I have a Sony 60 inch LED KDL 60r520a . Had this TV for about 5 months originally PowerUp nothing came on the screen from Googling and stuff I tested the t-con and it was bad tried to replace the bad components messed the t-con up. Recently found a donor TV broken screen still lit up and played. I swap the new t-con in the TV turns on was watching videos grab the TV to move it and it powered off. I unplugged it powered it back on came back on let it play videos for about an hour then it went off again. And now all I can get it to do is Flash the Sony logo and then the 6 blinks. I even swapped power supplies and main boards. Could this be caused buy a bad LED. I replaced lots of backlit LEDs never Edge lit. The donor TV was a 70 inch the LED strips might not be the same length. This model has three boards power supply tcon main board
Sony kdl-60r520a logo flash then 6 blinks
Re: Sony kdl-60r520a logo flash then 6 blinks
Did more testing
3.3vsb is 3.3v
Acd is 3.3v
Power on 3.3v when switched on
Tcon 12v
Reg12v is 12v when on
Bl error is 3.3v when turned on
Blon is 2.9v when turned on
Pwm dimmer 1.6v when turned on
Led connector
Led1 + goes to 137v
Led1 - goes to 60v
Same readings led2 led3
Screen flashes logo for a second .
Where does the bl error detection come from the tcon? OrAttached Filesif you find these attachements useful please consider making a small donation to the site
Can't win with this TV turns out the power connector to the board isn't always connecting. So I fixed that TV turns on the right side facing the TV is darker and sluggish yesterday it was fine I'm guessing I can't remove the driver board like you can on the 70 inch models are there any work around for the 60 inch models.Comment
you have a BL error which is more likely that you have some of the LEDs out. The operation on those can be done IF you can find suitable replacement leds.
Of course, a picture of the display will likely confirm this.Comment
Now have swaped back the oeignal psu was the connected from wall plug to psu. I had video for awhile now just back lights on no video tv responds to remote. I am using Tcon from 70r550a which shop jimmy says is a substitute think the tcon is bad gets extremely hotComment
WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
Backlights stay on now just no video. Possible panel failure? Yesterday worked fine . Then power cord issue that's fixed but then half screen darker sluggish and now no video at all. Swaped main board and psu no change . Don't have another tcon to try. Have 12v at tcon but tcon getting extremely hot.Comment
is 12v present on the t-con?WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
What do you get on the screen if you have the flat ribbon cables between the T-CON and the LCD panel connected one at a time?Never stop learning
"Disconnect right cable I get a washed out white pic across whole screen looks like some distortion of colour or picture" It that with the left cable in place but right cable not in place? We want one cable in one at a time only, not both out at the same time.Never stop learning
Ordered new tcon replaced it turn the TV on back lights come on then dim but still no picture. Disconnecting the ribbon cables from the t-con to the panel one side at a time does nothing just the backlight stays the same is this a mainboard issue?Comment
possible its the mainboard but i would say more the lcd panel thats at fault lets see what others have too say though.Comment
by IhandyrepairHI guys
I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
here is the issue
I have Sony and android logo. but then 4 led red flash lights front of the tv
I have 3.3v ref. 12v reg then T con 12v when I press the power on button
but then I get black screen and 4 red flash light at the front LED
but I get 3 led flash on the LED driver board.
I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
so I tried... -
by iglitareHi,
Or is it always a bad/shorted... -
by maudaI'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
...05-21-2023, 11:56 PM -
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by rimwallThis TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or... - Loading...
