Vizio E55-D0 Picture Flashes
  • Tech 57
    • Aug 2014
    • 37
    This TV has the video flashing
    When no signal is there or hdmi is connected it flashes
    if i remove the attenna it says no signal backight is steady so i dont think the backight strips are bad.sounds like a main board.
    What's your Opinion Thanks phil
  • R_J
    • 9546
    Re: Vizio E55-D0 Picture Flashes
    When there is no signal the backlights are usually lowered, so it still could be a backlight issue, Go into the menu and lower the backlight adjustment and see if the flashing changes.
    • Tech 57
      • Aug 2014
      • 37
      So you think bad led strips?
      I guess i should strip the panel down
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Is everything else working?? This points to a backlights issue. and RJ is correct. Probably try turning the Backlight Level down (not the Brightness or Contrast Levels) to about 55%. That may give you a temporary fix.
        • Tech 57
          • Aug 2014
          • 37
          ok i did lower the backlights setting to dark in the menu setting it stopped so that means backlight strips are bad?
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            That's a roger!!!!
            • caphair
              • Nov 2011
              • 1249
              I have this same issue. On the led driver board there are test points for each led strip.
              LED 10 measures 0v
              LED 6 - 9.2v
              LED 5 - 9.2v
              All other strings have 12.5v sometimes measured 14v
              45v at the Vout test pins
              So I’m guessing the LED 10 strip has failed completely? But I’m wondering why 5 and 6 have lower voltages compared to the others. Separate issues on their way out?
                You have ten LED strings so it has 10 MOSFET'S on the LED driver board for the Cathode return for each LED string, the Cathode of each LED string is connected to the Drain pin of each MOSFET so if the string has open circuit then you will not have Voltage on the drain pin.
                Looking at your cutoff picture I cannot read or tell what the pin names are, too small for my eyes to see.
                • caphair
                  • Nov 2011
                  • 1249
                  So each string is being independently driven as oppose to having one huge voltage put through all strings tied in series like other TVs?
                  What's the 45v out then? There's 4 pins total labeled Vout, 2 pins on 2 connectors where the led strings are split up
                    The 45V is for feeding the Anode of each LED string , the Cathode return of each string is connected to the PWM controlled MOSFET DARIN for maintaining the constant current through each LED string, the source is connected to the current sensing resistor, the other end of the resistor is connected to circuit GND.
                    Your TV has local dimming backlights that adjust itself based on video content.
                    • caphair
                      • Nov 2011
                      • 1249
                      Ah ok. Didn't know it had local dimming. Looking at it for a friend. Is that why the backlights flash when powered on because one string is open?
                      Are the other two strings measuring lower voltage due to dimming or an imminent failure of the strings? Btw no source connected to the tv so just a “no signal” when on
                        The string that has open circuit will show 0V on the Drain pin of he MOSFET on that LED driver board, so how may of them show 0 V on the Drain pin?
                        The protection circuit probably kicks in die to no current flow detected.
                        This is where LED tester comes in handy when you have to test 10 LED strings.
                        • caphair
                          • Nov 2011
                          • 1249
                          Only the LED 10 shows 0v. Led 5 and 6 show 9v and the rest are 12v. The led driver board has two test points for each led string labeled.
                            If that is the case then it looks like it has open circuit.
                            There are more than one model of LCD panel used in this TV.
                            https://www.shopjimmy.com/catalogsea...q=Vizio+E55-D0
                            • caphair
                              • Nov 2011
                              • 1249
                              Would that one open circuit cause low voltage on the other two led strings?
                                You have 10 separate control circuits for 10 LED string.
                                The lower the Voltage on the return pin the more current through the LED string that is because the on time of the MOSFET will on longer so the Vdrops between Source and Drain will be less.
                                You can find out if LED 10 string has open circuit or not by swapping LED 10 return wire with other LED return wire and see if the 0V reading will follow or not, or you can have just one LED string connected one a t time and see if each one of them will come on or not, or you can use power supply (set current limit to about 50mA ~ 100mA) that ha high enough Voltage to drive the LED string and test each string.
                                • SS454
                                  vizio e650i-a2 backlight flashes then turns off
                                  by SS454
                                  vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                  panel: au optronics T650HVN05.4
                                  72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                  link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                  Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                  https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                  Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                  08-20-2020, 03:57 PM
                                • csmith
                                  Vizio D50u-D1 Powers up no picture
                                  by csmith
                                  I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                                  Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                                  supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                                  issue. Set will power up with remote but not power off....
                                  07-11-2025, 11:52 AM
                                • gavric
                                  Vizio M70-C3 Half picture is bad, main board on its last leg?
                                  by gavric
                                  Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                  When tv powers on vizio V logo shows nice on whole screen. picture 1
                                  When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                  When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                  When i click video to start playing picture goes black(like when you change...
                                  09-02-2021, 08:55 PM
                                • ggil44
                                  Vizio M65-E0 No Picture, No Sound
                                  by ggil44
                                  Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                  09-03-2024, 08:30 PM
                                • maricm
                                  Vizio m65-c1 picture flashing on and off on the screen
                                  by maricm
                                  HI all,
                                  hope someone point to the possible issue before I start buying replacement parts.
                                  Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
                                  Backlight stays on all the time,
                                  Sound works fine.
                                  screen keeps changing form black to full picture in about 1sec intervals.
                                  Picture looks fine with no visible artifacts.
                                  I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
                                  Disconnecting left and right ribbons on...
                                  11-25-2023, 06:32 PM
