Samsun LN32B550K1F with BN44-00261A burnt out IC
  • lucidbarrier
    • Jul 2012
    • 84
    Re: Samsun LN32B550K1F with BN44-00261A burnt out IC
    Originally posted by budm
    The backlights did not even flash on for second then. If the backlights circuit is OK the good lamps and bad lamp, the backlightys will flash on for seconds then the protection circuit will kick in to give you that 3-second to black symptom.
    Next thing we need to find out if you do have PFC Boosted Voltage or not by checking the DC Voltage between the two legs of the mail filter cap cp815, it should show about 380~400VDC right now in this self test mode, the backlights circuit require this boosted Voltage to operate.
    Looks like 166v across the 2 leads, main board unplugged and power cord plugged in
      OK, we need to check out the PFC circuit next. Need to check the PFC diodes and may be the DCV at the VCC pin of the PFC IC. I am going to bed now, so I will continue tomorrow.
      • lucidbarrier
        • Jul 2012
        • 84
        OK, we need to check out the PDC circuit next. Need to check the PFC diodes next, then msy be the DCV at the VCC pin of the PFC IC. I am going to bed now, so I will continue tomorrow.
        Yes sir, thanks for the help!
        • lucidbarrier
          • Jul 2012
          • 84
          I'm not too sure which diodes are the ones I need to check but those big diodes DP804 and DP810 are not shorted, they test 0F in one direction and .488v in the other direction (in circuit).
          I was looking at another thread with a similar board and I am assuming the PFC IC is the FAN7530 at UP801S?
          Reference:
          https://www.badcaps.net/forum/showthread.php?t=55254
          So with the black lead hooked up to the neg - lead of the main filtering cap and the postitive probing the little pads of the IC chip I only saw 2 voltages.
          I think that Pin 8 is the VCC. The little dot was located right over Pin 1.
          Pin 8: 0.228v
          Pin 1: 1.09v
            Look at the schematic and then check the DCV with ref to primary circuit GND (Neg. leg of the main filter cap) on E, B, and C of Transistor QB801 to see what you get.
            It may be in the protection shutdown mode due to bad resistors: Rb 803~808 which are part of the PFC protection circuit.., also may be bad 15V Zener ZB801
            • lucidbarrier
              • Jul 2012
              • 84
              While I was looking for that QB801, I noticed that there have been a bunch of components replaced on this board. There are diodes and capacitors and little resistors and FETs replaced. Some of the soldering is kind of iffy. The larger things look good but some of the tiny SMD components look a bit crooked. He didn't trim the legs far enough on the STRW6252. I went ahead and sent for a return on this board. It's one thing trying to find a failed component on a virgin board but then it's another trying to fix something he might have caused repairing the board.
              So the other day I went ahead and ordered this kit, which the seller blanked out the numbers on the components but it looks like a STRW6252 and a FAN7532 is in the kit, as well as some caps and a replacement fuse. I also ordered a Weller WES51 and a few tips, in case I need to replace that IC. I am going to focus on the failed original board and send the Frankenboard back to the seller.
              • lucidbarrier
                • Jul 2012
                • 84
                Wow that WES51 temp controlled soldering iron really makes a difference! I wish I had bought this thing years ago.
                I noticed that the power IC has heatsink compound on it. What kind of heat sink compound do I need to use? All I have is Artic Silver 5 but that contains silver and this looks like the old school white stuff.
                • heavymachines
                  • Mar 2011
                  • 1028
                  Grease will still work just fine.
                  • lucidbarrier
                    • Jul 2012
                    • 84
                    Thanks, I bought some GC heatsink compound today at Altex. It says perfect for power ICs so that's the main reason I got it.
                    • lucidbarrier
                      • Jul 2012
                      • 84
                      So today I put some compound on the power IC, soldered it in and swapped out the fuse that was open. I decided not to replace the little FAN7530 IC and to check the voltage at the main filtering cap to see where we were.
                      I plugged in the power cord and the backlights immediately came on and I saw about 386v at the filtering cap. So I reattached the T-Conn and main board and threw on the rear cover to test it.
                      And it came on with a beautiful picture! I knew this TV had a lot of potential because of similar TV's I've repaired. Do I need to worry about that little FAN7530 IC?
                      I want to thank you gentlemen for your help and suggestions.
                        PFC Voltage booster is working so the PFC IC is fine, glad to see the TV is working again.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          #32
                          glad you have managed too get your set working is it possible for future reference too let us know what was included in the kit and the board location numbers as it may help others with fault finding etc.
                          • lucidbarrier
                            • Jul 2012
                            • 84
                            The TV would power on and you could hear a chime, and the standby light blinked but there were no backlights, no picture, no image on the screen with a flash light on it.
                            The obvious parts that were faulty were the little power transister and the blown fuse. The power switch was visibly blown and destroyed and the fuse tested open in circuit.
                            Location UM801S - Power Switch Part# STRW6252
                            Location FS801 - Fuse T3.15AH 250V
                            I bought the kit from here:
                            https://www.ebay.com/itm/Samsung-BN4...2/142490605351
                            It's mostly the capacitors to recap the board along with the two parts mentioned and a FAN7530 at location UP801S on the back of the board. It's missing one cap though, I'm not sure which revision they used but there is a cap at CM852 rated at 10v 1200uF 105C and it's not in the kit. The cap they have at CM851 isn't on either board I have, and it's a 25v680uF cap. If you do need to replace the STRW6252 then you would also need to have some heat sink compound handy because its bare. I picked GC Type 44 Heat Sink Compound part# 10-8118
                            But I would read the other posts in this thread because Budm really broke it down how to test the power supply issue.
                            • electomech-fixer
                              First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                              by electomech-fixer
                              I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                              I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                              09-15-2025, 01:42 AM
                            • dicky96
                              Zotac GTX 260 burnt component - can anyone identify?
                              by dicky96
                              Hi guys
                              This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
                              This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
                              Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
                              I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
                              The good phase...
                              12-01-2021, 01:02 PM
                            • swimllamaswim
                              Precision 5550 LA-J191P No Power, Burnt ISL9538
                              by swimllamaswim
                              I picked up this Precision 5550 to fix up recently, and found that the ISL9538 chip was burnt on pin 14 (CSIN). The two left side Type C ports negotiate at 20v, and the right side one only negotiates at 5v. I also found the EMI protection diode, DT35, was burnt on that side. I pulled the ISL9538 off, checked for any other obvious shorts, repaired the pad, and put a new one on. Now, I still do not get power, and there is a rapid clicking sound from somewhere on the board that I can't pinpoint.
                              Here are the voltages measured at that chip:
                              To note, DCIN at Pin 17 is low,...
                              09-21-2025, 12:26 PM
                            • mferna14
                              Apple MacBook Pro A2338 820-02773-A AON Rail burnt
                              by mferna14
                              Hi Dear Friend., I am working on a Apple MacBook Pro A2338 820-02773-A. The history was that the AON Rail on the Trackpad connector JT400 was burnt. After I removed the burnt connector, I tested with the meter & no shorts. Connected the USB C power & all booted fine, no problems at all. I soldered a New TP connector put in the old trackpad with a brand new Flex cable. The laptop beeped in the start but no display. I removed the connector & the display was fine again. USED a known good Trackpad & a Flex cable, even with this still the same problem. I checked the connector whether...
                              06-25-2025, 11:26 AM
                            • nobbnobb1
                              Bose Acoustimass 10 IV Subwoofer No Sound. Help with burnt component identification?
                              by nobbnobb1
                              I picked up this used Bose Acoustimass 10 IV speaker system. Speakers seem to work fine, but the subwoofer does not make any noise. So I took apart the unit and found some obviously failed (burnt) components:
                              - 1x 3.14 A @ 250V main circuit fuse
                              - 1x bridge rectifier GBU601. there's actually two of these on the board, one is obviously burnt and the other does not seem to have any anomalies like shorts. However I figure may as well replace both.
                              - 2x diode. This is tricky because the only markings I see on it are: "617 402". No current rating or anything else....
                              11-16-2024, 09:56 PM
