Samsung UN60EH6000 Tries to come on, but stops
  • karthur
    • Nov 2015
    • 150
    Re: Samsung UN60EH6000 Tries to come on, but stops
    Originally posted by Davi.p
    But whitout TIP is ridicolous, on a board with very tiny smd components, you risk highly to burn it.. the tester i've said is not professional..
    A added the tip on the end of my lead just so that I could modify it. I have ground this down to a needle point so I can get it into tight places on a board.
    Here is the picture of the T-Con board.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4515
      • Italy - Milan
      Is not Hires photo, what can i see with this?? And also, get only tcon not cables and chassis..
      • karthur
        • Nov 2015
        • 150
        Sorry, just figured out you wanted a "Hii-Res" photo. I'll get you one.
        • karthur
          • Nov 2015
          • 150
          Here is a high resolution image of the T-Con board (BN95-00628C). This image gets compressed in the translation. I also put a copy of it on my google drive so you can get the full resolution image if you need it.
          This is a direct link to the full size image.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4515
            • Italy - Milan
            Ok i've DL it, now im editing..
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4515
              • Italy - Milan
              #26
              Test all point in volts. I don't see well to what is connected Q7100 apart those 2 elctrolitycs, but if you want test them...
              If some points has a near zero V then them must be retested with output flatcables detached...
              To upload pictures click on paperclip, a popup window appears, select the file locations, click upload and wait, when done close window then write the text, click newly on the paperclip and select the pictures to include..
                It looks to be high failure rate T-CON.
                Samsung BN95-00628C (BN97-06551C, BN41-01815A) T-Con Board
                http://www.shopjimmy.com/catalogsear...ung+UN60EH6000
                Notes from SJ:
                PLEASE NOTE: We recommending using one of the following boards as a substitute for this T-con:
                BN96-28943A
                BN96-28944A
                BN95-00944B
                BN95-00944C
                Pictures provided by shopjimmy.
                We have found these boards to have a lower overall failure rate than BN95-00628A, BN95-00628B or BN95-00628C.
                Check the resistance between the two legs of those SMD LYTICS caps (4).
                Report the DC Voltage reading of the ADJ 1117 LDO IC303.
                • karthur
                  • Nov 2015
                  • 150
                  Here are the readings with the output cables connected (all readings in dc Volts):
                  A=1.8
                  B=3.3
                  C=12.7
                  D=12.7
                  E=12.7
                  F=12.7
                  G=0
                  H=12.7
                  I=0
                  J= n/a
                  K= n/a
                  L=12.7
                  M=0.7
                  N=12.7
                  For the ones that were close to Zero, I retested with output cables disconnected.
                  G=0
                  I= 0
                  M=0.7
                  I found the Q7100 that you mentioned, but not sure what I need to test there. If I need to check something near Q7100, just let me know what it is.
                  Thanks.
                  • karthur
                    • Nov 2015
                    • 150
                    Where are the SMD LYTICS caps?
                    Can't find the ADJ 1117.
                    Here is what I get on IC303.
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      IC 303 seems right. That's a fixed regulator.
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        IC 7100 shoud have about 12v in I believe. Opposite side of triangle. Triangle pin should have output voltage.
                        • nicholas1110
                          • Aug 2012
                          • 127
                          • usa
                          #32
                          We have repaired many of these boards. It is usually the ic ISL9860. Shop jimmy has a repair kit for this tcon and also a YouTube video showing the easiest way to remove and replace this ic. In the YouTube video they show replacing 2 smd caps. If you test those with your meter they will show shorted. This means the ic is shorted. Hope this helps.
                          • karthur
                            • Nov 2015
                            • 150
                            The repair kit that I found for my board on SJ is out-of-stock. Does anyone know the size of the two SMD caps that I need?
                            I have a source for the ISL9860.
                            Thanks.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #34
                              Thanks.
                              if shopjimmy are out of stock maybe message them as they may advise you on the capacitor values/size they are very helpful i find
                              • karthur
                                • Nov 2015
                                • 150
                                No-can-do on providing the size of the capacitor. Anyone with a service manual that will tell the size of it?
                                Thanks.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #36
                                  do you know the voltage and uf rating already and you just need the physical size?
                                  • karthur
                                    • Nov 2015
                                    • 150
                                    I am going to check the caps tonight.... maybe mine are not damaged. If they are gone, I would have to know all aspects of them to order new ones. I could get the physical size, but would have to correlate to a form factor.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      #38
                                      i have a cheap pair of digital calipers and use this guide https://www.pcblibraries.com/forum/s...topic1729.html
                                      norcal715 has a video on this fault https://www.youtube.com/watch?v=iuHrnvAKlGw
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        Nice charts! But Where in those charts show the capacitence?
                                        • karthur
                                          • Nov 2015
                                          • 150
                                          Yea, that is one of the YT videos I watched. Norcal makes it look easy.
                                          He is probably right about why they are failing (heat... need to add thermal conductor)
                                          • Cornito
                                            Denon AVR-2700H audio stops while receiver still works
                                            by Cornito
                                            Hello team,
                                            I've got a new issue with a Denon Avr-2700H.
                                            After several minutes working, receiver stops playing sound with a poc eared in the speakers.
                                            Receiver still work and display video with error message on display.
                                            Seems to me that is the main output relay.
                                            I'm looking for the service manual that I can't find for the moment.
                                            Does somebody have it?
                                            Regards...
                                            08-03-2025, 06:10 AM
                                          • karthur
                                            Samsung UN60EH6000 Dump
                                            by karthur
                                            I have a Samsung UN60EH6000 that will not turn on. When I turn it on, no start-up melody. Only the screen flickers around the edges. I have replaced the T-con board, but issue persists. I have also checked the voltages on the power board and they seem to be correct.
                                            Power Board: BN44-00500A
                                            T-Con Board: BN95-00944B
                                            Main Board: BN94-05549E
                                            I have pulled off the chip IC901 on the main board. This is a Winbond W25Q128BVFG Chip.
                                            My bin dump is below. Can someone look at this and see if this is good or bad file?
                                            12-16-2023, 02:11 PM
                                          • karthur
                                            Samsung UN60EH6000 wont come on after lightning strike.
                                            by karthur
                                            We had a lightning strike a few days ago really close to my house. My Samsung UN60EH6000 was on when it hit. Afterwards, the TV would not come back on.
                                            I had repaired this TV a few years back by replacing the T-Con board. (The post I had on this is repair is here.)
                                            When I turn on the TV, I don't get any start-up melody. The screen just dimly flickers around the edges.
                                            Here is what I have checked.
                                            On the power supply board, 14pin connector:
                                            1 :12.7 Vdc
                                            3 :12.7
                                            5 :12.7
                                            7 :12.7
                                            9 :0
                                            11 :5.
                                            13 :5....
                                            11-01-2023, 06:18 PM
                                          • 6BW6
                                            Win7 Performance test stops
                                            by 6BW6
                                            I had a dodgy Molex Sata lead go bad that cause crashes once in a while, after repairing all is well with no crashing BUT.... Windows performance test stops. I get-:
                                            Problem signature:
                                            Problem Event Name: APPCRASH
                                            Application Name: WinSAT.exe
                                            Application Version: 6.1.7601.17514
                                            Application Timestamp: 4ce798fc
                                            Fault Module Name: atiuxp64.dll
                                            Fault Module Version: 8.14.1.6463
                                            Fault Module Timestamp: 56254af6
                                            Exception Code: c0000005
                                            Exception Offset: 000000000000dc14
                                            OS Version: 6.1.7601.2.1.0.256.48...
                                            05-29-2023, 04:21 PM
                                          • someonenotyou
                                            Lenovo A485/T480 USB stops working when USB2.0 is plugged.
                                            by someonenotyou
                                            Hi.
                                            I have 2 Lenovo laptops (A485 and T480) with identical USB problem.
                                            When I plug in a USB 3.x device (USB storage), the USB ports are working normal.
                                            But as soon I plug in USB 2.0 device (mouse, USB storage), all the USB ports stop working. Even if I plug in USB 3.x device.
                                            The only way to get USB working again is disconnect battery and reset BIOS.
                                            Has anyone had anything similar?
                                            I have not yet tried another BIOS, but would that be the problem with USB?
                                            Thank you.
                                            03-19-2025, 12:15 PM
