Lightning strike Digihome 65240fhdledcntd
  • Scoobydo
    • Jun 2018
    • 16
    Hi, Tv was on at the time and plugged into rooftop aerial. Lightning struck house next door. Other houses 200yds away have blown tv's (with no roof top aerial) and broadband routers OOS. The RCD tripped in the property, fuse in mains lead also blew. Aerial drop lead from the roof frazzled in various place with the conductors melted away.
    Got no standy light on the tv. Power board is vestel 17PW-03-9. The internal fuse T 3.15a 250v is open circuit. Can I change this for a cartridge fuse and see if power is restored? Have bridged fuse and checked across the 240v power input in diode mode on DMM and this is open circuit.
    Thanks in advance for any help
  • Scoobydo
    • Jun 2018
    • 16
    Re: Lightning strike Digihome 65240fhdledcntd
    When checking the quality of the uploaded file I noticed that the mosfet on the left I couldn't read the numbers on it
    • mmartell
      • Oct 2013
      • 3189
      Wipe it down with a q tip and IPA.
      • Sparkey55
        • Jan 2010
        • 1523
        Trying to troubleshoot a lightning strike victim can be very difficult because of multiple entry points for the high voltage, being power line, antenna and near field entering via connecting cables and other wires. Could be a lost cause.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Originally posted by sparkey55
          trying to troubleshoot a lightning strike victim can be very difficult because of multiple entry points for the high voltage, being power line, antenna and near field entering via connecting cables and other wires. Could be a lost cause.
          +100
          • R_J
            • 9588
            What you are looking at are diodes in the secondary, they are dual diodes with a common center pin.
            • Scoobydo
              • Jun 2018
              • 16
              Ok what's the chances of just changing the internal fuse and all is ok? Guess 1000/1 as it has blown due to current over it's rated capacity? Thanks
              • R_J
                • 9588
                You might get lucky, That blue R100 could be a mov that protected the supply and blew the fuse, Measure the resistance across it. It should measure close to open. If it measures shorted, you can remove it to test the power supply but replace it later for continued protection.
                Now looking straight above in the picture, under the heatsink is D105, check the resistance between the two outer legs. it should also be close to open and not shorted.
                • Scoobydo
                  • Jun 2018
                  • 16
                  d105 if I have the positve of my multimeter on the leg by the jumper j110 and the negative on the right hand leg I get 967 ohms. If I reverse the leads then it is open.
                  The MOV I get a reading that reduces down to 979k almost like it discharges so when I first probe it on the 2000k scale it starts around 1200k and then reduces until it settles at 979k on that scale.
                  Thanks for help
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    This seems to be open.
                    • Scoobydo
                      • Jun 2018
                      • 16
                      @Andrew F. Ali if I read it correctly R_J was saying if shorted then remove and replace fuse and see if it fires up. But you seem to be saying opposite.
                      Tks
                        Nothing wrong with that MOV, it is not needed for the circuit to operate.
                        Measure the resistance between the two legs of the main filter caps.
                        Measure the resistance between the two inner legs of the bridge rectifier.
                        • Andrew F. Ali
                          • Jan 2014
                          • 2450
                          • Trinidad & Tobago
                          I am saying it is good.
                          • Scoobydo
                            • Jun 2018
                            • 16
                            Budm, is the bridge rectifier an IC as I cannot see 4 diodes set up as a rectifier and I guess the caps are nearby this for smoothing but not sure where this is on the board. Sorry for new-b questions.
                              D105 is the 4-LEG bridge rectifier mounted on the black heatsink.
                              • Scoobydo
                                • Jun 2018
                                • 16
                                Inner legs d105 =969k once it goes stable starts higher and reduces. Tks
                                  How about the resistance between the two legs of the main filter cap as requested in post #12?
                                  • Scoobydo
                                    • Jun 2018
                                    • 16
                                    Sorry dont know where it is I googled as best I could but will need guidance
                                    • R_J
                                      • 9588
                                      The main filter cap, are actually 3 on this board, they are 47uf 450volt , labled c101, c102, c103, they are in parallel so measure across any one of them
                                      There is also one for the standby circuit, 10uf 450volts, (next to D123)
                                      If you don't read any short circuit across those capacitors, I would try a fuse and see what happens, if there is still a fault the fuse will open.
                                      • R_J
                                        • 9588
                                        If there was a spike on the power line, and the mov handled it, that alone would blow the fuse protecting the rest of the power supply
                                        • Bardou Kari
                                          HP EliteBook 840 G6 – no power after lightning strike
                                          by Bardou Kari
                                          I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
                                          – Charger is OK and 19V is present at the motherboard.
                                          – No charging LED, no fan, no reaction.
                                          – I don’t see any 3.3V or 5V near the coils.
                                          – Battery is unplugged.
                                          – I’m new to board repair but can use a multimeter.
                                          I added a clear photo of the board.
                                          Any idea where to start or what to check next?
                                          Thanks a lot for your help!...
                                          07-01-2025, 10:45 AM
                                        • SluggerB
                                          Panasonic TH-50PX80 killed by lightning strike, help me save her!
                                          by SluggerB
                                          Yes it's a 17 year old Panasonic plasma!
                                          I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
                                          06-04-2025, 07:02 PM
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
                                        • MrCreosote
                                          Lightning Strike: 55" TV dead: is display panel OK?
                                          by MrCreosote
                                          THE LIGHTNING:
                                          This was a very close strike, blew a 15 amp breaker for all ceiling lights in home AND could smell ozone for a few minutes after strike.
                                          Very close and probably a very strong EMP.
                                          THE TV:
                                          No standby LED. Some voltage from PSB (not totally dead).
                                          But found a kit of ALL 4 circuit boards for $55.
                                          At first thought, this will fix my TV.
                                          But then lightning has the ability to totally fry semiconductors. Which would include any or all of the PCBs. However, the display is one big semiconductor and given...
                                          08-16-2021, 10:27 PM
                                        • pbig
                                          advices for repairing Sony Bravia 32EX600 after lightning strike
                                          by pbig
                                          hi everyone,
                                          my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
                                          On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
                                          - the 450V/150uF capacitor voltage when plugged is normal at 394V
                                          - from connector CN6150 (15 poles)
                                          STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
                                          06-28-2023, 02:43 AM
