Vizio VW42L FHDTV10A will not turn on without unplugging and plugging TV back in
  • ken_taz
    • Jun 2018
    • 48
    Summary
    Vizio VW42L FHDTV10A will not power on without unplugging and re-plugging the TV back in several times.
    Problem
    The TV will not always act the same way when it is plugged in to try and get it to start up.
    First, I plug the TV in and get the Vizio logo to light up orange. Press the button to turn it on and nothing happens.
    I then unplug the TV and wait a few seconds and re-plug it back in. This time when I press the button, the Vizio logo turns white, but no back light comes on. During this time the outputs from the power board are as follows:
    [U]Outputs going to inverter board[U]
    24v = 24.9v
    SGND = .003v
    A = .12v
    B = .03v
    Outputs going to main board
    PSON = 3.18v
    12v = 11.5v
    SGND = .001v
    5v = 5.17v
    A = .12v
    B = .03v
    I then unplug the TV for a few seconds and re-plug it in again. This time when I press the button the logo turns white and the back light comes on. I also cannot turn the TV off when just the logo and backlight come on.During this time the only significant changes on the outputs are the A and B outputs.
    A = 3.34v
    B = 5.01v
    I can sometimes get the TV to come on and function properly. I've left it on for a few weeks at a time so as not to have to try and get it to turn on again, lol.
    Things Tested
    1 - The filter cap. on the PSU showed a voltage of just over 350v.
    2 - I could not find any visual evidence of bad caps throughout the whole system.
    3 - All fuses tested good. 1 on T-con, 1 on inverter, 2 on main.
    4 - I checked the voltages of the regulators on the main board.
    Main board regulators
    U20
    )11
    1084
    0739AL
    Pin 1 = .55v
    Pin 2 = 1.79v
    Pin 3 = 3.32v
    U19
    )11
    1084
    0739AL
    Pin 1 = 1.26v
    Pin 2 = 2.52v
    Pin 3 = 5.07v
    U15
    )11
    1084
    0739AL
    Pin 1 = 2.09v
    Pin 2 = 3.35v
    Pin 3 = 5.07v
    U22
    AMC1117
    F0748F
    Pin 1 = 2.10v
    Pin 2 = 3.36v
    Pin 3 = 5.12v
    U21
    AMC1117
    F0748F
    Pin 1 = .00v
    Pin 2 = 1.26v
    Pin 3 = 2.51v
    U17
    AMC1117
    F0748F
    Pin 1 = 2.10v
    Pin 2 = 3.37v
    Pin 3 = 5.07
    U44
    J302
    G9117
    Pin 1 = 8.46v
    Pin 2 = 9.72v
    Pin 3 = 11.42
    U16
    AZ7805T
    -E1
    748J13
    Pin 1 = 11.41v
    Pin 2 = .00v
    Pin 3 = 5.01v
    I have read many threads of different issues with Vizio TV's. I am looking for ideas on where and what to check. I am not an electrical Wiz, but do know enough to be dangerous, lol. If this TV isn't worth the time or money to repair I'll be bummed because the picture is, or was, very nice. I'm hoping to save it for in my bedroom to replace the 14" tabletop there now.
    I have attached pictures of the 4 boards.
    Thank you in advance for your help!
    Re: Vizio VW42L FHDTV10A will not turn on without unplugging and plugging TV back in
    When not working the BL-ON is not present, LED did not change from Amber to white.
    May be EEPROM problem:
    http://www.shopjimmy.com/vizio-vw42l...eprom-only.htm
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Originally posted by budm
      +10
      • ken_taz
        • Jun 2018
        • 48
        Originally posted by Andrew F. Ali
        +10
        What do you mean by +10, Andrew?
        • ken_taz
          • Jun 2018
          • 48
          Thanks for your reply, budm. So you're saying that the EEPROM could be the cause of it not turning on at all one time, and then turning on after multiple times of unplugging and re-plugging it back in, or just that it caused the TV to not turn on at all?
            Yes, but look real close at your main board P/N to make sure the EEPROM is made for that main board P/N and version.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              +10....means....I totally agree with the previous post.
              • R_J
                • 9623
                Try replacing CE13 & CE17, 470uf 25 volt on main board
                  Good eyes! it looks like one of them has slightly bulging top.
                  • ken_taz
                    • Jun 2018
                    • 48
                    Thank you R_J. I will replace those before I replace the EEPROM to see if that takes care of things. Wow, such a slight bulge on CE17 I never even noticed it. I tested both with my ohm meter and they did not respond. I will reply when I get them changed out.
                    • ken_taz
                      • Jun 2018
                      • 48
                      I replaced both CE13 and CE17 caps with 470uf 35v caps from my local Radio Shack. Thank you for spotting the tiny bulge in the one cap and knowing that the problem could lie in the two that you directed me to, R_J.
                      The TV fired right up and seems to be working fine. I haven't hooked up a video source yet, but I can switch to all inputs with the remote and it shows up on screen.
                      Thank you everyone!
                      • ken_taz
                        • Jun 2018
                        • 48
                        Well, I finally got around to hooking an old DVD player up that I had stored in my attic. I turned the TV on and switched it to the component input that the DVD was hooked up to. I ran into the house for a DVD and when I returned, the TV had turned off. I turned the TV back on after loading the DVD in the player. I had a picture for a few seconds and then it started making a loud buzzing noise thru the speakers and the picture had vertical lines across the whole screen. The TV then shut off after a few more seconds. I was able to turn the TV back on and go thru the same process again repeatedly. Oh well, I guess the caps weren't the only problem.
                          • 12328
                          • U.S.
                          Wouldn't be surprised if you have one or more bad caps on your powerboard still.
                          • angelos
                            • Dec 2012
                            • 573
                            • South Africa
                            I agree, change all the electrolytics on the main board.
                            • ken_taz
                              • Jun 2018
                              • 48
                              The power board and the main board are two different boards.
                              Change out all the caps on the main board? Do you have any idea how many there are on the main board?
                                BTW, I noticed that some of the those caps have black marking on the top. Did you do that or someone else worked on the set before you?
                                Did you try heating up the main board with hair dryer for a few minutes to see if the TV will come on normally?
                                Did you check the DC Voltage of the power supply outputs and the Voltages of the regulator ICs again when it is not working?
                                  • 12328
                                  • U.S.
                                  Looks like about `15 or 16. This is where a meter that can check capacitance is handy, otherwise it's a guessing game as to their operability.
                                  • ken_taz
                                    • Jun 2018
                                    • 48
                                    nomoresonys, you are talking about the main board, not the power board correct?
                                    The main board, which I have pictured below, has a total of approx. 72 caps. on it.
                                    The power board, in pictures two and three, has quite a few less than the main.
                                    I agree, it would be a much easier job to have a meter to check these caps. instead of playing the guessing game. Lol
                                    • ken_taz
                                      • Jun 2018
                                      • 48
                                      budm, No, I didn't put the marks on there. I bought this TV brand new, so it must've been done at the factory.
                                      I heated the main board up and the TV turned on and stayed on without any vertical lines. The only thing is now there is no sound at all. The vertical lines and the sound are related I'm sure.
                                      I tested the output voltages and the regulators while nothing was working, except for the logo and the back light. Everything tested the same as stated in my findings from my original post except that it now has the 5.01v at pin B and 3.35v at pin A. I did notice that when I got the TV running the voltage at pin A varied quite a bit while a video was being played, 1.75v - 3.25v.
                                      • petehall347
                                        • Jan 2015
                                        • 4448
                                        • United Kingdom
                                        ce23 ce50 dont look good from here .. if they turn out bad change all same values on that board .
                                        p.s where do the speakers plug in ? i am failing to see an audio chip .
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • howardc64
                                          Vizio SmartCast TV software bug that looks like hardware
                                          by howardc64
                                          Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                          It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                          11-16-2024, 05:17 PM
