Sony XBR-65X900C Sporadic Issues
+ More Options
Posts
  • budwich
    • Jul 2015
    • 3097
    Re: Sony XBR-65X900C Sporadic Issues
    Originally posted by Michale32086
    I did check the 5V off the USB just for sheets and greens.
    I initially got a solid 5V reading but then it faded and went to wild fluctuations.. This was on the 55X TV...
    I didn't get a 5V again, even when the Power LED showed it was "on"...
    I get the exact same cycles on the 55X that I did on the 65X..
    Power LED comes on, fades,comes on, fades, then comes on real bright, then fades, then an orange/green LED.. Interesting to note that, the longer I let it cycle, the more orange/green flashes I see.. Starts off with 1 of each, after a few mins, 2 of each etc etc..
    I also noticed that the Optical Audio laser only comes on for a brief moment. In a working environment, the red laser usually stays on all the time.
    So, I am guessing I got a bad board..
    Ah... but... sorry if I don't understand, this is the result with the "new" card put in either the 65 or 55... right? If so, you can confirm these "results" by putting back the working 55 card in the 55 and see what you see.
    It is quite likely that the "new card" is bad but again, this "playing around" was intent to see if you could locate a replaceable component on the card as opposed to shelling out the $300... at least that was my hope. :-)
    • Michale32086
      • Nov 2011
      • 1453
      Yea, that's with the "new" card...
      Let me put the working board back in and repeat the check..
      One sec
      • Michale32086
        • Nov 2011
        • 1453
        Yea, the working board in the 55X gives me a solid 5V off the USB...
        • budwich
          • Jul 2015
          • 3097
          OK... you might want to carefully see if you can track where that 5v is coming from / being switched or otherwise. You could do this visually or via a meter (again carefully). You might get lucky and find a component along the way... and then check to see if similar / same component exists on the "bad cards".... maybe.
          • Michale32086
            • Nov 2011
            • 1453
            Will backtrace the 5v and see what I can see..
            Thanx
            • Michale32086
              • Nov 2011
              • 1453
              Well, it's been a long and winding road..
              But at the end of it.. SUCCESS!!!
              A nice nifty 65" Sony Android TV...
              A replacement board did the trick..
              Again, I want to thank everyone that chimed in.. All the help was VERY much appreciated..
              • nomoresonys
                • 12216
                • U.S.
                #87
                Good to hear.
                • nomoresonys
                  • 12216
                  • U.S.
                  #88
                  Originally posted by Diah
                  your TV issue are communication between ram and main processor i think.. as you plug it with LAN all recommend apps and smart apps loading and they occupied the ram so there are no more space to let the firmware run. CPU are responsible to clear the ram and load other script. you can repeat this methode how much you can till clear it.. this will never harm the set at all. other wise you need to reflow the cpu or ram.
                  Happy new year Diah, so if I do this like 10 times, it should clear out the ram? the more it's done the more room available til it's clear, about how many times you think should clear it if so? thanks.
                  • nomoresonys
                    • 12216
                    • U.S.
                    #89
                    I have voltage on the bl error pin on the ld board, does that mean its strictly a backlight issue or can the ld board itself be the problem?
                    • HarryZ
                      Sony XBR-49X800G networking issues
                      by HarryZ
                      Aloha. First post here, hope I can find someone to assist me.
                      I have a Sony XBR49X800G with streaming issues. The issue mostly occurs watching sporting events (basketball and football). The picture will sometimes get pixelated, sometimes freeze for a few seconds while the audio continues, sometimes it's jerky. In other words, you get a headache watching the TV.
                      My ISP provides 500 Mb service and I have verified that I have at least 500 Mb on ethernet, and something over 300Mb on WiFi. I installed Analiti on the TV (it's an Android TV) and I get ~ 70 Mb on both WiFi...
                      01-26-2024, 04:49 PM
                    • cheeky2
                      Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
                      by cheeky2
                      I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
                      Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
                      The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
                      Details:...
                      08-17-2023, 04:34 AM
                    • Carlos#2003%
                      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                      by Carlos#2003%
                      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                      02-15-2024, 07:52 PM
                    • PontyPCs
                      Sony Android TVs eMMC Issues
                      by PontyPCs
                      Hi people.
                      I have been trying to get my head round these issues with the eMMC putting the TV in to a boot loop condition, or completely dead, when a dump of the Boot 1, Boot 2 and USERDATA partitions have been made, the MLC lifetime counter has been reset, using the original eMMC with the RPMB partition intact and the eMMC is flashed with the original dump, Netflix and a few other Apps don't work. i assume all the DHCP keys and factory programmed RPMB access Key will be contained within the original dump, and as we are re-flashing the original eMMC i would expect every thing to work....
                      12-10-2023, 10:43 AM
                    • ptcriserx3
                      Sony trinitron crt bowed and side color issues
                      by ptcriserx3
                      Hi
                      Ive got a vintage 2001 sony trinitron flat tube tv
                      The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
                      See many images attached...
                      Just windering if this is not fixable or something i can correct without getting too invloved
                      Im trying to sell the tv
                      06-17-2023, 07:27 PM
