KDL-60W600B won't open just Red Blinks 6 times
  • Ali101
    • Jul 2017
    • 152
    • Taiwan
    I have Sony KDL-60W600B 2 years old TV, last night every thing was ok & i closed via remort, On morning when i try to open TV via remort, it won't open & just flashing 6 red blinking, no audio, no video, even after turn on tv it won't let turn off via remort or tv power button but only the way is to un-plug power, i google it & try to find way to fix it from past 72 hours but no success, i use hard reset to factory re-set tv, but no success, i saw around google some one said its T-Con fault so i tired & if i take T-Con board cable un-plug & try to open tv than tv open with green light which is stable & than i can use remort to close tv as well, so i have no idea whether i have issue with T-Con board or Main Board or Power Board, here expert ppls help will be highly appreciated on this issue, since i almost gave up as from past 72 hours no success, i hope some one will help me to sort out where i have issue so i fix my tv, since i am noob but know little bit about fixing things,
    Thanks.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: KDL-60W600B won't open just Red Blinks 6 times
    Have you checked the fuse F102 marked 32V, 5A on the Tcon is not open circuit?
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Look for these components on the PSU PS6800 (fuse to ground) and Q6814. The fuse may be open and the transistor shorting.
      • Ali101
        • Jul 2017
        • 152
        • Taiwan
        Re: SONY KDL-60W600B won't open just Red Blinks 6 times
        Thank for reply, can you please help me to tell i need to check fuse F102 with multi meter right? and i not understand this (5A on the Tcon is not open circuit?) also i upload T-Con pics where i mark with red fuse F102, please confirm whether this is the one which you advising, appreciated your help,
        Thanks.
        • Ali101
          • Jul 2017
          • 152
          • Taiwan
          Thank for reply Andrew, sorry but i can't find PS 6800 & Q6814 on PSU, can you point out to me where is it located in below PSU pics, also please help me how i check with multi meter, i.e set multi meter on which range, and do i need to plug in power & turn on tv than check? since after tv turn on it keep blinking red flash 6 times,
          Appreciated your help,
          Thanks.
          Edit: added Tv back picture also,
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Thanks.
            F102 in yellow box
            Use your meter set to ohms and place probes on each side and measure resistance which should be 0 ohms or a few ohms at the most due to the resistance of your meter leads. Test with power off.
            • Ali101
              • Jul 2017
              • 152
              • Taiwan
              F102 in yellow box
              Thanks for help dick_barton, as per your instruction i test it fuse F102 on said location with multi meter set on ohms & result is below,
              with rang of 200 = 0.06
              with rang of 2000 = 001
              with rang of 20k, 200k & 2000k = 0.00
              waiting for your reply & support,
              Thanks.
                Fuse is OK, given those results.
                Try checking each side for 12V supply, when the board is installed in the TV and the TV is turned on.
                (It might go to 12V then turn off after the error code occurs.)
                • Ali101
                  • Jul 2017
                  • 152
                  • Taiwan
                  Hello Tom and thank you very much for help and support, much respect, do i need to check again on above fuse f102 each side 12V while tv turn on,
                  Thanks.
                    Thanks.
                    Yes, turn TV on, watch the reading, does it go to 12V.
                    Use the "20V" DC range of your meter, or the closest similar one, must be higher than 12V.
                    If your multimeter is an auto-ranging one (given what you've said above I don't think it is, but good to be sure), make sure you lock the range as it won't range-up quick enough to capture a quick pulse. So you'd lock it at 20V or 40V or whatever its closest range is.
                    • Ali101
                      • Jul 2017
                      • 152
                      • Taiwan
                      Ok thanks tom, will check and get back with results,
                      Thanks.
                      • Ali101
                        • Jul 2017
                        • 152
                        • Taiwan
                        Hello again Tom, i use to test with power turn on tv and fuse f102 have 12.38 V out put for one to two seconds while turn on tv after 2 seconds it goes to 0.00 V, i set my multi meter on 20 DC range, since i start tv, it start with white light and in one second it turn to red with keep blinking 6 times, any suggestions will be appreciated,
                        Thanks.
                          Sounds like the TV is detecting a fault with the T-con or other part and shutting down but given you have 12V at the t-con there is no short or fault with that part of the power supply.
                          I would look for a service manual to check what a 6 blink code means.
                          • Ali101
                            • Jul 2017
                            • 152
                            • Taiwan
                            Thanks Tom, as per service manual, it says 6 red blinking means either its (Primary) Most likely defective part. (POWER SUPPLY or LCD PANEL) and (Secondary) Possible defective part (MAIN BOARD or TCON or LVDS FFC) attached file is service manual with screen image of above predictions,
                            Thanks.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter
                                Check the voltages going to the backlight of the panel, I suspect along the connectors CN6801 and CN6802 on thep ower board.
                                • Ali101
                                  • Jul 2017
                                  • 152
                                  • Taiwan
                                  @vinceroger69 thanks for headup, appreciated your help bro, @Tom can you advise how i can check on PSU CN6801 & CN6802, i mean multi meter should be on 20 DC rang right? & out come volts should be 3-5V right? does tv should turn on while checking CN6801 & CN6802? can you point out me where i place multi meter probes,
                                  looking forward to your reply,
                                  Thanks.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    Maybe forget this above as just realised your set is a led tv this this 6 blink code maybe for the older ccfl type tv im sure tom will confirm as it mentions inverter
                                      Higher voltage needed. Could be up to 200V - careful, high voltage.
                                      Also will need to see the labels near thjose connectors.
                                      The most likely fault is an open circuit LED in the LED strip.
                                      If this is the case the output voltage will go high then shut down, and one of the cathode pins will measure a higher voltage than normal.
                                      • Ali101
                                        • Jul 2017
                                        • 152
                                        • Taiwan
                                        Dear Tom, i check PSU CN6801 & CN6802 with Multi meter set 200 DC Range & below is results,
                                        CN6801:
                                        Pin 1=90 V, after turn tv on it drop slowly 89...88..87......3.2.1
                                        Pin 2=90 V, after turn tv on it drop slowly 89...88..87......3.2.1
                                        Pin 3=90 V, after turn tv on it drop slowly 89...88..87......3.2.1
                                        Pin 4=90 V, after turn tv on it drop slowly 89...88..87......3.2.1
                                        CN6802:
                                        Pin 1=13.5 V, after turn tv on it drop slowly 12...11..10......3.2.1
                                        Pin 2=13.7 V, after turn tv on it drop slowly 12...11..10......3.2.1
                                        Pin 3=13.6 V, after turn tv on it drop slowly 12...11..10......3.2.1
                                        Pin 4=13.6 V, after turn tv on it drop slowly 12...11..10......3.2.1
                                        Pin 5=0.00 V,
                                        your furthur advise will be highly appreciated,
                                        Thanks.
                                        • Nairolf
                                          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                          by Nairolf
                                          I have a Samsung DM32D display.
                                          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                          Here’s what I have tried so far:
                                          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                          From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                          08-24-2025, 03:47 AM
                                        • JarzabekPZ
                                          HP Victus 15-fb0104nw not turning on, charging led blinks 3 times
                                          by JarzabekPZ
                                          I'm working on a HP Victus that is not turning on. When power button pressed it only blinks 3 times with charging led. I have checked input mosfets and they are fine. Also all coils are fine too. Battery was empty but I charged it with my lab PSU and laptop started on batery but is not charging. When battery is disconected and only PSU connected it takes 0 current and not starting. What can be the reason?
                                          09-18-2025, 08:16 AM
                                        • htv239
                                          LG UH8500 Backlight Troubleshooting Help
                                          by htv239
                                          I am currently troubleshooting an LG 60UH8500 TV (2016 TV). Any help or suggestions would be appreciated.
                                          Overall Issue: When TV is turned on, backlights all come on for about 10 seconds, then all go out. There is sound and there is a picture on the display (obviously hard to see without backlights, but it is there).
                                          What I Have Done So Far: 1) Removed the back TV cover to expose the boards (Power Supply, Tcon, and Main), 2) blew out any dust and cleaned all connections, 3) Noticed that the LED backlights are fed from two separate connectors...
                                          10-11-2021, 01:53 PM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • netgearnetgear
                                          TCL 43S423 TCON OR PANEL FAULTY???
                                          by netgearnetgear
                                          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                                          08-20-2025, 06:04 PM
