RCA no power indicator
Re: RCA no power indicator
After checking it again, several times the original readings are correct. All 12 volt terminals show 10 volts and all 5 volt terminals are showing 3 volts. I'm not sure why it keeps giving me different readings but several tests are showing the readings I just mentioned.Comment
I was confused as to why I keep getting different readings so I had a friend come over (he has a little more experience with electronics than I do) and he tested it for me as well.
He found the same results as I, all 12 Volt terminals show 10 volts and all 5 volt terminals are showing 3 volts.
He was never able to get it to show anything else, we have tried 3 different meters and they are all showing the same thing.
sorry for all this confusion and again thanks for the patience with my inexperience.Comment
More in depth power supply troubleshooting required. Need good straight shot high res of the top and bottom side of that power supply board.Never stop learning
The PSU should only produce 5VSB with the main board disconnected. Nothing else. You can't get to read any other voltages on the secondary with the main board disconnected, until you supply 5VSB to PSon. Just sayin...
Can we see the component side of the PSU too?
While you are at it, snap a pic from the main board as well and post the model number of the TV.Last edited by CapLeaker; 08-04-2017, 06:37 PM.Comment
I have attached the pics....Attached Filesif you find these attachements useful please consider making a small donation to the site
RCA LED50B45RQ
http://www.shopjimmy.com/rca-re46hq1...led-board.htm#
RCA RE46HQ1290 Power Supply / LED Board
Please check the DCV at the PS-ON pin to see what it shows when TV is plugged in but the power switch is not activated and when the power switch is activated.
Pictures provided by shopjimmy.Attached Filesif you find these attachements useful please consider making a small donation to the site
The "PS-ON" shows 3V when the power switch is activated and it shows 3V when not activated.RCA LED50B45RQ
Pictures provided by shopjimmy.Comment
Measure the 12V pin also to see if it is showing 10V too.Never stop learning
Q12 top right corner section appears to be disintegrated. 2 up from D12 Also a leaking capacitor can pull voltage down. If that transistor is shorted it could be hitting some resistors that are acting like a voltage divider. if the short was to full ground it would be more obvious and easier to find.Comment
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by GjacksonHi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
on this laptop acer aspire v571p the led of the power indicator blinks blue for periods of 1s lighted and 3s off after switch on and this indefinitely.
i tried the hard reset, cmos reset, changing the ram without results.
in order to reach the cmos battery i disassembled the laptop and did several mesures with my multimeter.
The 19v, 5v, 3v are well established after the chip 5v-3v. the following signals : 3d3v_aux_kbc (which supplies the sio chip) and 3d3_s5 are well established also.
but the signals: 3dv3_s0, pw_slp_s3# and pw_slp_s4 oscillate at the same...Today, 03:54 PM - Loading...
