Samsung UN60EH6000 Dump
  • karthur
    • Nov 2015
    • 150
    I have a Samsung UN60EH6000 that will not turn on. When I turn it on, no start-up melody. Only the screen flickers around the edges. I have replaced the T-con board, but issue persists. I have also checked the voltages on the power board and they seem to be correct.
    Power Board: BN44-00500A
    T-Con Board: BN95-00944B
    Main Board: BN94-05549E
    I have pulled off the chip IC901 on the main board. This is a Winbond W25Q128BVFG Chip.
    My bin dump is below. Can someone look at this and see if this is good or bad file?
  • karthur
    • Nov 2015
    • 150
    Can someone please confirm that this file is good or bad .bin file?
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • ohren
      Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
      by ohren
      I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
      I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
      The models launched in 2018 and 2019 respectively....
      09-08-2023, 05:24 PM
    • C152Heavy
      Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
      by C152Heavy
      Summary for TL-DR readers:
      • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
      • Have obtained Samsung schematic & service documents - Can upload if helpful.
      • Have read ALL applicable threads
      • C1818 and CP820 replaced as low hanging fruit
      • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
      • VCC pin (18) of PFC...
      01-11-2023, 02:53 PM
    • DynaxSC
      by DynaxSC
      11-17-2023, 10:56 AM
