Samsung PN60E530 plasma tv power on issue
    hi
    when plugged in you can hear the samsung startup jingle and i can see various lights on the boards.. the screen is black..no image of any sorts
    the standby light just flashes and then goes off....no green or blue pwr light comes on
    i test voltages coming out of power supply and they all seem good
    if i try to hit the power switch on the tv the standylight just flashes and goes off
    any ideas?
    Re: Samsung PN60E530 plasma tv power on issue
    Pictures ? Of all the boards might help you more to solving your issue
      Yes mate there aren't a lot of clairvoyants on this forum and all they have really got from this is the set trys to start but doesn't and you think the voltages are all ok from power board. There are a number of tests you should do e.g. see other samsung plasma posts this page.
        Yes mate there aren't a lot of clairvoyants on this forum and all we have really got from this is the set trys to start but doesn't and you think the voltages are all ok from power board. There are a number of tests you should do e.g. see other samsung plasma posts this page. Almost 800 posts??!!
          thank you here are a few photos ob back of my tv....seems they use way less compoennets than they did back in 2006 model plasma tvs
            i even unplugged all the boards and still cant get power on light to come on
            when tv is plugged in the samsung jingle immediatley plays and thats it
            hitting the power button after this does nothing but cause front led to flash red everytime you push the button..
            there is no power light on front of tv....no image....
            ill do some more testing of voltages when i can...
              VS/VA/VSC readings are ?
                hi ok i did some more voltage testing
                when i power tv on with remote the samsung jingle comes on ..apparently this tv does not have a blue or green power on light on front of tv....the standy light just blinks a few times when you power it on and then goes away..
                anyways here are some voltages i tested just now when power tv on..
                vs from ps starts normal then slowly goes to zero
                va from ps starts normal then slowly goes to zero
                can someone tell me where the vscan on y and ve on z test points are in my pics if you
                can see...
                also logic board green light flashes every 6 seconds....i saw another post that says this means bad y ..or y buffer or z
                  voltage test if i unplug the power to z board (which also powers off to y board since z feeds y)
                  when i power tv on i hear the samsung jingle but the green light on logic board stays off and when i test voltages i get
                  vs=0
                  va=0
                  standby=0
                    update...i have been looking at a few other posts on this model ...
                    if i unplug power to y and also the flat ribbon cable to y .....the tv powers on with samsung jingle and the logic board now blinks every 1 second
                    voltages
                    vs=not sure...when i test it now it shows "out of limits" ...shows up as 1 on far left of cheap harbopr freight multimeter....i use 1000v setting since its suppose to be 211 volts
                    va=good 57v
                      im thinking this is a y or y buffer issue
                        Yes the tests now done give good reason to suspect y side problem. Check y main for short. Samsung boards generally in good supply at reasonable prices.
                          thank you im thinking y also but it seems from research i have done that this is a very common issue with y board....
                          3 bad ceramic caps and 1 bad ic
                          very common..so common they sell the kit on ebay lol
                          cheap enough to buy the parts and try it..so i will look
                            Have you also tested the y buffers for shorts?
                              y buffers tested ok....not shorted
                                My post 22/6/17 contains a download for 2009 models troubleshoot tutorial you may find helpful.
                                  Update...replaced 3 blue caps on yours..tv now powers on ok with picture
                                  Did not replace the ic....didn't need to
                                  Thanks to everyone who helped here and via other posts
                                  Seems to be a very common issue....
                                    There is a slight issue with top of screen grainy....will reseat y buffers....
                                    Or maybe buffer issue...but tv does power on good now and logic board is flashing every second now which means ok
                                      Correction replaced 3 blue caps on ysus ....damn iPad auto fill lol
                                        Found a great site..arrow electronics.....
                                        Arrow at this time offers free shipping all orders
