LG 42LK520 Stuck on LG Logo screen even without TCON?
  • jason123
    • Oct 2015
    • 1136
    Hi Folks,
    Just picked up this TV and the symptoms are non-responsive. It turns on, you can see the LG logo, when you click the menu button, you can tell that the upper left corner is changing but the LOGO overlay is on the screen.
    The weirdest thing ever is if I power it up with the 2 ribbon cables form TCON to Panel disconnected the LOGO is still visible / DIM. It's like the logo is stuck on the panel (in color so not burnt in)
    When I disconnect one of the ribbon cables, one side goes black and the other side has logo but the upper strip is white just like when you activate a menu. When I disconnect the other ribbon cable, the other side goes white but logo overlay is still on that side! very odd!
    Labeled voltages seem to check out.
    20 V and 3.5 from power board to Main card are at 20.32 V and 3.38 V
    12 V to TCON is 12.03V
    I see various voltages on the boards - not labeled so I don't know variance over nominal
  • ducky29
    • Dec 2015
    • 369
    • Europe
    Re: LG 42LK520 Stuck on LG Logo screen even without TCON?
    Maybe you might have severe screen burn in.
    • jason123
      • Oct 2015
      • 1136
      I considered that, but the logo goes away on one half when you disconnect both ribbons. See photo ...other thoughts?
      • petehall347
        • Jan 2015
        • 4448
        • United Kingdom
        which cables are you disconnecting ? out or in ?
        • R_J
          • 9623
          Looks like he is disconnecting the lvds cables not the cable between t-con and panel.
          • jason123
            • Oct 2015
            • 1136
            Cables from TCON to panel [out]
            • petehall347
              • Jan 2015
              • 4448
              • United Kingdom
              most odd .. seems like that panel has a memory of some sort .
              • jason123
                • Oct 2015
                • 1136
                I am perplexed also...i would like to part it out and sell the main board tcon and power .. but i want to make sure they're not defective
                • petehall347
                  • Jan 2015
                  • 4448
                  • United Kingdom
                  to be sure remove all cables from t con and try again
                    So all you have is backlights, no active circuit connected to the LCD panel so all the pixels are dead but yet you can see color image on the screen, makes mo sense to me.
                    • jason123
                      • Oct 2015
                      • 1136
                      You're seeing what i am seeing...i have no clue what's going on. I am open to suggestions and and tests... i just want to make sure i don't sell bad parts
                      • petehall347
                        • Jan 2015
                        • 4448
                        • United Kingdom
                        reverse engineer the panel i say .. i dont have the knowledge for that by the way as just learning
                        • jason123
                          • Oct 2015
                          • 1136
                          Update... accidentally touched the tcon and picture on screen updated. Repeated touching in that area seems to get it going temporarily suggesting TCON problem?
                          • Diah
                            • Feb 2013
                            • 6560
                            at yours first post photo the T-CON was unprotected with Metal shield. this mean allot, at this point there are some damage at LCD where no discharge from LCD .
                            1- did the TV go to standby mode ? if yes
                            2 send command IN STOP to discharge eeprom and whole set to factory condition.
                            i posted over here apk on android can do this job within any mobile had IR sender.
                            • jason123
                              • Oct 2015
                              • 1136
                              I got rid of my last android S6 with ir
                              The tcon has a metal shield...i took ot off for the photo and to measure voltages
                              • jason123
                                • Oct 2015
                                • 1136
                                replaced the TCON board and the TV is working great. Thank you all for the help!
                                • jason123
                                  • Oct 2015
                                  • 1136
                                  A bit pre-mature celebration. So TCON seems to have fixed the issue. I watched one full movie, and it was great. This morning, went to turn it on, and the same problem as before. Logo screen overlay is stuck on the screen. Help!
                                  • maxvalutech
                                    • 804
                                    • australia
                                    I'm no expert but doesn't tcon have an erase circuit and as its only the logo that doesn't erase then it would seem the that the ic on which that logo is stored isn't switching off its transmission once displayed at start. The model I'm working on now shows logo at switch on for a few seconds it then goes off as do backlights I think then they switch on again with TV going and menus etc available. If this is usual for LG sets it indicates two separate processes take place. The set I'm working on does have backlight problems.
                                    • Stunt
                                      Hp Laptop Stuck on Hp protected by hp sure start screen
                                      by Stunt
                                      Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                      I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                      I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                      Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                      screen that's it and stuck there. I left it until the following day and i still...
                                      09-02-2025, 01:51 PM
                                    • Daren87
                                      Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                      by Daren87
                                      I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                      08-13-2023, 03:25 PM
                                    • conghuyms
                                      MacBook Air A2179 stuck logo , pls help me !
                                      by conghuyms
                                      Hey everyone,
                                      I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
                                      When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
                                      I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
                                      11-05-2025, 08:30 AM
                                    • abajor
                                      A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
                                      by abajor
                                      Having this very weird issue.
                                      The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
                                      I swapped with a working screen from an A2141 waiting for parts.
                                      The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
                                      The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
                                      04-27-2024, 01:37 PM
                                    • alltvrepairs
                                      Lg TCon test pins for screen test
                                      by alltvrepairs
                                      i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                                      Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                                      Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                                      Appreciate your help....
                                      06-13-2025, 06:33 AM
