Win7 Performance test stops
+ More Options
Posts
  • 6BW6
    • Jan 2015
    • 55
    I had a dodgy Molex Sata lead go bad that cause crashes once in a while, after repairing all is well with no crashing BUT.... Windows performance test stops. I get-:
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: WinSAT.exe
    Application Version: 6.1.7601.17514
    Application Timestamp: 4ce798fc
    Fault Module Name: atiuxp64.dll
    Fault Module Version: 8.14.1.6463
    Fault Module Timestamp: 56254af6
    Exception Code: c0000005
    Exception Offset: 000000000000dc14
    OS Version: 6.1.7601.2.1.0.256.48
    Locale ID: 2057
    Additional Information 1: 2769
    Additional Information 2: 2769594407f52209a804a6d1c0ed4d12
    Additional Information 3: 04bb
    Additional Information 4: 04bbe9907734487884969c6fb588dd95
    So I did CMD scan as administrator for atiuxp64.dll here's the result-:
    Microsoft Windows [Version 6.1.7601]
    Copyright (c) 2009 Microsoft Corporation. All rights reserved.
    C:\Windows\system32>dir "atiuxp64.dll" /s
    Volume in drive C has no label.
    Volume Serial Number is E6CE-2584
    Directory of C:\Windows\system32
    20/10/2015 04:57 166,488 atiuxp64.dll
    1 File(s) 166,488 bytes
    Directory of C:\Windows\system32\DriverStore\FileRepository\c7171099.inf_amd64_
    neutral_4e1498617e0336e7\B171094
    18/04/2014 03:43 143,304 atiuxp64.dll
    1 File(s) 143,304 bytes
    Directory of C:\Windows\system32\DriverStore\FileRepository\c7295782.inf_amd64_
    neutral_f7a12ff154ea5754\B295612
    Total Files Listed:
    3 File(s) 476,280 bytes
    0 Dir(s) 207,387,811,840 bytes free
    I'm running Win 7 pro x64 with a AMD A6-5400K APU (Radian graphics), not crashed since running any programs but yet I can't complete the test.
    Can anyone throw any light on this?
    Thanks Dave
  • R_J
    • Jun 2012
    • 9535
    Re: Win7 Performance test stops
    Have you tried reinstalling your video driver? also try running SFC/scannow from an administrator command line
    • 6BW6
      • Jan 2015
      • 55
      Thank you for quick reply, yes I've ran SFC and that came up clean, 'No violations found' or something like that. I never ever give the video driver a thought, thanks for that.
      I did down-load atiuxp64.dll from a link that was given on Microsoft help site for someone else with a similar problem, suppose no harm in trying that first I hung fire to hear from people with more knowledge than myself first.... maybe video's playing OK kinda 'foxed me'.
      I'll get back after some shut-eye, by the way they are SSD drives, I'll do a clone job first so I've a spare drive. Many thanks, much appreciated. Dave
      • TechGeek
        Computer Geek
        • Jan 2015
        • 2254
        Video driver isn't playing nice. Use DDU in Safe Mode and rip the entire driver stack out, clean-install from known-good installation media, and try again.
        Note: Cloning a DAMAGED install to a known-good drive will NOT fix the damage! You must perform a clean installation with a fresh filesystem in order to ensure that further corruption isn't lurking in the shadows.
        Permanently Retired Systems:
        Kooky and Kool Systems
        sigpic
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3593
          • slovakia
          or just disable apu in device manager and run on basic drivers mode to check function
            master hoarder
            • May 2008
            • 12175
            WinSAT.exe = Windows System Assessment Tool.
            It basically measures your system's performance by running tests in the background and is what gives you your Windows Experience Index (that number that shows how good your PC is.) My guess is, when it tries to evaluate your built-in GPU, it crashes - either due to improper driver or possibly a hardware issue.
            These AMD APUs (especially the mobile ones) may start to fail if they were ever ran at hight temperature or not cooled well. Another thing is, video memory is simply taken from the system memory. So if you have a bad RAM module, bad connection in one of the RAM slots, or bad BGA in CPU socket, this will cause errors and crashes with the GPU. Best bet is to run something like memtest first to check if your RAM is OK. But before doing that, also make sure your system's cooling is up to snuff. Bad cooling can and will kill these APUs over time. IIRC, the stock heatsinks these APUs come with is quite garbage / undersized. I always use proper full-size AM2/AM3 heatsinks on these APUs, and they run much cooler as a result.
            Also, before running memtest, check your PSU too - bad caps can cause all sorts of intermittent issues, including very specific failures with certain software or programs. I suggest opening it and posting a picture here, or at least post what brand and model it is.
            Now, if your PSU checks out OK and memtest runs without errors, then I would lean towards a driver issue. In that case, get GPU-Z and post a screenshot here to see what video drivers your APU is using. Not using the correct drivers can cause issues. Also check the temperature of the APU with that while at it. Anything over 55C under load on these APUs would be an issue.
            Lastly, I encourage disabling unnecessary crap like WinSAT and anything MS telemetry-related. I've had multiple instances where WinSAT was trying to run while I was playing a game. The result was either choppy/bad performance while it ran, or in a couple of cases my game crashed because WinSAT used too much resources.
            To disable WinSAT, go to Control Panel > Administrative Tools > Scheduled Tasks and find the entry for WinSAT. Right-click on the entry for it and disable that scheduled task from running. You can (and should) also do that with anything in there that mentions Windows Customer Experience or Windows Telemetry or similar. All of these tasks are really garbage that slows Win7 down. There are several services that can be disabled too. Been a while since I done a Win7 install, so apologies for not being able to give you more details on how to do this at the moment.
            Anyways, report back with the above findings first (PSU brand/model/pictures, memtest results, system cooling + temperatures, GPU-Z screenshot and/or driver version) and then we can try to go from there to see how to solve the issue.
              Microsoft Surface Book Surface Book with Performance Base Hybrid (2-in-1) Specification for Upgrade or Repair
              This specification for the Microsoft Surface Book Surface Book with Performance Base Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book with Performance Base boardview and Surface Book with Performance Base schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-06-2024, 08:20 AM
              ASUS VivoBook Performance Laptop Notebook Pro Specification for Upgrade or Repair
              This specification for the ASUS VivoBook Performance Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Performance Laptop boardview and Performance Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-06-2024, 07:00 AM
            • chth96
              How Can I test PWM DM0365R?
              by chth96
              Hello
              I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
              So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
              I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
              I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
              06-18-2025, 04:14 PM
            • hinisa
              Xiaomi router freezes at boot after re-capping
              by hinisa
              I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
              When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
              After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
              Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
              07-08-2023, 05:58 AM
            • khelane
              test active pfc power with lamp test
              by khelane
              Hello
              I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
              Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
              Is there a way...
              06-03-2025, 01:00 AM
