SAMSUNG UE43AU7020K BACKLIGHTS BUT NO PICTURE
  • sordids999
    • May 2013
    • 2161
    • uk
    Hi
    Really stuck on this TV
    I'm thinking it's a bad screen ?
    Voltages all seems good
    Tcon 12v ok
    Remove one tcon cable at a time no half image on the screen just backlight and no picture
    even tried the tape trick still no luck
  • sordids999
    • May 2013
    • 2161
    • uk
    If I disconnect lvds cable one at a time on the tcon
    CLK1 to CKL10 is 9.8v
    If both lvds cables are connected then
    CKL1 to CKL10 is 0.00v
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4502
      • Italy - Milan
      maybe the spi flash on the tcon bad, they are prone to be polluted, try at least a replacement board..
      • sordids999
        • May 2013
        • 2161
        • uk
        Just an update on this TV issue changed the tcon and it's all working again
        P.s thanks Davi.p
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4502
          • Italy - Milan
          OK 😁 bye...
            09-07-2024, 05:50 AM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • stinger
            Samsung UN70TU6980FXZA no sound no picture but does have backlights
            by stinger
            When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
            04-17-2024, 03:06 PM
          • JJAAMM
            by JJAAMM
            Problem
            07-06-2023, 06:01 AM
          • shelby5041
            Samsung LCD TV no picture backlight on no 12v at tcon
            by shelby5041
            hi
            i have a samsung lcd tv
            it powers on with sound and backlight but no picture
            all voltages from PS are good 12v 3.3v and 5v
            whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
            i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
            no 12v at the tcon fuse
            i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
            the odds of having 2...
            10-08-2021, 08:21 AM
