I need to order some 1000uf @ 16 volt it has to be 8mm in diameter what is a good choice
    • Jul 2011
    • 6070
    Here is the page of capacitors that I can choose from what is a good choice for a FSP 400-60GLC
    https://www.digikey.com/en/products/...Xmc1YPJ6BlESoA
    I try to use a 565-1664-ND which is a 10mm in diameter unfortunately it will not fit because there are two of them the same size and value and there is no room and they go to two different circuits not in parallel if that was the case I put a 2200uf @ 16 volt one in there and be done with it
    Even If I move the wire out of the way the coil is in the way and will push the diode lead right into the heat sink which would not be good
    I used a very old new ( probably over 10 years old at least ) Click image for larger version  Name:	IMG_0683.jpg Views:	8 Size:	1.25 MB ID:	3322022 1000uf @ 16 volt “FC” capacitor and after about a minute or so puff the capacitor blew it top the other one ok
    • Jul 2011
    • 6070
    For some reason it is not letting me edit my post
    I going to change all of the “FC” capacitors just in case something is wrong with them because of there age
    • redwire
      • Dec 2010
      • 3912
      I would consider using a polymer cap 1,000uF or 1,200uF 16V 8mm dia (LS=3.5mm?) mainly because they have lower ESR 8mΩ verses 29mΩ and can take higher ripple current 7,500mA verses 1,500mA (ZLH).
      https://www.digikey.com/en/products/...MDS1KX/7427966 1,200uF LS=3.5mm and there is a LS=5mm one. Longer life 5,000hr parts are all 10mm dia.
      https://www.digikey.com/en/products/...MDS1PX/7427964 1,000uF LS=5mm
      https://www.digikey.com/en/products/...02MDS1/7427962 1,000uF LS=3.5mm
      Or... I have stuffed in 10mm parts but let them sit high above the board, you have height room.
        • 31262
        polymer rarely works in switching psu's - the ultra-low esr is often mistaken for an overload
        no harm trying though.
        otherwise panasonic FR comes in 8x20mm
        • redwire
          • Dec 2010
          • 3912
          They are usually undersized in the first place in these PSU's. I think one of those caps is for the -12V rail and not critical, muh RS-232 driver lol.
          The FR ESR is 30mΩ and 1,560mA ripple current which isn't much for the +12V rail for any cap really. Surely there are a few in parallel for that. Sam should see what rails they are for and why the new FC smoked, maybe too much ripple current.
          I'm saying the caps are too small in the first place, upsizing them and/or going for polymer low ESR is pretty much mandatory. And this board is for six different models/power ratings - How do you pull that off in the same amount of room Mr. FSP?
          All my newer PC PSU use polymers to get the 7 year warranty. Fingers crossed.
            • 31262
            if a cap explodes i would check none of the diodes have shorted and hit the cap with high frequency AC
            • redwire
              • Dec 2010
              • 3912
              It's always when I put them in backwards lol. So many distractions. Now I double-check polarity and put a red felt pen mark on the top of a cap to show I've checked that, it also tells me I've replaced that.
              • ssl6
                MSI K7T266 Pro (Ver. 1.0)
                by ssl6
                Hey Everyone,
                Long time lurker, but I think this is my first time posting.
                Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
                I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
                11-09-2023, 01:00 PM
              • gabri2211
                external hd Seagate, broken down the +12 volt and USB 3.0 SATA board
                by gabri2211
                Hi to all 😎
                I'm looking for any useful information to repair this interface (I have attached the image).
                On this board I read E3215-1215A_4D.
                This is the small plate inside the HD enclosure that allows to connect a 12 volt power supply, interface the disk with a USB 3.0 socket and is connected to the HD with the SATA connector.
                If any of you have found a burnt or short-circuited component in a circuit like mine​, if you have useful diagrams for the repair, or even better a description for the tests at the test points, I would be very grateful.
                in particular...
                11-12-2024, 08:08 PM
              • Yanleb
                Sharp LC-60LE810UN Lamp Error
                by Yanleb
                I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
                I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
                Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
                I've tried all the key...
                08-24-2021, 11:48 PM
                Using a 5 volt @ 12 amp switching power supply and two USB doctor volt / amp meter to three IPads on one power supply
                I have been wanting to do this project for some time using a Mean-well switching power supply that I bought at least ten of them that were originally in a device that was abandoned for some reason they were listed new but removed from equipment that was never used
                I do not understand Mean-well the capacitor next to the voltage reference ic chip was a brand that is known for failure over time the other capacitors are brand name needless to say it got replaced before I even powered it on for the first time
                I used a four USB outlet and electrical plate that is made for...
                08-03-2024, 07:54 PM
              • bembeno
                Adapter 24 volt problem
                by bembeno
                I have 24 volt adapter when i measure its output with multimeter i found the 24 volt is good put it dosent charging the battarey of Electric wheelchair i tried another adapter and charging thr battarey what can be the problem
                06-06-2024, 12:32 AM
