Samsung PN60E530 plasma tv power on issue
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    hi
    when plugged in you can hear the samsung startup jingle and i can see various lights on the boards.. the screen is black..no image of any sorts
    the standby light just flashes and then goes off....no green or blue pwr light comes on
    i test voltages coming out of power supply and they all seem good
    if i try to hit the power switch on the tv the standylight just flashes and goes off
    any ideas?
  • sordids999
    • May 2013
    • 2149
    Re: Samsung PN60E530 plasma tv power on issue
    Pictures ? Of all the boards might help you more to solving your issue
    • maxvalutech
      • 804
      • australia
      Yes mate there aren't a lot of clairvoyants on this forum and all they have really got from this is the set trys to start but doesn't and you think the voltages are all ok from power board. There are a number of tests you should do e.g. see other samsung plasma posts this page.
      • maxvalutech
        • 804
        • australia
        Yes mate there aren't a lot of clairvoyants on this forum and all we have really got from this is the set trys to start but doesn't and you think the voltages are all ok from power board. There are a number of tests you should do e.g. see other samsung plasma posts this page. Almost 800 posts??!!
        • shelby5041
          • Feb 2009
          • 1505
          thank you here are a few photos ob back of my tv....seems they use way less compoennets than they did back in 2006 model plasma tvs
          • shelby5041
            • Feb 2009
            • 1505
            i even unplugged all the boards and still cant get power on light to come on
            when tv is plugged in the samsung jingle immediatley plays and thats it
            hitting the power button after this does nothing but cause front led to flash red everytime you push the button..
            there is no power light on front of tv....no image....
            ill do some more testing of voltages when i can...
            • sordids999
              • May 2013
              • 2149
              VS/VA/VSC readings are ?
              • shelby5041
                • Feb 2009
                • 1505
                hi ok i did some more voltage testing
                when i power tv on with remote the samsung jingle comes on ..apparently this tv does not have a blue or green power on light on front of tv....the standy light just blinks a few times when you power it on and then goes away..
                anyways here are some voltages i tested just now when power tv on..
                vs from ps starts normal then slowly goes to zero
                va from ps starts normal then slowly goes to zero
                can someone tell me where the vscan on y and ve on z test points are in my pics if you
                can see...
                also logic board green light flashes every 6 seconds....i saw another post that says this means bad y ..or y buffer or z
                • shelby5041
                  • Feb 2009
                  • 1505
                  voltage test if i unplug the power to z board (which also powers off to y board since z feeds y)
                  when i power tv on i hear the samsung jingle but the green light on logic board stays off and when i test voltages i get
                  vs=0
                  va=0
                  standby=0
                  • shelby5041
                    • Feb 2009
                    • 1505
                    update...i have been looking at a few other posts on this model ...
                    if i unplug power to y and also the flat ribbon cable to y .....the tv powers on with samsung jingle and the logic board now blinks every 1 second
                    voltages
                    vs=not sure...when i test it now it shows "out of limits" ...shows up as 1 on far left of cheap harbopr freight multimeter....i use 1000v setting since its suppose to be 211 volts
                    va=good 57v
                    • shelby5041
                      • Feb 2009
                      • 1505
                      im thinking this is a y or y buffer issue
                      • maxvalutech
                        • 804
                        • australia
                        Yes the tests now done give good reason to suspect y side problem. Check y main for short. Samsung boards generally in good supply at reasonable prices.
                        • shelby5041
                          • Feb 2009
                          • 1505
                          thank you im thinking y also but it seems from research i have done that this is a very common issue with y board....
                          3 bad ceramic caps and 1 bad ic
                          very common..so common they sell the kit on ebay lol
                          cheap enough to buy the parts and try it..so i will look
                          • sordids999
                            • May 2013
                            • 2149
                            Have you also tested the y buffers for shorts?
                            • shelby5041
                              • Feb 2009
                              • 1505
                              y buffers tested ok....not shorted
                              • maxvalutech
                                • 804
                                • australia
                                My post 22/6/17 contains a download for 2009 models troubleshoot tutorial you may find helpful.
                                • shelby5041
                                  • Feb 2009
                                  • 1505
                                  Update...replaced 3 blue caps on yours..tv now powers on ok with picture
                                  Did not replace the ic....didn't need to
                                  Thanks to everyone who helped here and via other posts
                                  Seems to be a very common issue....
                                  • shelby5041
                                    • Feb 2009
                                    • 1505
                                    There is a slight issue with top of screen grainy....will reseat y buffers....
                                    Or maybe buffer issue...but tv does power on good now and logic board is flashing every second now which means ok
                                    • shelby5041
                                      • Feb 2009
                                      • 1505
                                      Correction replaced 3 blue caps on ysus ....damn iPad auto fill lol
                                      • shelby5041
                                        • Feb 2009
                                        • 1505
                                        Found a great site..arrow electronics.....
                                        Arrow at this time offers free shipping all orders
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • lp20th
                                          Samsung Plasma TV Power Supply Issue
                                          by lp20th
                                          I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                                          11-28-2023, 10:28 AM
                                        • CDNBrewer
                                          Samsung Plasma PN43D450A2D No Power
                                          by CDNBrewer
                                          Hello, I have a Samsung Plasma TV - Model # PN43D450A2D
                                          This was my parents TV and the initial symptoms were that the display was hard to turn on with the display making various clicking noises until one day it would not turn on anymore.
                                          I took a look and found a couple 1000uF capacitors (i believe on the low voltage size) that had leaked out their electrolyte and did not test well on a tester. I replaced them but still no dice.
                                          When the TV is plugged in, there is no clicking, LED status lights (on PCB boards or the front display) and the power on button...
                                          03-02-2025, 04:59 PM
                                        • Cookybaby
                                          Samsung UN60ES6500FXZA Power Supply Issue
                                          by Cookybaby
                                          Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                          I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                          Make: Samsung
                                          Model: UN60ES6500FXZA
                                          Power Supply P/N: BN44-00525A
                                          Symptoms: The TV was...
                                          08-20-2023, 12:26 PM
                                        • Drewwol11
                                          Samsung QN49Q70RAFXZA Power Cycling Issue
                                          by Drewwol11
                                          My Samsung TV display recently stopped working while I was playing PS4 (no storm or anything to indicate a power surge). I could still hear audio through the PS4 but no display. The TV kept trying to turn on but would turn off after a second or two.
                                          I tried the obvious troubleshooting steps like unplugging, replugging, trying different outlets and power cords with no luck. Someone on another forum suggested that it may be a power supply issue so I purchased a replacement power supply board but that did not help. I then disconnected the main board from the...
                                          08-31-2021, 09:32 AM
