Sharp LC-50LB481 Two fast blinks Backlight Turns Off No Picture
  • neilc6
    • Nov 2015
    • 1550
    This TV is model LC-50LB481C. Think C suffix is for Canadian version. U suffix for US so LC-50LB481U.
    It is branded Best Buy Recycles (Best Buy repaired and resold??). It is missing 2 ground screws on the PS board, 1 ground screw on the main board and both the tcon shield and screws. I borrowed some screws from the cable clips to ensure it was grounded.
    When first plugged in, backlights come on for a few seconds, a quick bright backlight flash and then goes out. No picture.
    When power button is pressed, TV attempts to boot, front led slow blinks, millisecond quick backlight flash and front led goes out.
    When power button pressed second time, hear a click and front led has fast 2 blink code.
    PS connector
    ON/OFF 3.9V
    +12-A 0V
    +12V 12.1V
    +5V 0V (problem? or unused)
    DIM 3.0V when backlights are on, 3.6V/3.9V when not on
    PS_ON 3.4V
    main filter caps = 159V
    LED strips test good with tester - voltage 62V, 63V
    3 red/black pairs going to LED strips, 2 of the pairs are wired in parallel
    Backlights off 48.7V, 48.8V
    Backlights on 56V, 56V
    Anyone have service manual for 2 blink code? Power supply??
  • mmartell
    • Oct 2013
    • 3189
    Re: Sharp LC-50LB481 Two fast blinks Backlight Turns Off No Picture
    No Picture meaning you've done the Flashlight Test ?
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      So you have no +12-A or +5V when you power up the set?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        There are two sets of wires on the connector that goes to the Main Bd. from the PSU. What are the pin Nos. and labels for this connector and what are the voltages you get on each of the pins at plug-in to ac and when the Pwr button is pressed??
        • neilc6
          • Nov 2015
          • 1550
          There is no picture when the backlights are on. TV attempts to turn on but fails, backlight is on for a few seconds before turning off. Measure 12V on both sides of tcon main fuse.
          ON/OFF - 3.5V after plug in, drops to 2.9V after power is pressed and settles to 3.9V
          +12V - always at 12.1V
          +5V - always 0
          +12-A - always 0
          DIM - 3.4V after plug in, 2.4V when backlight is on, 3.7V after
          PSON - 0V after plugin, 3.3V after power pressed
          Front LED is on after plugging in. Slow blinks after power is pressed. Backlights come on for a few seconds. A few more seconds and backlight has short bright flash. Slow blink stops after a few more seconds.
          You would think +5V would supply main board but I am getting PS_ON signal and standby LED.
          • neilc6
            • Nov 2015
            • 1550
            Ordered a used power supply board. I would assume more voltages would come up with the PSON signal.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              I am thinking you may have an LED Driver or LED Backlight issue.
              • budwich
                • Jul 2015
                • 3097
                while you are waiting for your board, you might try disconnecting the tcon to panel cables (two?) with power off and see what happens there after to see if sets comes up with lights.
                • neilc6
                  • Nov 2015
                  • 1550
                  I did try disconnecting the tcon ribbon cables one at a time and both and still no picture and no power up. The bright blink is a bit suspicious though.
                  • budwich
                    • Jul 2015
                    • 3097
                    both disconnected at the same time?
                      • 12276
                      • U.S.
                      Little more focused pic. of ps here: seems strange there's no 5v, maybe test powerboard by itself, see if your voltages are there. http://www.shopjimmy.com/sharp-pltvf...c-50lb481u.htm
                      • neilc6
                        • Nov 2015
                        • 1550
                        Disconnected both tcon ribbons and exact same behaviour. Unplugged main connector completely and have 12V but no 5V and no +12-A.
                        It is a Roku TV and missing the remote. I will need a remote in order to set it up if I can fix it since it can be controlled by a Roku app. Looks like it is missing 2 stand screws as well going through the instruction manual (only 1 per side).
                          +12V and +12VA are fed by the same 12V synchronous rectification supply, if you look at the bottom side of the board you will see that L9101 and L9102 are tied together on on end, so it is probaly measurement error.
                          The +5V pins are connected to the empty pad that is why there is no 5V. This TV uses 12V STBY.
                          http://assets.shopjimmy.com/media/ca...au4-bottom.jpg
                          • neilc6
                            • Nov 2015
                            • 1550
                            The top silkscreen doesn't match the bottom silkscreen. The bottom one is correct since I measure 12V on 12-A.
                            http://assets.shopjimmy.com/media/ca...51aau4-top.jpg
                            Top silkscreen
                            On/Off DIM
                            NC PS_ON
                            +12-A +12-A
                            GND GND
                            GND GND
                            +12V +12V
                            +12V +12V
                            +5V +5V
                            Bottom Silkscreen
                            On/Off DIM
                            NC PS_ON
                            GND GND
                            GND GND
                            +12-A +12-A
                            +12V +12V
                            +12V +12V
                            +5V +5V
                            Main board and tcon are now suspect as well. Disconnected LVDS and still same behaviour.
                              • 12276
                              • U.S.
                              Maybe try unplug connector from ps to mainboard and use resistor as jumper to self test the power supply, see if your backlights come on and you get the proper voltages.
                                Top silkscreen
                                On/Off DIM
                                NC PS_ON
                                +12-A +12-A
                                GND GND
                                GND GND
                                +12V +12V
                                +12V +12V
                                +5V +5V
                                Bottom Silkscreen
                                On/Off DIM
                                NC PS_ON
                                GND GND
                                GND GND
                                +12-A +12-A
                                +12V +12V
                                +12V +12V
                                +5V +5V
                                At this point the 12A should be present as you can see how the 12V A is connected to the source, the 5V is not connected to anything so there will be now Voltage there.
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  the other problem is that IF the error count for backlights and other errors has been set, you might have to do the "forced power sequence" (ie. channel and vol and cord plug in type thing) other wise, the set may not come on.
                                  • neilc6
                                    • Nov 2015
                                    • 1550
                                    This model only has one button. Dual function on/off and for input switching. Checking the part number for the main board, 756TXGCC0QK001, it came from a 39" Insignia Roku TV. Shopjimmy indicates two different main boards - 756TXGCC0QK026 and 756TXGCC0QK0040
                                      • 12276
                                      • U.S.
                                      Right, one of the 12 v is there and one is not, if I read it right.
                                      • Andrew F. Ali
                                        • Jan 2014
                                        • 2450
                                        • Trinidad & Tobago
                                        The StdBy voltage is 12V. DO NOT try to self-test the PSU by using 'a resistor'. You WILL damage your PSU altogether. If you want to self-test your PSU you can take two 1.5V batteries in series connected to the PS-ON and GND.
                                        • DXseekerMO
                                          TCL 55US57 backlights, no picture.
                                          by DXseekerMO
                                          So here we go with another screen short TCL. For this exercise left and right will be reference looking at the screen.
                                          The person I got this TV from said the color was bad in a vertical fashion about 1/4 of the way over the left side of the screen. Shortly after the symptoms below started.
                                          Power Supply, main and T-CON board are working.
                                          Symptoms: The TV has backlights but no picture with both FFC's attached to the T-CON and does not respond to the remote or buttons, and the TV appears to continuously re-boot.
                                          Unhook FFC from left side...
                                          09-18-2021, 03:56 PM
                                        • kca
                                          Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                                          by kca
                                          Hello all ~
                                          I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                                          This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                                          No picture. No sound.
                                          I tested all the voltages coming out of the power supply...
                                          10-12-2023, 05:23 PM
                                        • sordids999
                                          SAMSUNG UE43AU7020K BACKLIGHTS BUT NO PICTURE
                                          by sordids999
                                          Hi
                                          Really stuck on this TV
                                          I'm thinking it's a bad screen ?
                                          Voltages all seems good
                                          Tcon 12v ok
                                          Remove one tcon cable at a time no half image on the screen just backlight and no picture
                                          even tried the tape trick still no luck
                                          Thanks...
                                          05-12-2025, 10:36 AM
                                        • Mustang67ford
                                          Sharp LC-50LB370U PS or backlights?
                                          by Mustang67ford
                                          Hello all. Working on a sharp LC-50LB370U. A few days ago, I turned the tv on and immediately left the room, came back in and tv was black. Turned it off then on and all good (didnt think much of it at the time) for about a week. Did the same thing again but stayed black this time. When turning on, the word "sharp" is dimmer than normal I think then tv goes black. I do have sound and do have a display with the flashlight test. I trided unplugging and also holding in the power button for 30 sec, no change. I opened the back up and the backlights do turn on to some extent for a moment...
                                          11-12-2022, 08:32 AM
                                        • stinger
                                          Samsung UN70TU6980FXZA no sound no picture but does have backlights
                                          by stinger
                                          When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                                          04-17-2024, 03:06 PM
