I have a Samsung BN44-00445A power supply which needs a few components. I have however one thermister component which literally fell apart in my hands and I'm unable to know its value. The reference position on the board is NT801S. Would anyone have a schematic or perhaps know the value of this component?
Samsung BN44-00445A power supply issue
Re: Samsung BN44-00445A power supply issue
Ok, here is pic with location circled. I have verified shorted mosfets in the power staging section but this damaged surge thermister crumbled from heat and I'm unable to determine its value for replacement. I have seen on a samsung model BN44-00445C that this thermister is an NTC 10D 11. My power supply is a BN44-00445A. Any help is greatly appreciated.Comment
I think any -ve temp coefficient thermistor will work from any similar PSU.Comment
https://cdn.badcaps-static.com/pdfs/...fa27f23101.pdf
That NTC blew up can be due to shorted load or the bypass relay is bad and not bypassing the NTC when the TV is turned on.
There are two power relays on your board.Attached FilesLast edited by budm; 03-07-2018, 11:55 AM.Never stop learning
This samsung BN44-00445A power supply's thermister position has NT801S printed on the board. I hoped someone might have a schematic to verify its value as I'm not certain of which to put in. If the NTC-10D-7 will work I'll order it today Bud. I've ordered a rebuild kit but the thermister is not included in it. The owner initially blew a fuse in the ps then replaced the fuse, plugged it back in then the thermister fried.Comment
At this you must test all the devices attached to the heatsinks for shorts circuit first. That NTC is blown up for reason.Never stop learning
You should also check the relay that bypasses the NTC when the TV is turned by measuring the VACdrops between the two legs of the NTC when the TV is turned on.Never stop learning
Hello again, I have been able to determine the thermistor is a WMEC 10D100 or 20D100. Putting together the crumbled pieces I could make out part of the numbers so I checked the WMEC data sheet and there where only 2 possible solutions. It had to be either 10D100 or 20D100. Could anyone please advise which might be correct for this power supply? A supplier would also be appreciated.Comment
10D = 10mm Dia.
20D = 20mm Dia.
Can you estimate the size?
They typically use 10mm, 20mm will be very big.Attached FilesNever stop learning
The WMEC 20D100 thermistor seems hard to find in small quantities. I did find a NTC SCK20100 on eBay which I believe would be equivalent. Checking values it seems close. Would it be fair to assume so? https://www.ebay.ca/itm/152940849564...MakeTrack=trueComment
'SCK20100' That will be 20mm dia. 10 Ohms at 25c.
http://www.vtsensor.com/Product/details/id/295.htmlLast edited by budm; 03-20-2018, 04:13 PM.Never stop learning
by CookybabyHello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
Make: Samsung
Model: UN60ES6500FXZA
Power Supply P/N: BN44-00525A
Symptoms: The TV was... -
by lp20thI have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
by KjellAfter installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...08-01-2025, 09:15 AM -
by captainKKKSamsung Bn4400612b Power Supply issue takes out a new 5A fuse on my Samsung UN50F6300, without any the BL or main board cables connected. Please advise if this board has known issues and fixes. There are no evident fried components and the caps look ok. Nothing unusal on the bottom side of the board under magnification. Is the ICM801CS under that heat sink a known issue? SJ (https://www.shopjimmy.com/samsung-bn...-1473373576096) out of stock, so component level repair may be my best shot. Thanks.
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
- Loading...
