Sharp LC-50LB370U PS or backlights?
  • Mustang67ford
    • Nov 2022
    • 5
    • Usa
    Hello all. Working on a sharp LC-50LB370U. A few days ago, I turned the tv on and immediately left the room, came back in and tv was black. Turned it off then on and all good (didnt think much of it at the time) for about a week. Did the same thing again but stayed black this time. When turning on, the word "sharp" is dimmer than normal I think then tv goes black. I do have sound and do have a display with the flashlight test. I trided unplugging and also holding in the power button for 30 sec, no change. I opened the back up and the backlights do turn on to some extent for a moment then off. Proceeded to take voltage readings, I am trying to determine if I have a backlight issue or a PS issue. I took voltage readings at the PS LED connector with reference to chassis ground. Here are the readings:
    Pin 1, V+, 1 wire, 65.6v, spike to 96.3v, back to 65.6v
    Pin 4, V-, 1 wire, 17.9v, spikes to 39v for a split second then quickly drops to what appears to be 0v, back to 16.8v
    Pin 9, V-, 2 wires, 17.9v, spikes to 39v for a split second then quickly drops to what appears to be 0v, back to 16.8v
    Pin 12, V+, 2 wires, 65.7v, spike to 96.9v, back to 65.7v
    Since I have voltage on the v-, I am getting a return voltage so the ICs seem to be working but not sure when it drops to 0v for a second. Only thing not able to isolate the 2 wire set on pin 9/12 without further disassembly. I also unpluggged the TV, unplugged the multiconductor cable to the main board, plugged tv in and no backlights came on. Any advice would be appreciated. Thank you in advance.
  • Mustang67ford
    • Nov 2022
    • 5
    • Usa
    Re: Sharp LC-50LB370U PS or backlights?
    Ended up removing the screen and checking the LEDs. There were a few out and a one in poor illumination compared to the rest. Turned it on to test the voltages with the screen off and getting 7 blinks, assuming that is because the screen is disconnected. Also, now no voltage on the LED connecter - side pin 4 and 9. New LEDs on order. Hopefully the 7 blinks I now have will go away with reassembly.
    • nomoresonys
      • 12322
      • U.S.
      I think they will, a second of backlight then nothing is a classic symptom of bad backlight/s.
      • Mustang67ford
        • Nov 2022
        • 5
        • Usa
        Thanks, good to know.
        • Mustang67ford
          • Nov 2022
          • 5
          • Usa
          New leds installed, back in operation.
          • nomoresonys
            • 12322
            • U.S.
            glad to hear it, another nice save, thanks for the followup.
              Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
              This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
              I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
              I am comparing them to a brand new one that I installed
              The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
              I going to let it run for several days before I remount back on the wall next to the...
              09-05-2024, 06:48 PM
              HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
              This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
              09-12-2024, 02:30 PM
              HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
              HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
              This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
              09-06-2024, 08:10 PM
              HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
              This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
