47ls4500 screen has rainbow color.
  • capwizard
    • Jun 2016
    • 1991
    47LS4500 screen has rainbow colors or solarized distorted picture.
    I've changed T con still the same.... rainbow color. should I order the main board or just give up and they want me fix tomorrow or tv just needs reconfiguration.
  • petehall347
    • Jan 2015
    • 4439
    • United Kingdom
    Re: 47ls4500 screen has rainbow color.
    try turning colour and contrast down . might not help but worked once for me with a pc monitor
    • capwizard
      • Jun 2016
      • 1991
      Thank you. tv really works. I probably just charge customer half the price. tv really improves a lot.
      Maybe someone changed main board with different panel no?
      • DXseekerMO
        • Feb 2018
        • 1119
        • US
        I had that exact same problem on a 55" Vizio E550i-B2 and it was the LVDS cable. I wiggled it and got a change of picture state. Removed it and the contacts were swayed. Replaced it with one from the parts pile and it worked great!
        They call me......."threadkiller"
        • capwizard
          • Jun 2016
          • 1991
          thank you, i will try it tomorrow.
          • petehall347
            • Jan 2015
            • 4439
            • United Kingdom
            try less colour . match skin colour to reality .
            • capwizard
              • Jun 2016
              • 1991
              Update
              I've changhed LG main board and the t-con board so the problems are on the screen itself. thanks for everybody helped.
                I have never seen bad LCD panel that will cause bad GAMMA like that, you need to check GAMMA reference Voltages on the T-CON board.
                • budwich
                  • Jul 2015
                  • 3097
                  you might want to get into the service menu and check things out there. Some settings may deal with panel settings such as the number of bits the panel supports along with the type of color system used. further, what inputs have you used / are available (ie. rgb, hdmi, composite).
                  • capwizard
                    • Jun 2016
                    • 1991
                    I've changed 4 main boards and 5 T con boards still are the same problems.
                    • capwizard
                      • Jun 2016
                      • 1991
                      I tested with rf signal but it happened on manu also.
                      I've spend almost two days I still can't go into the service menu.
                      • R_J
                        • 9588
                        You likely need the (@R$%^) service remote to access the service menu The remote has a [IN-START] button on it
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          Lg in start tv remote app
                          • capwizard
                            • Jun 2016
                            • 1991
                            How to Make an IR Blaster
                            https://www.instructables.com/id/How...an-IR-Blaster/
                            i did make an IR Blaster but my LG phone does not have On-The-Go (OTG) capability. i've down load the APP with an [IN-START] button but i cant use it.
                            • budwich
                              • Jul 2015
                              • 3097
                              not sure about what the OTG capability gives you BUT basically all you need a "wav file" which you "play" that results in the proper "ir wav" when the "leds" are connected to your headset outputs on your phone / any phone.
                              • capwizard
                                • Jun 2016
                                • 1991
                                vinceroger69 sent me the ZIP files, I didn't knew what was what, after your interpretation, i unzip the file, found the EZ_ADJ .wav IN_START.wav IN_STOP .wav POWER_ONLY.wav . i will try it tomorrow
                                • R_J
                                  • 9588
                                  If you can get into the service menu with your phone, you should be able to use a regular lg remote after that to navigate the menu/settings
                                  • capwizard
                                    • Jun 2016
                                    • 1991
                                    Thanks to all my friends.
                                    I spend whole morning. I still cannot figure out how to do it. I even use Bluetooth hook up IR booster right into speaker. I ended up ordered a $5.84 service LG remote controller.
                                    • Diah
                                      • Feb 2013
                                      • 6437
                                      with wav. file need to make DIY IR LED and speaker or headphone jack. insert it at pc speaker out. then play the wav file with (Windows Amplifier ) player on pc windows.. only on this player the code will sent correctly as its
                                      • capwizard
                                        • Jun 2016
                                        • 1991
                                        Thank you, do you mean, I cannot use my cell phone connect to Bluetooth with the homemade IR booster connect right to the speaker.
                                        I heard the pop noise at beginning then were the strings of code sounded.
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • spice_disc
                                          Vizio TV M50-C1 reboot cycle and static on screen
                                          by spice_disc
                                          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                          09-08-2024, 02:37 PM
