LG 37lv375s no 24V
  • R_J
    • 9514
    Re: LG 37lv375s no 24V
    I would start checking that inv_on line back to the main board
    • chrle
      • Sep 2013
      • 158
      • slovakia
      how?
      • R_J
        • 9514
        Follow the wire back to where it comes from, then check the components, If you look at the service manual it does give some direction where to look, search the manual for inv_on or inv_ctl etc. to follow the path
        • chrle
          • Sep 2013
          • 158
          • slovakia
          I found this manual
          • chrle
            • Sep 2013
            • 158
            • slovakia
            think I found what I need
            • chrle
              • Sep 2013
              • 158
              • slovakia
              #26
              Problem is on mainboard....
              • chrle
                • Sep 2013
                • 158
                • slovakia
                #27
                I will try to reflow main processor...
                  You can try forcing on the backlights circuit by disconnecting the INV_ON (BL-ON) wire going back to the main board first then use 1K resistor between BL-ON pin and standby power supply pin to force the backlights on, if the backlights are on but you do not see any video, or sound, or other functions then it has more than just the BL-ON controlling problem.
                  • chrle
                    • Sep 2013
                    • 158
                    • slovakia
                    #29
                    Ok guys I replaced main processor ,volltages are same...
                    I will try forcing backlight with 1k resistor
                    • neilc6
                      • Nov 2015
                      • 1550
                      Did you replace the processor or the main board. LV series has bga issues.
                      • chrle
                        • Sep 2013
                        • 158
                        • slovakia
                        #31
                        yes I replaced with new processor
                          • 12075
                          • U.S.
                          #32
                          Did you do this?
                          • chrle
                            • Sep 2013
                            • 158
                            • slovakia
                            #33
                            Did you do this?
                            no, I am going to electronic store to buy 1k resistor, I have low ohm resistors at home.
                            • chrle
                              • Sep 2013
                              • 158
                              • slovakia
                              #34
                              ok guys it turn on backlight with 1k resistor
                              but no picture or sound
                                • 12075
                                • U.S.
                                #35
                                Looking like a mainboard fault.
                                • gabri2211
                                  external hd Seagate, broken down the +12 volt and USB 3.0 SATA board
                                  by gabri2211
                                  Hi to all 😎
                                  I'm looking for any useful information to repair this interface (I have attached the image).
                                  On this board I read E3215-1215A_4D.
                                  This is the small plate inside the HD enclosure that allows to connect a 12 volt power supply, interface the disk with a USB 3.0 socket and is connected to the HD with the SATA connector.
                                  If any of you have found a burnt or short-circuited component in a circuit like mine​, if you have useful diagrams for the repair, or even better a description for the tests at the test points, I would be very grateful.
                                  in particular...
                                  11-12-2024, 08:08 PM
                                • GRANDGG
                                  LG 42lw4500 flashing red light , wight light , 2 clicks
                                  by GRANDGG
                                  Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
                                  05-09-2025, 12:27 PM
                                • CapLeaker
                                  LG 65UQ70 horizontal bars jumping
                                  by CapLeaker
                                  So I bought this LG 65UQ70 today at Walliworld. Put the wall mount on, set it up, worked for 30 mins and then I get these jumping horizontal bars. Let the TV do updates and let it cool down for 5 mins. Worked perfect for 2 mins. As soon the TV is warm I get the jumping vertical bars again.
                                  Keep the other TCL thread in mind. Now I am questioning are all COVID 2022 / 23 TV’s bad or what? That’s two 65” TV’s one from Amazon and this one from Walmart. What are the chances on that?
                                  I guess this one goes back either later today or tomorrow morning, unless...
                                  08-13-2024, 09:41 AM
                                  Using a 5 volt @ 12 amp switching power supply and two USB doctor volt / amp meter to three IPads on one power supply
                                  by sam_sam_sam
                                  I have been wanting to do this project for some time using a Mean-well switching power supply that I bought at least ten of them that were originally in a device that was abandoned for some reason they were listed new but removed from equipment that was never used
                                  I do not understand Mean-well the capacitor next to the voltage reference ic chip was a brand that is known for failure over time the other capacitors are brand name needless to say it got replaced before I even powered it on for the first time
                                  I used a four USB outlet and electrical plate that is made for...
                                  08-03-2024, 07:54 PM
                                  I need to order some 1000uf @ 16 volt it has to be 8mm in diameter what is a good choice
                                  by sam_sam_sam
                                  Here is the page of capacitors that I can choose from what is a good choice for a FSP 400-60GLC
                                  https://www.digikey.com/en/products/...Xmc1YPJ6BlESoA
                                  I try to use a 565-1664-ND which is a 10mm in diameter unfortunately it will not fit because there are two of them the same size and value and there is no room and they go to two different circuits not in parallel...
                                  08-03-2024, 02:54 PM
