samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
  • arctor
    • Mar 2025
    • 21
    • italy
    hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give you the photo of the panel
  • Diah
    • Feb 2013
    • 6545
    50 size panel are rubbish ......make jumper between this 2 feedback points, then disconnect one half screen ( U Ribbon on the panel buffer boards ) see which side will make picture and clean
    • arctor
      • Mar 2025
      • 21
      • italy
      thanks diah but i give it back to my friend...how u say display is rubbish...so he will decide what to do thanks for your help, but he is stubborn say it the main board...
      • noipi
        samsung Oled 65 Horizontal Lines and Flicker
        by noipi
        I have samsung 65", i bought it last january 2025 2nd hand, and last month got this problem, flickering with horizontal lines. any inputs if this is Motherboard replacement or the LCD tcon, can someone help me what to do, i saw in YT, someone says that to cover the flex connector of the unit. Sorry for my english i am asian. i include the video so someone can help me out. thanks...
        10-14-2025, 02:11 AM
      • Ihandyrepair
        Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
        by Ihandyrepair
        Hi guys
        I just started fixing 4k TV few months ago. so I am still learning a lot
        I got this tv from friend complaint is ghosting or horizontal lines on image.
        never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
        then it started to show the ghosting white image.
        I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
        it has 3 thin small boards at the bottom of the...
        12-05-2022, 04:18 PM
      • x_orange90_x
        Samsung UN46C8000XFXZA vertical bars/horizontal lines
        by x_orange90_x
        I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
        The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
        09-04-2023, 12:09 PM
      • x_orange90_x
        Samsung UN46C8000XFXZA Horizontal lines
        by x_orange90_x
        I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
        I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
        07-15-2023, 05:06 AM
      • porfyriadhs
        Tv Samsung UE50TU Horizontal lines
        by porfyriadhs
        Hello to everyone. I tried the tape method to by pass the on and off problem for the Samsung tv I mentioned. But unfortunately lines starts to appear. My question is if someone knows how to fix the lines problem...
        05-16-2024, 02:44 AM
