Lg 55ls4500
  • aeboyer
    • May 2019
    • 5
    • United States of America
    Lg 55ls4500
    I got this tv tonight for free of a guy on Craigslist and this is what happens (image attached). I haven't opened it up yet but I'm not sure if it is the LCD panel, T-Con board, or something else. Looking for any possible advice.
    https://imgur.com/a/aXKdIsX#aJBn2CM
  • aeboyer
    • May 2019
    • 5
    Re: Lg 55ls4500
    Image attached
      Re: Lg 55ls4500
      We will need to see the pictures of the whole back side of the TV showing all the boards.
      Something like this I would try having the cable between the T-CON board and the LCD panel connected one at a time to see what you get on the screen, also do the Voltage testings on the test points on the T-CON board.
      • aeboyer
        • May 2019
        • 5
        Re: Lg 55ls4500
        I can't get a multimeter until tomorrow to test voltages but I opened it up and checked the pictures with just one cable attached at a time and here is what I got. Ignore the smudge and the glare in the first picture, There are no lines just a black screen.
          Re: Lg 55ls4500
          https://www.shopjimmy.com/lg-6871l-2...con-board.htm#
          This looks to be using the same blank PCB as your board but I am not 100% sure since I cannot read the white silk screen as printed on your board.
          Please verify.
          There are many Voltage test points in that T-CON board that need to be checked.
          • aeboyer
            • May 2019
            • 5
            Re: Lg 55ls4500
            I bought a t-con board off of ebay and it still does the same thing, no change. All the connections are tight and everything. Would I be correct in thinking it's either the main board or a bad panel and which would be more likely?
              Re: Lg 55ls4500
              You need to test the Voltage test point on the T-Con as suggested in post #5 to find out if they are OK or not, that may tell you if you have problem in the LCD panel or not. The problem can be as simple as shorted cap in the tab bonding boards.
              • budwich
                • Jul 2015
                • 3097
                Re: Lg 55ls4500
                the fact that you got another tcon with the same result (is it exactly the same result with the one cable at a time connected?) likely indicates it is not a tcon problem. Further, the one picture that shows a white side (probably the detached side) with the other side showing lines (vertical) is not a good sign. The picture showing the opposite "setup" does not show the white screen on the disconnected side further indicates similar problems especially with the band of vertical lines now on the other side.
                As budm suggested, you may get lucky and find a bad component (capacitor or resistor) in the bottom edge board that that cables connect.
                • advant
                  by advant
                  02-03-2020, 12:25 AM
                • netgearnetgear
                  TCL 43S423 TCON OR PANEL FAULTY???
                  by netgearnetgear
                  Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                  08-20-2025, 06:04 PM
                • Daren87
                  Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                  by Daren87
                  I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                  08-13-2023, 03:25 PM
                • alltvrepairs
                  Lg TCon test pins for screen test
                  by alltvrepairs
                  i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                  Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                  Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                  Appreciate your help....
                  06-13-2025, 06:33 AM
                • angelos
                  TCON and self diagnosis!
                  by angelos
                  Hi Guys.
                  I have experienced something rather unique and need to find out by the forum what to make of it.
                  I got in this set, a JVC or Telefunken LED TV whose complaint is that sometimes the set comes up blank with the back lights running. So I switched on and yes there was a blank screen and back lights were running. I checked the fuse on the TCON and sometime later I lifted the set off the table to check the image (the TV has no feet to let it stand upright) and noticed the set was cycling red, green blue, test pattern, blank then all over again doing this. Suddenly the no signal...
                  09-19-2022, 03:05 AM
