Samsung BN44-00445A power supply issue
  • Jese1d
    • Feb 2013
    • 15
    • canada
    I have a Samsung BN44-00445A power supply which needs a few components. I have however one thermister component which literally fell apart in my hands and I'm unable to know its value. The reference position on the board is NT801S. Would anyone have a schematic or perhaps know the value of this component?
  • ajshoe
    ajshoe
    • Dec 2012
    • 477
    • usa
    Re: Samsung BN44-00445A power supply issue
    please circle the part on the SMPS. Whatever u do - don't use calvinwarehouse on EBAY for board repair. total ripoff and incompetent.
    • Jese1d
      • Feb 2013
      • 15
      • canada
      Ok, here is pic with location circled. I have verified shorted mosfets in the power staging section but this damaged surge thermister crumbled from heat and I'm unable to determine its value for replacement. I have seen on a samsung model BN44-00445C that this thermister is an NTC 10D 11. My power supply is a BN44-00445A. Any help is greatly appreciated.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        I think any -ve temp coefficient thermistor will work from any similar PSU.
          https://cdn.badcaps-static.com/pdfs/...fa27f23101.pdf
          That NTC blew up can be due to shorted load or the bypass relay is bad and not bypassing the NTC when the TV is turned on.
          There are two power relays on your board.
          • Jese1d
            • Feb 2013
            • 15
            • canada
            This samsung BN44-00445A power supply's thermister position has NT801S printed on the board. I hoped someone might have a schematic to verify its value as I'm not certain of which to put in. If the NTC-10D-7 will work I'll order it today Bud. I've ordered a rebuild kit but the thermister is not included in it. The owner initially blew a fuse in the ps then replaced the fuse, plugged it back in then the thermister fried.
              At this you must test all the devices attached to the heatsinks for shorts circuit first. That NTC is blown up for reason.
              • Jese1d
                • Feb 2013
                • 15
                • canada
                Thanks Bud, I did and found 2 shorted transistors on the heatsink in the power staging section. The rebuild kit I ordered comes with these but not the thermister.
                • jetadm123
                  • 2169
                  Since you ordered a rebuild kit, maybe the seller will have a schematic or a board lying around and can tell you the part number for NT801S
                  • Jese1d
                    • Feb 2013
                    • 15
                    • canada
                    That's good advice jetadmin123, I did try that but they said they don't offer tech support.
                      You should also check the relay that bypasses the NTC when the TV is turned by measuring the VACdrops between the two legs of the NTC when the TV is turned on.
                      • Jese1d
                        • Feb 2013
                        • 15
                        • canada
                        I will Bud, thanks for sharing your experience with us.
                        • Jese1d
                          • Feb 2013
                          • 15
                          • canada
                          Thanks Andrew, I may give that a try and just monitor how hot it gets for awhile. Cheers
                          • Jese1d
                            • Feb 2013
                            • 15
                            • canada
                            Hello again, I have been able to determine the thermistor is a WMEC 10D100 or 20D100. Putting together the crumbled pieces I could make out part of the numbers so I checked the WMEC data sheet and there where only 2 possible solutions. It had to be either 10D100 or 20D100. Could anyone please advise which might be correct for this power supply? A supplier would also be appreciated.
                              10D = 10mm Dia.
                              20D = 20mm Dia.
                              Can you estimate the size?
                              They typically use 10mm, 20mm will be very big.
                              • Jese1d
                                • Feb 2013
                                • 15
                                • canada
                                Thank you for your kind response. It would be 20mm then based on what its size is. Sometimes it's a real bear trying to identify a damaged part with no schematic.
                                • Jese1d
                                  • Feb 2013
                                  • 15
                                  • canada
                                  The WMEC 20D100 thermistor seems hard to find in small quantities. I did find a NTC SCK20100 on eBay which I believe would be equivalent. Checking values it seems close. Would it be fair to assume so? https://www.ebay.ca/itm/152940849564...MakeTrack=true
                                    'SCK20100' That will be 20mm dia. 10 Ohms at 25c.
                                    http://www.vtsensor.com/Product/details/id/295.html
                                    • Jese1d
                                      • Feb 2013
                                      • 15
                                      • canada
                                      That's the same as the WNEC then, thanks Bud!
                                      • Cookybaby
                                        Samsung UN60ES6500FXZA Power Supply Issue
                                        by Cookybaby
                                        Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                        I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                        Make: Samsung
                                        Model: UN60ES6500FXZA
                                        Power Supply P/N: BN44-00525A
                                        Symptoms: The TV was...
                                        08-20-2023, 12:26 PM
                                      • lp20th
                                        Samsung Plasma TV Power Supply Issue
                                        by lp20th
                                        I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                                        11-28-2023, 10:28 AM
                                      • Kjell
                                        Samsung Series 9 - BIOS issue
                                        by Kjell
                                        After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                        Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                        08-01-2025, 09:15 AM
                                      • captainKKK
                                        Samsung Bn4400612b Power Supply issue on Samsung UN50F6300
                                        by captainKKK
                                        Samsung Bn4400612b Power Supply issue takes out a new 5A fuse on my Samsung UN50F6300, without any the BL or main board cables connected. Please advise if this board has known issues and fixes. There are no evident fried components and the caps look ok. Nothing unusal on the bottom side of the board under magnification. Is the ICM801CS under that heat sink a known issue? SJ (https://www.shopjimmy.com/samsung-bn...-1473373576096) out of stock, so component level repair may be my best shot. Thanks.
                                        02-17-2022, 08:59 PM
                                        09-07-2024, 05:50 AM
