to temp. then your recovery will discover the model No don't matched. so it will reject the USB. and attempted to reset the pervious firmware in place. if we are lucky with this the TV will start on if no other reason.. give it try..
                      • Diah
                        • Feb 2013
                        • 6614
                        yes.. but not always.. my lovely rework machines Korean Infared in room Table BBQ
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          #52
                          Whatever works for you, that's great. You have first hand knowledge. Does it use a GU10 bulb or is it a little larger ? Care to share any photos to help other users ?
                          • Diah
                            • Feb 2013
                            • 6614
                            here you are
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              #54
                              Not bad, I'm all for repurposing things and at 1200W I'd think it has more than enough heat to heat the whole board.
                              • Michale32086
                                • Nov 2011
                                • 1453
                                That's pretty awesome..
                                I have always been a duct tape/super glue kinda guy..
                                • Michale32086
                                  • Nov 2011
                                  • 1453
                                  Well an update on this..
                                  I believe I have "reflowed" the board to the point of oblivion...
                                  I get absolutely nothing now.. No power LED no nothing.. I haven't checked the voltages but I am fairly sure they will be bad news as well..
                                  One of my (many) weaknesses is the inability to WAIT.. I just plow ahead hoping I get lucky, but usually end up stepping on my wee-wee...
                                  I am home today, but tomorrow I plan on checking the voltages to confirm it's DOA status.. At that point, I have 2 options..
                                  Order a board for $250 +/-....
                                  Put the TV in a safe place and hope another like it comes thru...
                                  The second option is not as unlikely as one might think.. I usually get anywhere from 10-30 TVs a month, oft times more.. The chances of an identical model coming thru is a distinct possibility..
                                  Of course, I could hurry that likeliness along by actually buying the board.. It's my luck that I would pay $250 for a board and then within a day or so, an identical model comes thru!
                                  In any case, thanx for all the help and hints and tips.. I'll follow up tomorrow with the voltages check...
                                  • Michale32086
                                    • Nov 2011
                                    • 1453
                                    Attached is a pic of the Main Board.. Not of mine specifically.. I can get a pic of that tomorrow..
                                    I pulled off the heat sinks and put the board on my reflow rig (also pic attached) I actually have a new T8280 Infrared preheat unit.. As you can see from the pic, that one has seen a lot of use..
                                    Anyways, I pulled the heat sinks off and put the AOYUE 968 nozzle on the GPUs, one at a time..
                                    Got the temp slowly up to 235c for 90 seconds...
                                    Subsequent reflows I just heated the board on the T8280 up 370f for 90 secs...
                                    Ironically enough I have another Sony XBR that has a very similar Main Board.. The only difference is that this board doesn't have the connector marked in BLUE.. The one on the XBR65X is an A2072598B. The one of the other XBR (I think it's a 55") is A2072599B
                                    With the board from the 55", I get the Power LED on for a min and then it shuts off...
                                    Like I said, I'll follow up tomorrow.. Maybe we can resurrect the dead..
                                    Thanx again for all your help..
                                    • Michale32086
                                      • Nov 2011
                                      • 1453
                                      Update on this...
                                      I have to clear out one of my TV Storage areas..
                                      I came across another SONY XBR with an identical Main Board as the 55".. It's from a 47" so it needs a firmware update...
                                      As I mentioned before the 55" MainBoard does not have the connector marked in blue..
                                      How important is that to the functionality of the 65"??
                                      • Diah
                                        • Feb 2013
                                        • 6614
                                        Update on this...
                                        yours 65 are Android. the next should android too with same CPU Type, Same Ram manifacture as well the NAND, all of there should be 100% same. other wise you will toast other parts include the 49 boards too
                                        • Michale32086
                                          • Nov 2011
                                          • 1453
                                          Ahhhhh Good point.. OK..
                                          I think I got it working on the 55" which has similar specs (4K, etc etc) to the 65"..
                                          I think I am going to NOT look a gift horse in the mouth..
                                          • HarryZ
                                            Sony XBR-49X800G networking issues
                                            by HarryZ
                                            Aloha. First post here, hope I can find someone to assist me.
                                            I have a Sony XBR49X800G with streaming issues. The issue mostly occurs watching sporting events (basketball and football). The picture will sometimes get pixelated, sometimes freeze for a few seconds while the audio continues, sometimes it's jerky. In other words, you get a headache watching the TV.
                                            My ISP provides 500 Mb service and I have verified that I have at least 500 Mb on ethernet, and something over 300Mb on WiFi. I installed Analiti on the TV (it's an Android TV) and I get ~ 70 Mb on both WiFi...
                                            01-26-2024, 04:49 PM
                                          • cheeky2
                                            Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
                                            by cheeky2
                                            I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
                                            Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
                                            The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
                                            Details:...
                                            08-17-2023, 04:34 AM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • PontyPCs
                                            Sony Android TVs eMMC Issues
                                            by PontyPCs
                                            Hi people.
                                            I have been trying to get my head round these issues with the eMMC putting the TV in to a boot loop condition, or completely dead, when a dump of the Boot 1, Boot 2 and USERDATA partitions have been made, the MLC lifetime counter has been reset, using the original eMMC with the RPMB partition intact and the eMMC is flashed with the original dump, Netflix and a few other Apps don't work. i assume all the DHCP keys and factory programmed RPMB access Key will be contained within the original dump, and as we are re-flashing the original eMMC i would expect every thing to work....
                                            12-10-2023, 10:43 AM
                                          • ptcriserx3
                                            Sony trinitron crt bowed and side color issues
                                            by ptcriserx3
                                            Hi
                                            Ive got a vintage 2001 sony trinitron flat tube tv
                                            The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
                                            See many images attached...
                                            Just windering if this is not fixable or something i can correct without getting too invloved
                                            Im trying to sell the tv
                                            06-17-2023, 07:27 PM
