XBR-55X850 turns on but no pic no 12v on t-con
  • hmendez86
    • Jun 2015
    • 344
    • united states
    Got this tv 4k sony xbr55x850c evrything works you can heard sound but no pic....i check the t-con for 12v and theres none....there no backlight.....if i try look the screen with flashligth theres no image ether......anyone had trouble with these tvs
    Re: XBR-55X850 turns on but no pic no 12v on t-con
    https://www.badcaps.net/forum/attach...0&d=1525751962
    Picture is not clear, I cannot read the pin out of that large white connector, I also cannt read the power supply board P/N as printed on the white sticker.
    Please upload good clear pictures of the boards, you will get lots more help that way.
    We will need the Voltage readings of all those pins of those 3 connectors.
    You need to put down pin name and follow by the Voltage reading when TV is not on and when power switch is activated.
      • 12276
      • U.S.
      Did you check the two fuses F1 and F2 on the tcon?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4460
        • Italy - Milan
        Check the mainboard, usually near the lvds connector there are one or two power mosfets that enables Tcon supply rail, check them. Maybe with the no communication between mainb. - screen the mainboard deactivates also the back light, not so probable but worth a try no?
          https://www.badcaps.net/forum/attach...1&d=1525751962
          The power for T-CON on this TV is not from the main board, it is supplied from the power supply board via small 5-pin connector on the T-CON board.
          • freakaftr8
            • Oct 2012
            • 3743
            Is the LED in front of the tv under the Sony emblem white or flashing m green/amber?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4460
              • Italy - Milan
              Anyway if it's only from the psu, it can still be delayed so a couple of transistor may activate it at the right moment.
              • R_J
                • 9588
                On the power board CN6401, pins 25-28 are tcon_vcc12v. Pin 24 is TCON_ON control. Q6403 should be the fet that controls the tcon 12 volts. which comes from the reg12v. I cant tell for sure but it looks like Q6404 is the transistor that controls the fet
                Also note there are a lot of small fuses on the main board, IE: F9403, F9406, F9401, F9002, F9000, F7700, F9009, F8400 etc. they may be worth checking
                • hmendez86
                  • Jun 2015
                  • 344
                  • united states
                  I check for the small sdm fuses on main board an all are ok
                  • hmendez86
                    • Jun 2015
                    • 344
                    • united states
                    The amber ligth is white were the tv is on i can heard the sound...
                    • hmendez86
                      • Jun 2015
                      • 344
                      • united states
                      The t-con power comes from the power supply..but but the swicth to turn on the t-con and back ligth comes from the main board....what i think is the problem a transistor on main is damage.
                      • hmendez86
                        • Jun 2015
                        • 344
                        • united states
                        • hmendez86
                          • Jun 2015
                          • 344
                          • united states
                            So is the power supply board getting the control signal on 'Pin 24 is TCON_ON control'?
                            • hmendez86
                              • Jun 2015
                              • 344
                              • united states
                              It has a signal but not all 12v .....on the pin 15 has 12v..what i did to power i jump starter the power on to 5stb...but i wont get 12 on t con
                              • hmendez86
                                • Jun 2015
                                • 344
                                • united states
                                I had a similar problem on a another tv xbr55x810c i was thinking the problem was t con because the re were no 12 on tcon from power.....so i change the power to a new one but no luck. so i was thinking were i go now? To i dicide to change main board and it worked leds ligthup and 12 v on power....
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  I'd try formatting a USB and go to Sony website and unzip the eeprom ro the USB. With tv unplugged insert USB and plug tv in. Wait till flashing white indicator stops and tv resets. About 30 to 45 min process.
                                  Could be corrupt eeprom. Had this happen when I was trying to figure out my XBR-75x850c.
                                    For T-CON to get the power from the power supply board, the main board has to send TCON_ON signal, the PS-ON signal for turning on the main switched supply, that is why we are asking if you do have the TCON_ON signal or not.
                                    • hmendez86
                                      • Jun 2015
                                      • 344
                                      • united states
                                      Tcon-on pin i get 0.005
                                        That means the main board is not sending the signal to turn on the power supply circuit to provide 12V to the T-CON board.
                                        Sounds like you are having the same problem as in your post #16.
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • netgearnetgear
                                          TCL 43S423 TCON OR PANEL FAULTY???
                                          by netgearnetgear
                                          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                                          08-20-2025, 06:04 PM
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
