Precision 5550 LA-J191P No Power, Burnt ISL9538
  • swimllamaswim
    • May 2016
    • 24
    Originally posted by mon2
    Review the voltage to ground @ PL1901 (either side).
    It's at a locked 0.9mv
    • mon2
      • Dec 2019
      • 14589
      Assuming that you have ~20v on the CHG_SRC_20V -> Then the mosfets linked to this inductor are suspects = PQ1902, PQ1900, PQ1903, PQ1904.
      Remove all power. Meter in resistance mode. First confirm that the main power rail is not shorted. Test the resistance to ground of B+. This must be a high resistance else there is a fault here.
      Next..
      Test each mosfet using resistance mode.
      Measure:
      source (1-2-3) & drain (5-6-7-8)
      source (1-2-3) & gate (4)
      gate (4) & drain (5-6-7-8)
      Each must be hundreds of k ohms or higher else could be defective. Repeat for each mosfet.
      • swimllamaswim
        • May 2016
        • 24
        Next..
        Measure:
        B+ looks good, at 4 megaohms. However, all four mostfets were shorted in some way. I'll get replacements on the way for those, but in the meantime, is there anything else I should check, that those could have affected? And for the 3rd Type C port running at 5v, I'm assuming that's the PD chip, correct? Do those need to be programmed?
        PQ1900:
        [B]source (1-2-3) & drain (5-6-7-8) - 75kohm
        source (1-2-3) & gate (4) - 1.7ohm
        gate (4) & drain (5-6-7-8) - 100kohm
        PQ1902:
        source (1-2-3) & drain (5-6-7-8) - 100kohm
        gate (4) & drain (5-6-7-8)​ - 100kohm
        PQ1903:
        source (1-2-3) & drain (5-6-7-8) - 37kohm
        source (1-2-3) & gate (4) - 50kohm
        gate (4) & drain (5-6-7-8) - 0.5ohm (resistance of my leads)
        PQ1904:
        source (1-2-3) & drain (5-6-7-8) - 50kohm
        gate (4) & drain (5-6-7-8) - 50kohm​​
          DELL Precision 5550 Mobile workstation 5000 Specification for Upgrade or Repair
          This specification for the DELL Precision 5550 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5550 boardview and 5550 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Precision...
          09-06-2024, 08:10 PM
