Samsung LE40C750R2K horizontal lines
  • lesnajair
    • May 2015
    • 57
    • United Kingdom
    Hi All
    Please could I ask a quick question on whether the stripes onscreen showing on menu items is fixable or worth trying to repair? I haven't acquired it yet, but if it's not an economic repair, I won't bother taking the project on! Hope this is OK?
    Regards
    Les
  • Jacksy
    • Apr 2017
    • Austria
    Re: Samsung LE40C750R2K horizontal lines
    check the flexcable from the T-Con to the LCD screen.
    • lesnajair
      • May 2015
      • 57
      • United Kingdom
      Thanks Jacksy
      • grss1982
        • Mar 2007
        • 225
        • Philippines
        @lesnajair:
        Did you ever fix this issue?
        Also, did you notice a greenish tint to the area with he horizontal lines?
        I'm having a similar issue with my LG LED monitor but with the added greenish tint and it happens in only the right half of the monitor. :|
        Thanks for any replies.
        CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
        GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
        Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1
        • lesnajair
          • May 2015
          • 57
          • United Kingdom
          Hi
          No, the issue wasn't fixed. The TV was for sale very cheap and I was asking for advice before I bought it but decided against it in the end. I like a simple fix! LOL. Good luck with yours.
          Les
          • mikail13
            • Aug 2013
            • 93
            • Turkiye
            Thank you for tips.
            i already same problem with my Sammy.
            i have already know origin of the problem .. LCD flex cable..
            if i press the pins on flex cable display goes right.
            is only solution replace it?
            cutting the top of flex may help me?
            shipping is very late from China ..
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4365
              • Italy - Milan
              Shipping of what?? the flex cable? You are meaning those attached to lcd glass? How do you go to change it?
              • heavymachines
                • Mar 2011
                • 1028
                LOL if you were to change tab bond flex you would need a $5,000 tab bonding machine or make a homemade one. Also requires special strips and solutions consisting of acid.
                https://www.youtube.com/watch?v=ci4OFwtD1cE check this out.
                • koka0011
                  • Apr 2013
                  • 30
                  • Sri Lanka
                  did you cut ckv lines?
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4365
                    • Italy - Milan
                    "Also requires special strips and solutions consisting of acid."
                    Which acid? And for what? For removing old glue?
                    "did you cut ckv lines?"
                    Why do that? What are for ckv lines?
                    Thanks...
                    • heavymachines
                      • Mar 2011
                      • 1028
                      Thanks...
                      Did u watch the video?
                      • budwich
                        • Jul 2015
                        • 3097
                        interesting video. Not sure if I had all that "capability", that I wouldn't use a "new strip" instead of trying to salvage the existing strip... I think that's what I saw. Kind of like replacing the lcd in a tablet but saving the existing digitizer screen for reuse. :-) Maybe they are harder to come by than the equipment.
                        • heavymachines
                          • Mar 2011
                          • 1028
                          LOL there are other videos on Y/T showing using new tabs. however despite using old crusty tab it did work.
                          However the vid was edited so hard saying if you watch the vid you can see he has 2 tabs the one he inspected under microscope and the other under the glass table and that one looked wrinkly and crusty.
                          • Moreno83
                            • Jun 2014
                            • 2008
                            • The Netherlands
                            The tabs you can order on aliexpress for cheap. Also the tape for bonding ( around $80 ). Only problem is to attach it to the panel in line.....
                            You need big machines for that i guess...
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4365
                              • Italy - Milan
                              Sorry, seemed a tag to me.. Yes i already saw that video.. now i remember...
                              • Ihandyrepair
                                Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                by Ihandyrepair
                                Hi guys
                                I just started fixing 4k TV few months ago. so I am still learning a lot
                                I got this tv from friend complaint is ghosting or horizontal lines on image.
                                never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                then it started to show the ghosting white image.
                                I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                it has 3 thin small boards at the bottom of the...
                                12-05-2022, 04:18 PM
                              • Rubenlily
                                Samsung QE50Q67TAU - horizontal lines
                                by Rubenlily
                                First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                                I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                                I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                                I'm no expert but I've done the tape...
                                08-16-2023, 01:12 PM
                              • x_orange90_x
                                Samsung UN46C8000XFXZA vertical bars/horizontal lines
                                by x_orange90_x
                                I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                                The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                                09-04-2023, 12:09 PM
                              • arctor
                                samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                                by arctor
                                hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                                04-26-2025, 05:22 AM
                              • x_orange90_x
                                Samsung UN46C8000XFXZA Horizontal lines
                                by x_orange90_x
                                I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
                                I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
                                07-15-2023, 05:06 AM
