Sony KDL-46Z4100 bad T-Con?
  • Daveleone
    • Apr 2016
    • 267
    I've seen a few threads about this issue, but no clear conclusion. I have a Sony KDL-46Z4100 and when I turn it on, it powers on and the backlight comes on. Then there are some lines down the right side of the screen. If I hit the Guide button on the remote the lines change and a white cloud slowly grows from the right side of the screen to the left (see linked video) and some more lines show up on the left side of the screen.
    From my previous experience with a Sony 46XBR6 TV I had, I figured the problem was the T-con board. I bought a replacement on eBay and the TV still exhibits the same issue.
    Do you think...
    1) I got a 2nd bad T-con board off eBay (sounds crazy, but with my other Sony TV I ended up getting THREE bad T-con boards before I finally got a good one and everything worked), or ...
    2) Bad main board, or ...
    3) Bad panel?
    Help.
    Video: http://******/2fVhS0Y
  • Daveleone
    • Apr 2016
    • 267
    Re: Sony KDL-46Z4100 bad T-Con?
    I should also mention that if I look at those lines you see in the picture closely I can very faintly see some letters in the upper-right corner of the screen (where the input would normally display), and if I press the input button, the lines fade away very slowly and other lines appear in different places very slowly.
    • dskall
      • Oct 2016
      • 2905
      • usa
      I'm thinking bad panel. What happens when you unhook t-con to panel cables one at a time?
        Try flexing the panel to see if the lines will change.
        • Daveleone
          • Apr 2016
          • 267
          Flexing panel had no effect. Pictures of panel with left ribbon disconnected and right ribbon disconnected are attached below.
          • attainteddragon
            • Apr 2013
            • 764
            • australia
            sounds like panel to me. you could strip it down to the screen and see if pressure on or around the cof chips affects the picture.
            WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              It does looks like a bad panel fault especially the way it sweeps across the screen.
              • Daveleone
                • Apr 2016
                • 267
                Update on this set. I would've given up on this days ago, but I wanted to take the investigation to its conclusion because I saw so many threads here regarding this model or similar models that never got closure
                I bought a new T-Con and a new Main Board.
                Old T-Con, Old Main: Lines down screen, but TV stays on.
                New T-Con, Old Main: Lines down screen, but TV stays on.
                Old T-Con, New Main: Lines down screen, TV shuts off with 14 blink code (High Frame Rate 120Hz Error)
                New T-Con, New Main: Lines down screen, TV shuts off with 14 blink code (High Frame Rate 120Hz Error)
                **Q1: Not sure why the behavior is different with the new main board vs the old main board? Any ideas on that?**
                But the symptoms at this point do seem to point to a defective panel. I took the front apart and tried putting pressure on each of the tab bonds both on the panel side and the circuit board side. No effect. The panel LOOKS ok, so I'm thinking maybe defective components on the circuit boards that are bonded to the panel.
                **Q2: What do you all think? Defective panel? Due to faulty components?**
                • Daveleone
                  • Apr 2016
                  • 267
                  Gents, any thoughts on my questions above? Thanks!
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    I would say bad panel and bad new mainboard
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4458
                      • Italy - Milan
                      "1) I got a 2nd bad T-con board off eBay (sounds crazy, but with my other Sony TV I ended up getting THREE bad T-con boards before I finally got a good one and everything worked), or ..."
                      Interesting, i have suspected theese things happens, because people get bad diagnose by bad technicians or by Internet forums and he put his board on sale like them are good.. it think.. bah..
                      I think you have 2 bad tcons, and the second mainboard is maybe ok but not completely compatible (settings/software), but this maybe must be added to a bad lcd panel that ruined tcon. A diagnose can't be done without testing voltages on the tcon.
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        I still think it's a bad panel. I currently have a set that does exactly as shown in the video. If I keep quickly changing Source I will sooner or later get a picture but still showing bleeding on highlighted areas of the picture.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4458
                          • Italy - Milan
                          Dick i think you refer to those picture with vertical wake.. but i dont know if this is the case.. let wait OP tests..
                          • budwich
                            • Jul 2015
                            • 3097
                            what's the history on the set?
                            • Daveleone
                              • Apr 2016
                              • 267
                              Unfortunately, I don't know the history. Someone local gave the set to me for free. He said one day he turned it on and it had the lines down the screen, but that's all I know about it.
                              I'd be surprised if I have 3 bad T-Cons especially since I have bought from the current seller in the past and everything they have shipped me has been in working condition. BUT on the last Sony set I had I went through 3 bad T-Cons before I got a working one (probably because of what Davi.p said - people think their board is good and LCD panel is bad and sell the board as "working" when it's actually not working; I should note the working one I finally got was from the current seller) AND the difference in main board behavior does make me wonder if that board is bad as well.
                              I'd hate to trash the set because I think I have a bad panel and the problem is actually something else that could have been fixed.
                              Do you have a list of voltages I should test on the T-Con? Maybe I can give it one more go before I give up on it
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4458
                                • Italy - Milan
                                I need a photo of the tcon in hires perpendicular and without reflections, a good idea is to grab it from Shopjimmy and post here, search for its model code, i'm unable to see that site.. for now, just to make you in action, watch the board, you see a column of 4+4pin chips, those are almost sure power mosfets, are you able to test them for short?
                                • Daveleone
                                  • Apr 2016
                                  • 267
                                  Here's the pic of my T-Con (model A-1564-648-A). I also included a pic of A-1564-648A v2 because I'm not sure how to distinguish whether I have a v1 or v2 board.
                                  Also, I don't see the 4x4 pin chips you're talking about. Can you point them out? Thanks!
                                  • petehall347
                                    • Jan 2015
                                    • 4439
                                    • United Kingdom
                                    sell one tcon board and wait for complaint .
                                    • petehall347
                                      • Jan 2015
                                      • 4439
                                      • United Kingdom
                                      if i buy a board its because its cheaper than fixing one .i generally buy ones from smashed panels .or so they say .
                                      it sometimes make me wonder why it got smashed .
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4458
                                        • Italy - Milan
                                        HI, i refer to your first photo, that is the only important, i will mark in () the tension is supposed to be for me approx., points 1 (12V), point 2 (3,3v), point 3 (<0v), point 4 (>20v), point 5 (>12v), point 6 (<12v), the point 6 are fuses, must be measured on one terminal and the other. Blue rectangular shows the power mosfet that i know usually fails on that type of boards, measure in diode mode between the 3 legs joined and 4 legs joined, one way and other (swap probes). Good work..
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • iglitare
                                          by iglitare
                                          09-04-2025, 07:13 AM
                                        • ggil44
                                          Sony XBR-65X750D Horizontal lines bottom of screen
                                          by ggil44
                                          Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                                          05-30-2023, 07:51 PM
                                        • Chrissygizmo
                                          Sony KD-55XG9505 lines on screen problem
                                          by Chrissygizmo
                                          Hello again everyone,
                                          This is my latest mission, to try getting this Sony tv back to normal working order…
                                          I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                          02-19-2025, 11:31 AM
                                        • noisykid
                                          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                          by noisykid
                                          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                          12-30-2024, 07:15 PM
